kgaliano Posted April 13, 2016 Report Posted April 13, 2016 Good afternoon, I have a question regarding the subVI called "Write Panel to INI__ogtk.vi" in Labview version 2012. It seems like the input parameter "VI ref" is a reference that is not closed by this VI (specifically where the property node used to obtain the VI name is located). I was wondering if this can cause a memory leak? Thank you. Quote
drjdpowell Posted April 13, 2016 Report Posted April 13, 2016 The VI ref was created by the calling code, and the calling code is responsible for closing it if/when it needs closing. If I were updating this VI, I might add a “VI ref out†output to visually prompt the developer to deal with the ref. Quote
hooovahh Posted April 13, 2016 Report Posted April 13, 2016 Yup, the only potential memory leak is if this function opened a new VI reference, but didn't close it, or return it to be closed. The way the function works now, it will take a reference it assumes is already opened and then not close it. Generally if you open a reference, it should be closed in the same place it is opened. But honestly most of the time I use that function it is with a This VI reference which doesn't need to be closed anyway. Quote
kgaliano Posted April 14, 2016 Author Report Posted April 14, 2016 Thank you for your replies. Does this imply that, in general, "This VI" references do not need to be closed? So I am guessing that memory leaks typically arise from other references (e.g., control refnums, indicators, files, etc.)? Quote
drjdpowell Posted April 14, 2016 Report Posted April 14, 2016 Does this imply that, in general, "This VI" references do not need to be closed? So I am guessing that memory leaks typically arise from other references (e.g., control refnums, indicators, files, etc.)? Some refs are static; they always exist and you are neither creating or destroying them. “This VI†and control refs are of this type. “Closing†these refs is a no-op. Other refs are both dynamically created and involve holding resources open of some kind (like an open file, or a Queue or something). Here is where one worries about ‘memory leaks’. Quote
hooovahh Posted April 14, 2016 Report Posted April 14, 2016 "This" is a term I've heard NI use to refer to these types of references. If a reference is a This reference (like the This VI, or This Application, or This Control) then yes closing it is a no-op. The reference simply cannot be closed because it is being used. One way to know if your reference is a This or not, is to cast it to a U32 and look at the refnum. If the number changes with each run of your VI then it is a new reference and should be closed. If it is the same then there isn't a need to close it. I've also done a test where I run the VI using the run continuous and see if the memory in task manager increases. If it doesn't then what ever references I'm opening and is enough for a stable system. Quote
Darren Posted April 14, 2016 Report Posted April 14, 2016 I talk about which references should be closed vs. which ones you don't have to worry about closing in my Brainless LabVIEW presentation. 1 Quote
kgaliano Posted April 15, 2016 Author Report Posted April 15, 2016 Thank you for your explanations. Quote
ShaunR Posted April 15, 2016 Report Posted April 15, 2016 I talk about which references should be closed vs. which ones you don't have to worry about closing in my Brainless LabVIEW presentation. I was emphatically with you right up until the "train tracks" (my OCD prevents your version and there are genuine reasons for pass-through for optimizations) and palettes.(time and motion studies on placing primitives is ridiculous - you can make mistakes faster? ). Nice to see a fellow heathen picking holes in accepted dogma. Beginning to think I was the only one Quote
