Disable item on runtime shortcut menu of a control
Hi all,
I would like to know if there is a way to access to the reference of the runtime shortcut menu of a control? I would like to enable/disable one of those menu item programmatically. I only know how to access the runtime menu of the VI.
Thanks in advance.
In the event structure, have an event for the Shortcut Menu Activation? event.  This returns a Menu Reference that can then enable, disable, add, and remove menu items.
  • 2 years later...
