Conditionnal Disable structure dont display same choice
I try to modify one program and add conditionnal Disable structure but i don't have same choice than if the vi is new.
Old vi choice:
new vi choice:
I suspect it's about compilation because the second isn't compile. But is there one simple method to modify this on the old VI without recreating it?
I've seen that some cases the symbols shown are only pulled in from the target that is listed under the project.  Did you happen to open this from a blank VI or a new project?  Anyone can add additional symbols, and NI adds a few when you add certain targets to your project.  You can view these by going to the properties of the target from the project.
Hi hooovahh and ShaunR
The old and New are created without project. I have tryed to add case "OS" but LV tell me than  this word didn't exist. Is there a way to modify those options outside project?
Small detail, the old vi is in LLB.
I don't think so, it won't work outside of a project anyway since that conditional value is only going to be available in a project that has that value.
I can't reproduce what you are saying with a new VI outside of a project, it is still showing what is in your top screenshot. When you open a new VI if you have a project open it automatically adds it to that project, could that be what happened in your case?
Many Thanks,
Riley
