Nested Malleable vis breaks vipc build?
I'm having problems building a vipc from a vipb with files containing nested vims. Getting the following error from VIPM:
ERROR: 7: VIPM API_vipm_api.lvlib:Parse Build Return Message_vipm_api.vi<ERR>
Code:: 7
Source:: 0053C289D635723F5DC0A4F08297566A<ERR>
The following source VIs or Libraries are missing.
Please correct this problem before rebuilding.
b39afad9-8321-4719-86a9-dddab325fc87.vi
The following source VIs or Libraries are the callers of missing files
BitsSetter.vim
I created a zip with the vims and the vipb file. Any suggestions how to fix this?
Opening the files shows no errors. Replacing the nested vim with its actual implementation fixes the problem but I don't want to give in just yet.
I'm on LV 18.0.1f4 64bit with VIPM 2018.0.0f1
Cheers
bits.zip
Edited by ThomasGutzler
It looks like the issue is putting nested VIMs in a class.  See https://forums.jki.net/topic/2641-vi-calling-vim-fails-to-build-fixed-in-vipm-2017f1/ and https://forums.ni.com/t5/LabVIEW/VI-Package-Manager-Fails-to-Build-with-Malleable-VIs-VIMs/td-p/3871468.
@Jim Kring If you are still looking for a simple reproducing case of this bug, here is one.
On 11/21/2019 at 10:01 AM, ThomasGutzler said:
Good find!
@Jim Kring happy to assist in any way I can when you're looking into this bug.
Jim does not come to LAVAG often (e.g. see https://lavag.org/topic/21017-where-are-openg-product-pages-for-packages/?do=findComment&comment=129287 )
I'd imagine you'd get a lot more interest if you post at the JKI forums
13 minutes ago, ThomasGutzler said:
Unfortunately, nobody seems to care about this any more :(
Nested malleables + VIPC is not a combo that I use :)
19 hours ago, ThomasGutzler said:
I replied with an example on the relevant thread on the JKI forum
You might want to post a link to this thread in that thread.  The attachment is listed as unavailable - the error message says "This attachment is not available. It may have been removed or the person who shared it may not have permission to share it to this location".  Brian's original attachment is also listed as unavailable.
Maybe that was JKI's problem all along - they wonder why no one sends them examples while not realizing that they don't allow anyone to post code.
Edited by TomOrr0W
17 minutes ago, TomOrr0W said:
The attachment is listed as unavailable - the error message says "This attachment is not available. It may have been removed or the person who shared it may not have permission to share it to this location".  Brian Hoover's original attachment is also listed as unavailable.
I can download them both. Maybe you need to have an account for the download to work. I had to create an account to be able to upload.
  • 1 month later...
  • 4 weeks later...
