[CR] Array Point to RowCol
index.php?automodule=downloads&req=display&code=sst&id=11
File Name: Array Point to RowCol
File Submitter: dsaunders
File Submitted: 3 Aug 2006
File Updated: 22 Oct 2006
File Category: User Interface
Converts a pixel coordinate to an array index. Returns an array of indices with a length equal to the number of array dimensions. Also returns if the point is within the content rectangle (not on the caption, scrollbars, etc.)
Works on any N-dimensional array regardless of visibility of caption, label, index display, or scrollbars. Designed to be used on mouse events that provide the mouse coordinates.
Limitations: Property nodes do not indicate the array border width, nor if the user has chosen to display an element gap. These inputs are thus provided on the VI.
David,
Great VI!
One comment: I think that the GObj.OwningVI property generates (opens) a new VI reference and should therefore be closed, after one's done using it.
Cheers,
-Jim
  Jim Kring said:
David,
Great VI!
Cheers,
-Jim
Good eye. I had a subVI to handle the panel defer, and obviously didn't check the new code quite enough. I will update the VI.
David Saunders
  • 14 years later...
Oh boy 2006, I think that predates the LAVA 1.0 migration issues, and then several other newer revamps.  I certainly don't have this, and have no way of getting something so old.  I can contact Michael if you'd like.
