Taylorh140 Posted August 17, 2021 Report Share Posted August 17, 2021 It just so happens that sometimes I am suppose to reproduce a test system made by a customer. There may have been an installer at one point but no-one knows anymore and they don't want to share the source vis. In the past i have download each NI library installed on that particular PC and installed it on the other until i get it all to play nicely. However it takes some time and is quite tedious. Is this the only way? Quote Link to comment
Antoine Chalons Posted August 18, 2021 Report Share Posted August 18, 2021 I've been there a few times. The treasure hunt is not really fun. 2 suggestions : - if MAX is installed, you can see from there the NI drivers - and versions - installed, that's a good starting point. Careful though, if it's installed doesn't mean it's required for the application to run. - if MAX is not installed, I would go to the uninstall utility of Windows and select National Instruments Software, this will launch the uninstall utility of NI, it displays everything installed Also, you say the customer doesn't want to share the source, but if they have it, maybe you can tell them how to get the information you need. Quote Link to comment
JKSH Posted August 18, 2021 Report Share Posted August 18, 2021 2 hours ago, Antoine Chalons said: - if MAX is not installed, I would go to the uninstall utility of Windows and select National Instruments Software, this will launch the uninstall utility of NI, it displays everything installed If it's a new-ish installation, the uninstall utility is replaced by NIPM. But that does also provide a comprehensive list of installed NI software. Quote Link to comment
FantasticNerd Posted August 19, 2021 Report Share Posted August 19, 2021 On 8/17/2021 at 5:04 PM, Taylorh140 said: and they don't want to share the source vis. And they are aware that you will need more time for that? Are you payed on an hourly basis? Is there a rational why they do not want to share the source code? Is an NDA possible so that they can share the source code? Quote Link to comment
Taylorh140 Posted August 24, 2021 Author Report Share Posted August 24, 2021 @FantasticNerd I don't make the rules, as far as this particular situation I can only speculate why. I would guess NDA would be required as well as other complicated approvals. In this case we are requesting a installer/setup procedure. but these things take time, in the meanwhile we are limited in testing. It's great the MAX/NIPM have a list of installed stuff. This is typically where i start too. Now wouldn't it be nice if NI just had a utility that looked at the exe, and made an installer that had all the components :). Quote Link to comment
FantasticNerd Posted August 30, 2021 Report Share Posted August 30, 2021 On 8/24/2021 at 6:21 PM, Taylorh140 said: Now wouldn't it be nice if NI just had a utility that looked at the exe, and made an installer that had all the components :). I do not think there is any company that will provide you with a tool to scan the Executable you build. Could something similar exist for a C++ or C# Application? Like scan the Application wich DLLs and Libraries are used? I don't think so, to be honest. Quote Link to comment
