Neil Pate Posted March 10, 2019 Report Posted March 10, 2019 Take a look at the attached control, all it is is a slider (which I think I modified from the flatline controls from drjdpowell) When I just open this in LabVIEW, not even anything running, my CPU usage jumps from about zero to nearly pegging one of the cores of my PC. Weird... Slider_Test.ctl Quote
ensegre Posted March 10, 2019 Report Posted March 10, 2019 Confirm. But I have seen such things happen with corrupted controls once or twice across the years. My wild speculation was that there is an underlying event loop which goes foul for some reason. 1 Quote
Neil Pate Posted March 10, 2019 Author Report Posted March 10, 2019 So weird. I have replaced it with a system control and everything is now behaving as expected. Quote
drjdpowell Posted March 10, 2019 Report Posted March 10, 2019 If you replace with an unmodified slider direct from Flatline does the problem come back? Quote
Neil Pate Posted March 10, 2019 Author Report Posted March 10, 2019 (edited) 6 minutes ago, drjdpowell said: If you replace with an unmodified slider direct from Flatline does the problem come back? Will check it out. I am on a new laptop so need to install the Flatline controls again. Edit: no everything seems to be behaving now. One strange thing, I see the latest Flatline slider has a round grab handle; has it always been like this? If so then I have no idea where I got my slider from as mine has a rectangular grab handle. Anyway, for now just going to use the system control (which is not ideal as I would like to be able to colour the grab handle to match some other colours on my GUI). Edited March 10, 2019 by Neil Pate Quote
drjdpowell Posted March 10, 2019 Report Posted March 10, 2019 I investigated, and it is because you made the two incr/decr arrows transparent. I've had suspicions in the past that there is something buggy about colouring things transparent. 1 Quote
Neil Pate Posted March 10, 2019 Author Report Posted March 10, 2019 (edited) 20 minutes ago, drjdpowell said: I investigated, and it is because you made the two incr/decr arrows transparent. I've had suspicions in the past that there is something buggy about colouring things transparent. Thanks James. I may be able to fix this then by colouring those arrows to be the same as my background colour rather than transparent. Edit: even more strangely, colouring them a colour and then back to transparent causes the problem to go away Edit2: LabVIEW is now behaving but the exe displays the same problem. I am going to leave this for now and just use the system control. If I get a moment I will try and fix it but for now I am moving on. Edited March 10, 2019 by Neil Pate Quote
drjdpowell Posted March 10, 2019 Report Posted March 10, 2019 You can either use a transparent PNG (there is one in "<vi.lib>\JDP Science\Flatline Controls\Transparencies\Full Transparent.png") which, strangely, is not the same as colouring something transparent. But the best option, if you don't want the User to be able to click on those arrows, is just to make them very small and hide them behind the main body of the slider. Quote
BramJ Posted March 11, 2019 Report Posted March 11, 2019 I can also confirm, I get about 25% CPU load on a quad core i5 Quote
