Antoine Chalons Posted July 27, 2021 Report Share Posted July 27, 2021 This is not a montage. This VI was running and giving expected results. I suspect the malleable VI (Get config section from TOML file) to be somehow responsible for this visual artifact. After hitting ctrl + B, the broken parts of the wires were removed, I reconnected and that's it. Is this a known issue ? LV2020 v20.0.1 Quote Link to comment
Francois Normandin Posted July 27, 2021 Report Share Posted July 27, 2021 I'm pretty sure I reported something along those lines during beta testing of LV2020, but it was, if memory serves well, when using malleable with interfaces. Quote Link to comment
ThomasGutzler Posted July 28, 2021 Report Share Posted July 28, 2021 At least you get broken wires. Have you tried quick-drop replacing a vi with a vim that has a different connector pane? The wires just connect to nothing, don't break and there's no indication that anything went wrong until you try to build it. Kwality Quote Link to comment
JKSH Posted July 28, 2021 Report Share Posted July 28, 2021 53 minutes ago, ThomasGutzler said: Have you tried quick-drop replacing a vi with a vim that has a different connector pane? The wires just connect to nothing, don't break and there's no indication that anything went wrong until you try to build it. Kwality Ouch. Can you please wave this in NI's face? https://forums.ni.com/t5/LabVIEW-2021-Public-Beta/bd-p/labview-2021-beta Quote Link to comment
ThomasGutzler Posted July 29, 2021 Report Share Posted July 29, 2021 Mh, looks like that was a problem I remember from 2018 Quote Link to comment
G-CODE Posted July 31, 2021 Report Share Posted July 31, 2021 Same thing just happened to me in LabVIEW 2020. It's the malleable VI with the broken wire. Quote Link to comment
