Neil Pate Posted August 1, 2016 Report Posted August 1, 2016 (edited) I use locals sparingly, but in my typical use case where I really just need to use a value in more than one place (lazy yes, but not worth the effort to do it any other way) I need to read from a local rather than write to it. The default condition is to write though, so I need to change my virtually every time I need to use one. Am I the odd one out here? Don't suppose there is some SuperSpecialIniKeyForDefaultLocalVariableDirection? Edited August 1, 2016 by Neil Pate Quote
ShaunR Posted August 1, 2016 Report Posted August 1, 2016 Create a local variable. Set it to read. Use the pointer tool to grab it and create a copy. Works on anything, not just variables. Quote
hooovahh Posted August 1, 2016 Report Posted August 1, 2016 Yeah if you default to one you are going to upset one group of people or another. I would guess NI's thoughts were it you wanted to read a control just use its terminal, and a developer would be more interested in writing a local variable. If you aren't CTRL dragging yet you would be. I is a bit odd that that operation does something different than a copy paste but I like it. Quote
Neil Pate Posted August 1, 2016 Author Report Posted August 1, 2016 Sure I know about the CTRL-drag trick, I use it all the time. The problem is I use locals seldom, so most of the time there isn't another one to clone nearby on the BD. Quote
