Antoine Chalons Posted May 26, 2021 Report Posted May 26, 2021 After installing LV2019 SP1 f4 using NIPM I can't launch VIPM (20 or 21) anymore If anyone has an idea to solve this... Quote
X___ Posted May 26, 2021 Report Posted May 26, 2021 Thanks for the heads up. Still using f3. I am surprised that I haven't been nagged by NIPM yet... Is that patch even documented anywhere? Quote
Antoine Chalons Posted May 26, 2021 Author Report Posted May 26, 2021 yes it is : https://www.ni.com/fr-fr/support/documentation/bugs/19/labview-2019-sp1-bug-fixes.html 1 Quote
Rolf Kalbermatter Posted May 27, 2021 Report Posted May 27, 2021 How about deselecting VIPM installation in the package when installing? Quote
Antoine Chalons Posted May 27, 2021 Author Report Posted May 27, 2021 I'm not sure what you mean... I never install VIPM via NIPM, it only offers an out of date version. But being stuck now, I've completely un-installed VIPM and VIPM runtime, and re-installed it from NIPM and I get the same error. I guess I should un-install LV2019 and re-install only up to 2019 f3... but that's going to take a long time Quote
Rolf Kalbermatter Posted May 27, 2021 Report Posted May 27, 2021 Does the Patch update somehow also contain VIPM? Seeing that it is a patch it probably doesn't but it's worth checking. When you install packages through NIPM you can usually select sub packages that are or are not installed. Default is to install everything but if there is a selection possibility (the Full LabVIEW installer gives you an option to deselect VIPM), then you can control what gets really installed. Quote
Antoine Chalons Posted May 27, 2021 Author Report Posted May 27, 2021 I don't remember if there was a separate option for VIPM, but I'm sure that if there was I disabled it. Quote
Antoine Chalons Posted May 27, 2021 Author Report Posted May 27, 2021 this screenshot comes from a co-worker who has not yet installed 2019 SP1 f4 > no option for VIPM Quote
Antoine Chalons Posted May 27, 2021 Author Report Posted May 27, 2021 Found a solution : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Ru8SAE&l=fr-FR Luckily, my colleague has the same laptop with similar NI softs installed so he sent me his tdtable.tdr file and then it all works fine again. 1 Quote
