Dragging graphs out of a listbox...
Nice.
If you replace the OpenG VI with the above then we don't need to install all those dependencies for your demo ;)
What do you expect the cancellation behviour to be? Press escape while holding the mouse down? Mouse up cancels unless the dragged window is outside the main window? Both? Something else?
I wouldn't want this feature to be a "framework" though. It would need to be much easier than that. Maybe a VI that accepts  control references and it just works like above on those controls?
Edited by ShaunR
1 hour ago, ShaunR said:
Nice.
Ah, yes, thanks. The attachment in the original post is now without the OpenG dependency and has been converted back to LabVIEW 2018.
I did do something similar years ago and posted the code here.  With a youtube link demoing the graph functions.  I never actually used it on a real project but put some decent time into the UX.  It also allows for dragging out the graph into a new semi transparent window.  It is not a generic framework, and mostly a proof of concept that could be used in an application, if you don't mind the various limitations, and restrictions.
