A Scottish moose Posted October 13, 2017 Report Posted October 13, 2017 Hello Everyone, I noticed an interesting change today that I thought was worth mentioning. I've been using the classic system button for some of my UI's. It's flat and looks clean. Less busy. I noticed today that the graphics for this button are different from one of my PC's to another. My laptop, which is running 2016.0, looks like the original. My desktop which is running 2016.0f2 looks like the 'different' one. Both 2016 but one has no depth graphic and one does. I've dug through the menus folder and it looks like the classic and modern controls are not housed there, which makes sense really since they are probably proprietary. I'd prefer the original look as it matches with the flat Windows 10 style that's in vogue right now. Just something I noticed and thought was worth mentioning. Cheers, Tim Quote
A Scottish moose Posted October 13, 2017 Author Report Posted October 13, 2017 Update: I was able to replicate the original look with a 'Flat Square Button' and some color matching in about 5 or so minutes. Just be aware that if you move to sp1 of 2016 some of those graphics will change on you. Replicating them isn't a big effort however. Cheers, Tim Quote
drjdpowell Posted October 13, 2017 Report Posted October 13, 2017 (edited) System controls are supposed to change to match the operating system. Are your two machines on different Windows versions? Edited October 13, 2017 by drjdpowell Quote
A Scottish moose Posted October 13, 2017 Author Report Posted October 13, 2017 (edited) Yes. They are... however this was out of the classic palette. Perhaps you've taught me something new. I was under the impression that only system dependent controls are in the systems palette but I bet you are correct. The system button in the classic palette is OS dependent. Good catch Don't listen to my previous posts then because my conclusion was incorrect. Also thank you for your observation. Tim Edited October 13, 2017 by A Scottish moose Quote
drjdpowell Posted October 13, 2017 Report Posted October 13, 2017 I don’t know why the system buttons are also in the “classic” palette, but they are the same controls as in the “system” palette. BTW: If you use the non-system buttons you’ll lose the mouse-over “hover” effect (which, personally, I like a lot). You can instead customize a system button by swiping the change-with-the-os-shapes for regular rectangles or simple PNGs (such as the buttons in Flatline Controls). Quote
