Similar Content
By bbean
I put together a simple xnode to relabel event registration reference wires that feed into dynamic events of event structures. With the increasing use of event based messaging systems, I found myself manually changing the name of event registration references to clarify the event name when multiple event registration references were used in an object. I did this by manually creating a cluster constant on the build cluster before the dynamic registration terminal on the event structure and renaming each registration reference. Being a lazy programmer, this seemed tedious after a few times so I decided to attempt to create an Xnode to accomplish the same thing faster. This video shows the "problem" and the potential solution using the xnode:
Re-Label Xnode - Event Registration
Here's another example showing another use case with ShaunR's VIM HAL Demo code:
Re-Label Use Case ShaunR HAL Demo
This may have been done before or there may be an easier way to do this, but I wanted to throw it out here to see if there's any interest and to see if people will try it out and give feedback. I've found it works best using quick drop for initial use (highlight wire, CTRL-Space,type re-label, CTRL-I, type new name in dialog) and for replacing or renaming an existing instance on the diagram (highlight existing xnode, CTRL-Space, type re-label, CTRL-P, type revised name in dialog). You can also use directly from the palette, but I found much faster from quick drop and also seen a couple crashes replacing through the pallete.
The Double Click ability is also a work in progress. Its purpose is to allow you to quickly rename the relabel with the same dialog box, but when it executes it breaks the wire on the output connection. You can still re-wire it to the event structure, but you will have to open the Event Structure Edit Events menu to get the event to "Re-link". Something I'm trying to avoid.
The Xnode generated code is simply a pass through wire with the output terminal renamed to the label of your choice. This seems to update attached event structures.
- B
sobosoft_llc_lib_diagram_tools-1.0.4.1.vip
By bI0ndin
Hi everybody,
While I was having some time to develop new scripting stuff i wondered "would it be possible to add somme scripting stuff in the VI toolbar ? " (the one with run, run-continuously, abort, police stuff and so on). My point is to add kind of a combobox that populate with every events in the current vi for a control when clicking on it. And of course show the effective event and make it blink when selecting it in the combobox.
The scripting part is almost done but i now come to the real problem :
"How can I add this piece of code in the VI toolbar ?"
I know i can create either a Quidrop Plugin or a shortcut menu plugin but they don't fit the way i wan't to use this plugin.
I asked some NI guy that told me the only options where the one above but I can't imagine that LabVIEW is not in some way developed around a "plugin architecture" so if any of you as plunge deep into LabVIEW's files and know where and how to achieve this goal it would be really nice
Thank's everybody and I hope my question was clear.
By Tripmeister
Hey guys,
I'm trying to do some scripting on a Realtime-VI wich uses the FPGA Interface "Read/Write Control". I open a Reference to a VI containing a Read/Write Control, and when scrolling through the BD-Objects I find it with the class-name "nirviReadWriteControl".
I used the "to more specific class"-VI to check wich class i can cast it to, and i tracked it down to be child of the GObject->Node Class. But i can't cast it to any of the childs offered in the class specifier constant.
I also found out, that the "nirviReadWriteControl" is a xnode.
I have never worked with those, is there a way to access theyr methods (I think they're called "abilities" for xnodes)?
The goal of the application is to make the Read/Write Control display all available FPGA FP-Elements, and connect Controls/Indicators to them.
There is the same Problem with the "Open FPGA Reference"-Node (Classname "nirviOpenFPGA").
I really hope somebody dealed with the xnodes a bit and can help me programmatically controlling them!
Best,
Trip
By bbean
After reading this LabVIEW Idea exchange request:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Provide-a-better-way-to-implement-a-polymorphic-VI/idi-p/920487
I was inspired to create VI macro(s) to attempt to address the problem mentioned in the request. Attached is my first attempt and I'm looking for feedback since I know people here have strong opinions. The benefit of this method is that a single vim (or 2 could replace a polymorphic VI with over 48 separate VIs....unless I'm missing something. I know that VI macros are not officially supported by NI, but that hasn't stopped us from using unsupported features before. Some people have probably already done something like this, but I couldn't find an example.
To use the files, unzip them and copy them all to your \LabVIEW (version)\user.lib\macros\ directory.
Create the directory if it does not exist. For example: C:\Program Files (x86)\National Instruments\LabVIEW 2014\user.lib\macros\ And as described in the wait-ms-with pass through post below, modify your LabVIEW.ini file to have the following ExternalNodesEnabled=True and Optionally XNodeWizardMode=True http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Wait-ms-with-error-pass-through/idc-p/3178218#M31820
Open the Example Changed.vi and review.
Changed Example.zip
By pylb
i am trying to automate building a code, deploying it on an RT target and rebooting the target. I've got everything working but I do have a dialog box saying that the connection to the target was lost popping up.
I would like to disable this notification during my process and re-enable it after.
Anyone has an idea how to do this?
I tried the "suppress Project Dlgs" invoke node of the target but it does not work.
I changed the target Tags to prevent the "periodic check of the responsiveness of teh RT protocol" but that did not work either.
I found this invoke node for the project that us called SuppressChangeNotification. I am not sure if that would do it since it could just be change of the content of the project not changes in the state of a target in the project. But the problem is, since it is part of the SuperSecretPrivateSpecialStuff the inputs are not documented and it needs ItemIDs of the notification that will be suppressed.
Anyone know what those IDs are? or has a better way to suppress that diakog box?
thanks,
Pierre-Yves
