rscott9399 Posted April 29, 2019 Report Posted April 29, 2019 Hi I have a VI that is very complex that i did not write. Needless to say life is difficult right now I need to do the following. The VI outputs a certain enumeration if there is no error. AKA a complete bit However, the complete is happening to fast. I would like to delay the output of this enumeration just by a second Is there any simple way to do this? Thanks Quote
infinitenothing Posted April 29, 2019 Report Posted April 29, 2019 It would really be nice to see some code or even like just the concept to see what you're talking about. Have you seen this VI? http://zone.ni.com/reference/en-XX/help/371361P-01/glang/stall_data_flow/ 1 Quote
rscott9399 Posted April 29, 2019 Author Report Posted April 29, 2019 This might be perfect. I dont see it in my labview Where can i get this? Thank you so much Quote
rscott9399 Posted April 29, 2019 Author Report Posted April 29, 2019 I have gone to the example folders and found the folder but its not in there I have 3 basic examples but not a VI with that in it I am running 2017 pro Is there anyway you could post it for me. Quote
LogMAN Posted April 29, 2019 Report Posted April 29, 2019 On 4/29/2019 at 5:44 PM, rscott9399 said: I have a VI that is very complex that i did not write. Needless to say life is difficult right now ... AKA a complete bit Expand Thank you very much, this just made my day 🤣 On 4/29/2019 at 6:08 PM, rscott9399 said: I have gone to the example folders and found the folder but its not in there Expand You'll find the function on your palette under Timing. Alternatively press Ctrl+Space and write "Stall Data Flow", it should appear in the list. Quote
infinitenothing Posted April 29, 2019 Report Posted April 29, 2019 Basics lesson 1 has that VI in the lower right quadrant. You can also search for the VI by name using quick drop Also, on the help page it tells you the owning palette (Timing VIs and Functions) so you can find that VI. Quote
rscott9399 Posted April 29, 2019 Author Report Posted April 29, 2019 yes im familiar with the quick drop It was not there for some reason, i dont get it Quote
rscott9399 Posted April 29, 2019 Author Report Posted April 29, 2019 I dont how this is possible Quote
rscott9399 Posted April 29, 2019 Author Report Posted April 29, 2019 I have discoverd what the problem is This is a CRIO real time application The Stall Data can not be used on the RT side apparently. When i go to my host i can search for the VI and it will come up. So back to the 20 million dollar question, how do i delay this data flow for a split second on the RT side Quote
infinitenothing Posted April 29, 2019 Report Posted April 29, 2019 It should still work in RT even if it doesn't show up on the pallets. Try it. Or, check out the underlying code and copy that. Quote
rscott9399 Posted April 29, 2019 Author Report Posted April 29, 2019 I did try to copy the VIM from the example and import it into the RT part of the project It gave me a conflict that appears to be caused by the fact that LABVIEW knows the file is there but i am telling it to use a different path which is just a copy of it saved to my desktop Quote
rscott9399 Posted April 29, 2019 Author Report Posted April 29, 2019 I took care of the error and got it to deploy Lets see if it works, stand by Thanks for your help! Will post results in a minute Quote
LogMAN Posted April 30, 2019 Report Posted April 30, 2019 For reference, here is a comparison of how it was done before Stall Data Flow existed (prior to 2017). https://forums.ni.com/t5/LabVIEW/Darren-s-Occasional-Nugget-01-05-2018/td-p/3738420?profile.language=en Quote
rscott9399 Posted April 30, 2019 Author Report Posted April 30, 2019 The stall appears to have worked. You all are Steeley Eyed Missile Men 10 points if you can name that movie Quote
ShaunR Posted May 1, 2019 Report Posted May 1, 2019 On 4/30/2019 at 12:46 PM, rscott9399 said: The stall appears to have worked. You all are Steeley Eyed Missile Men 10 points if you can name that movie Expand Apollo 13? (It's a NASA saying) 1 1 Quote
rscott9399 Posted May 1, 2019 Author Report Posted May 1, 2019 On 5/1/2019 at 4:39 PM, ShaunR said: Apollo 13? (It's a NASA saying) Expand Correct! One of my favorites Quote
ShaunR Posted May 1, 2019 Report Posted May 1, 2019 On 5/1/2019 at 5:54 PM, rscott9399 said: Correct! One of my favorites Expand Well. I didn't even get one like, let alone 10 points 2 Quote
LogMAN Posted May 2, 2019 Report Posted May 2, 2019 On 5/1/2019 at 10:12 PM, ShaunR said: Well. I didn't even get one like, let alone 10 points Expand It's like real life - overpromised and underdelivered. Now others have to fix it 😋 1 Quote
