Sort (search) Array of cluster by one cluster element
Hi all
I want to find the best way to sort (search) array element of cluster by one of the element of this cluster. and obtain a array of index .
Actualy the search element of openg do that for a cluster elemnt but not for element of cluster.
I want a generic solution and thinking pass by variant, but i have look around and a bit lost my latin ;-).
Please show me draw and don't send me directely VI because y work on 7.0 and can't open higher.
thanks
QUOTE(Michael_Aivaliotis @ Jun 25 2007, 10:16 AM)
you can avoid the search if you just want to sort.
Well...you learn something new every day. I had no idea that "Sort 1D Array" will compare the first element of a cluster when sorting an array of clusters. :book:
Thanks for the tip, Michael! :thumbup:
QUOTE(orko @ Jun 25 2007, 01:21 PM)
Well...you learn something new every day. I had no idea that the "Sort 1D Array" will compare the first element of a cluster when sorting an array of clusters.
and....
if your cluster have arrays, it will sort them as well.
Tie-breakers use the second element of the cluster and so on....
Ben
QUOTE(Ben @ Jun 25 2007, 10:24 AM)
and....
This had me blinking :blink: until I realized you meant "if your cluster have arrays, it will sort by them as well." I couldn't figure out how the sort 1D array was going to sort arrays inside an array of clusters. :wacko:
That's pretty cool though. I just tried it out and sure enough, with an array as the first element in the cluster, the sort will sort by the array's first element, then second, and so on. Thanks for this tidbit as well!
QUOTE(Michael_Aivaliotis @ Jun 25 2007, 10:45 AM)
Btw, I really don't like that yellow background on the diagram. It doesn't feel right. Or is it just a side effect of the gif transform?
Hehe... well, it's both actually. The yellow that I have on my BD is a lot lighter, almost white but just enough of a tone to not blind me when I open up my code in a dark environment. I'm one of those that is accustomed to black-lit workspaces. Comes from long hours as a web developer at eAcceleration, where flourescent lighting was an evil demon that drained the lifeforce from you after 18 hours of crunch time coding. I worked in an area that we dubbed "The Dark Side" :ninja:
I'm pretty sure that OpenG has some better array sorting/searcing VIs that let you pass in a VI Server reference to do the comparison, so you just write a compare function that compares the desired element of the cluster and returns greater, equal or less. I saw something like that on Jim Kring's screen when he won the LV speed programming competition at NI Week a couple years ago.
  • 18 years later...
Any chance if this exists now after decades of this thread? I'm looking for best way to search 1D array of cluster that has numerous items.. I need to specify type of element in clusters I need to filter out.
You want an ability to override the Equality or Comparison operators? I'm unsure, whether it really existed in OpenG packages, but now you have those neat malleable VIs, that let you do that: Search Unsorted 1D Array , Sort 1D Array , Search Sorted 1D Array. They have an additional input to specify your own equals or less function in a form of a custom comparison class or a VI refnum. There's an article to help: Creating a Custom Sorting Function in LabVIEW
  • Like 2
