How to correctly use the outputs of Gaussian Peak Fit?
I use the Gaussian Peak Fit.vi on data with very few points.
To get an idea of what the fitted curve looks like and to double check how well it performed, I wrote some extra code that is using the outputs of the vi to generate a nice curve with a few more (say 100) points on the x axis. Then I display the original data, the "Best Gaussian Fit" output and the curve calculated from the output parameters on the same graph:
post-28303-0-06797200-1418690195_thumb.p
I expected the four points of the red curve to be exactly on top of the green curve - but they're not.
Here's the block diagram (also attached as LV2012 VI: GaussFit.vi).
post-28303-0-42112100-1418690381_thumb.p
What am I doing wrong?
  • 6 months later...
Hello Thomas, would you mind to upload also a version of your program to a 2011 version? It would help me a lot! :D
Thanks in advance!
Luiza
Someone should make a internet drop box type app for conversion.
Somewhat ironically, Darin did exactly that, although that's not public. There's also this - https://labviewhacker.com/revert/ (edit - which I see is floated in the conversion board you linked to).
Edited by Yair
