Norm Kirchner Posted January 23, 2007 Report Posted January 23, 2007 File Name: Tree Control APIFile Submitter: njkirchner File Submitted: 10 Jan 2007 File Category: User Interface Description {Almost}Everything you every wanted out of the tree control but were too afraid to build. Provides extended/smart/wrapped functionality of the tree control. Functions Add Item Modify Item Remove Item Get All Items Get Top Level Items Get Items Parent Get Selected Item Get Siblings Get Children Get Item Properties Check Tag Valid Convert Tag to Text Find Tag from Text Outdent at Item Indent At Item Expand Collapse Empty Tree Notes Capable of working w/ LV 7 or later but uploaded version is for LV 8.2. Please request previous version if necessary. Good to recognize that the tree control is just a fancy multi-column listbox. Version 1.0.0 Initial Release 1.0.1 Example program added Click here to download this file Quote
Dave Graybeal Posted January 23, 2007 Report Posted January 23, 2007 I would just like to say thanks! These VI's are going to help ease the pain of working with Tree Controls. Tree Controls are great, but where a bit messy to get everything into and out of. This set of VIs (although I haven't put them to use yet) are going to make using Tree Controls much cleaner. Edit: I also just noticed the INI Viewer. Very handy little tool! Even if someone isn't looking for a way to make working with Tree Controls easier, they might be interested in checking out this tool. Thanks, Dave Graybeal Quote
JDave Posted January 23, 2007 Report Posted January 23, 2007 Very very very very nice. These will be very nice. I am finishing up an app that is built around a tree and could have used many of these. Thanks for the contribution. David Quote
LAVA 1.0 Content Posted January 23, 2007 Report Posted January 23, 2007 Provides extended/smart/wrapped functionality of the tree control. Sounds good! A few comments: The VIs should not be read-only, LabVIEW needs to be able to recompile the VIs when you upgrade to newer version of LabVIEW and occasionally when there is something weird going on in your project. Ability to add custom icons would be super! The LGPL license is viral in LabVIEW, meaning that if I use your library in my application it forces my application to ship under LGPL license. Could you consider licensing your package under EPL/MLP/GPL/LGPL multi-license. See thread Open Source Licensing of LabVIEW Packages for more information. jimi Quote
crelf Posted January 23, 2007 Report Posted January 23, 2007 3. The LGPL license is viral in LabVIEW, meaning that if I use your library in my application it forces my application to ship under LGPL license. Could you consider licensing your package under EPL/MLP/GPL/LGPL multi-license. See thread Open Source Licensing of LabVIEW Packages for more information. Or BSD... Quote
LAVA 1.0 Content Posted January 23, 2007 Report Posted January 23, 2007 Or BSD... Yes :thumbup: Quote
Jim Kring Posted January 23, 2007 Report Posted January 23, 2007 Jimi (and others) FYI, I've added some links in a reply to the licensing post. Thanks, Quote
i2dx Posted January 24, 2007 Report Posted January 24, 2007 Or BSD... sorry, this somewhat of a cross post, but what is wrong with the Creative Commons license? I spread all my *open source work* with this license ... Quote
LAVA 1.0 Content Posted January 24, 2007 Report Posted January 24, 2007 sorry, this somewhat of a cross post, but what is wrong with the Creative Commons license? I spread all my *open source work* with this license ... To avoid cross posting, see my answer here. Quote
Bobillier Posted January 24, 2007 Report Posted January 24, 2007 Hi You Said: Notes Capable of working w/ LV 7 or later but uploaded version is for LV 8.2. Please request previous version if necessary. Please is it possible to have a 7.0 version. :thumbup: Regards Quote
smcnally Posted February 7, 2007 Report Posted February 7, 2007 Very nice tool. I was wondering if you thought about handling multiple layers of children as well as reading and writing symbol index to ini file as well as multiple column information vs. just column index 1. Thanks Steve M. Quote
Norm Kirchner Posted February 7, 2007 Author Report Posted February 7, 2007 Sounds good! A few comments:The VIs should not be read-only, LabVIEW needs to be able to recompile the VIs when you upgrade to newer version of LabVIEW and occasionally when there is something weird going on in your project. Ability to add custom icons would be super! The LGPL license is viral in LabVIEW, meaning that if I use your library in my application it forces my application to ship under LGPL license. Could you consider licensing your package under EPL/MLP/GPL/LGPL multi-license. See thread Open Source Licensing of LabVIEW Packages for more information. jimi Ok, Sorry about not getting to this posting sooner. I didn't Know it existed {never got notification}. But on a few of your points. 1.The VIs are read only because I built the zip from VIs that are in source control {uses read only to handle checking in and out} so feel free to do a change all once unzipped 2. Custom Icons??? once you change the VIs from read only, change whatever you want 3. I thought the LGPL would let you do whatever you wanted, I'll follow the recommendations of the group to make them as usable as possible. Also to all of you, Thank you for the kudos. This toolkit is my baby and I'm glad you all like it. Be careful w/ the INI viewer though, it's been a while and I know that it hasn't gone through a ton of debugging and I don't want to mess up any of your INI by accident. Very nice tool. I was wondering if you thought about handling multiple layers of children as well as reading and writing symbol index to ini file as well as multiple column information vs. just column index 1.Thanks Steve M. Well when it comes to the INI viewer, it's meant to handle standard INI. It was never used extensively, but rather as a proof of concept and an excuse to use the tree. So in a standard INI there are only 1 layer of children. Feel free to extend the capability and post it back here. I'll modify the zip if it looks like they're good changes HiYou Said: Notes Capable of working w/ LV 7 or later but uploaded version is for LV 8.2. Please request previous version if necessary. Please is it possible to have a 7.0 version. :thumbup: Regards I know that some minor changes have been made since the 7.0 version so I can't vouch for their absolute sameness, but they all use the same connector pane and operate really close, so they should be forward compatible if you upgrade. Give me a few days to get to posting it, but I'll dig um up. Quote
Tomi Maila Posted February 7, 2007 Report Posted February 7, 2007 2. Custom Icons??? once you change the VIs from read only, change whatever you want You misunderstood me. The elements in a tree can have icons in a similar way as each item in LabVIEW 8.0 and later project explorer has icons. The addition of icons using the property nodes is somewhat complicated and therefore it would be nice if there was a simple way to specify an icon of an item. BSD license would be super! I think crelf and Jim Kring agree with me on this. Quote
Norm Kirchner Posted February 7, 2007 Author Report Posted February 7, 2007 You misunderstood me. The elements in a tree can have icons in a similar way as each item in LabVIEW 8.0 and later project explorer has icons. The addition of icons using the property nodes is somewhat complicated and therefore it would be nice if there was a simple way to specify an icon of an item.BSD license would be super! I think crelf and Jim Kring agree with me on this. For the Item symbols ('icons') you can use the modify item call, and I think you just need to re-define what the icon at an index is from another function, which, i'm assuming this is what you want, I don't have. I'll look into it though, as I have thought about it before myself too. Quote
crelf Posted February 7, 2007 Report Posted February 7, 2007 BSD license would be super! I think crelf and Jim Kring agree with me on this. Sure do :thumbup: Quote
Tomi Maila Posted February 7, 2007 Report Posted February 7, 2007 For the Item symbols ('icons') you can use the modify item call, and I think you just need to re-define what the icon at an index is from another function, which, i'm assuming this is what you want, I don't have. No, I don't want to know anything about icon indices. I just would like to add a new item to the tree and specify that this item icon is defined by this image data and the tree control would check if that icon is already used in the tree and if not then add it to one of the icons and then set the icon index of the current icon properly. Quote
