Drag and Drop onto Listbox
Hi.
   I was to drag a file from the finder onto a 'listbox' type object in a LabVIEW vi. I then want the object to display the complete path of a file. I can make a "Path" type object do this, but i do not seem able to do the same with a listbox. Does anyone know if this is possible?
Code Attached.
Drag'n'Drop-Listbox.vi
Many thanks, Alec
What is a "finder".  Do you mean you are dragging and dropping from the Windows explorer window?  If so someone posted an example on LAVA that uses some windows messaging library.
https://lavag.org/topic/14540-drop-into-a-tree-from-other-program/#entry87760
Another trick I've seen is that the path control allows you to drop files on it, so you might be able to get a path control and make it transparent, and put it over your listbox.
Whats A FINDER! Dang, you kids. (The finder is what windows explorer used to be called on the Apple Macintosh, LabVIEW also comes on Macintosh, In-fact, it was there first, Microsoft were late to the party... As usual! ;)... ). Yes, I do mean Explorer, think i had a relapse. Will check out the link, thanks.
OK, so what you are saying is that you just can't. LabVIEW does not support dragging from the desktop and dropping on it... Hmmm, rubbish.
Edited by alecjcook
So I'm a bit confused, are you on Windows or Mac, cause you say you mean Explorer, but then said Finder which "is what windows explorer used to be called".  I believe Windows Explorer used to be called File Manager in the Windows 3.x days.
And what do you mean by "Dang you kids", there could be people of any age that just have never used a Mac.
I didn't say LabVIEW doesn't support drag and drop, I'm saying there are options for doing drag and drop from an Explorer, but none are clean, other than onto a path control.  I've seen several neat examples, like this one with dragging an image on a tab.  The source isn't available but I wouldn't be surprised if a path control just isn't on top of the image since you don't interact with the image.
I believe LabVIEW doesn't have a unified way of doing this because it is cross platform, and you could be using any number of shells for any OS and supporting all of them would be a pain.  I like the idea, but I have yet to need this feature.
Easy tiger. He was just being jocular with an expression..
I didn't mean anything by it and didn't really take offense, sorry if it came across as hostile. (BTW I am one of those dang kids :D ) (but I also haven't used a Mac for more than 5 minutes in my life)
LabVIEW might support the dragging from explorer and dropping on a 'Path' control, but it does NOT support the dragging from explorer and dropping on a 'List Box'.
* "Dang You Kids" is supposed to be a light harder jove. I am british so it's not even a thing i'd say in real life. If I repeated some of the sarcasm us brits use, you really would take it the wrong way ;)
It doesn't stop me so I expect people in here are acclimatised :D
Guess how many toolkits Mac users buy? Guess how many queries I have had for installing any of my toolkits on Mac? : :lol:
It's possible to use the path control to do what you want, but it's a little hack-ey. You end up making the path control transparent, then only making it visible when the mouse is outside the VI's front panel. See http://digital.ni.com/public.nsf/allkb/81D867F8C6A1376D86257347001BE936
Oh that's not that too hacky, thanks for the link a quick search didn't find that one.  I was wondering how you would hide or shot based on mouse movement.  I guess the trick is that the Mouse Enter event isn't when dragging from explorer, until you release the mouse button.
And when you want it to accept dropping of multiple files you enter the next level in the world of pain :)
