zoogies Posted June 26, 2007 Report Posted June 26, 2007 I do this a lot: have some messy, ugly, or tangled wires running together, and going through each one, right clicking, and pressing "clean up." Is there a shortcut for this, or better yet, a "clean all wires" shortcut? Thanks! Quote
Aristos Queue Posted June 26, 2007 Report Posted June 26, 2007 QUOTE(zoogies @ Jun 25 2007, 01:11 PM) I do this a lot: have some messy, ugly, or tangled wires running together, and going through each one, right clicking, and pressing "clean up." Is there a shortcut for this, or better yet, a "clean all wires" shortcut? No. And you're not the only one who wishes for such a tool. Quote
PJM_labview Posted June 26, 2007 Report Posted June 26, 2007 QUOTE(Aristos Queue @ Jun 25 2007, 11:19 AM) No. And you're not the only one who wishes for such a tool. Actually there is one I wrote in 2004. It is available on http://forums.ni.com/ni/board/message?board.id=170&message.id=79506&query.id=716773#M79506' target="_blank">NI forum (Eventhough I though I post it on LAVA too, I was unable to find it). Note: Since that time, a lot of new class of objects have been added to LabVIEW. Therefore it might not work as well on LV 8.x (for example finding wire in flat sequence, disable structure or the like will most likely fail). PJM Quote
Jim Kring Posted June 26, 2007 Report Posted June 26, 2007 QUOTE(PJM_labview @ Jun 25 2007, 11:55 AM) Actually there is one I wrote in 2004. It is available on http://forums.ni.com/ni/board/message?board.id=170&message.id=79506&query.id=716773#M79506' target="_blank">NI forum (Eventhough I though I post it on LAVA too, I was unable to find it).Note: Since that time, a lot of new class of objects have been added to LabVIEW. Therefore it might not work as well on LV 8.x (for example finding wire in flat sequence, disable structure or the like will most likely fail). PJM You can (and should) use the built-in traversal VI for obtaining all Wire references: <LabVIEW>\vi.lib\Utility\traverseref.llb\TRef Traverse for References.vi This is updated by NI and will (should) work for any new obj types introduced to LabVIEW. -Jim Quote
gb119 Posted June 27, 2007 Report Posted June 27, 2007 QUOTE(zoogies @ Jun 25 2007, 07:11 PM) I do this a lot: have some messy, ugly, or tangled wires running together, and going through each one, right clicking, and pressing "clean up." Is there a shortcut for this, or better yet, a "clean all wires" shortcut?Thanks! <plug mode="own code"> The http://forums.lavag.org/downloads-file87.html' target="_blank">Scripting Tools toolkit in the code repository has, as an example, a little program that can be put into your project folder that will find all wire references and run the clean-up wire method on them. The toolkit is LV 8.2, so if you're using 8.0 then it's not much use to you. </plug> Quote
orko Posted June 27, 2007 Report Posted June 27, 2007 Here's a utility that uses scripting in 8.x to perform the cleanup wires using two core VIs located in the "<LabVIEW>\vi.lib\Utility" directory. Details on those two VIs: "allVIsInMemory.llb\Get User Application Reference.vi" gets the application reference of the launching VI using the output of the "App.MenuLaunchVI" scripting property node. "traverseref.llb\TRef Traverse for References.vi" gets all of the object references in the VI to search for wires. I couldn't get the "scripting tools:Get all Objects.vi" to work in LV 8.2.1. It would gather objects, but probing into it on my system I found that it couldn't find any wires. Not sure why, but Jim Kring pointed out that the traverseref.llb VIs were updated by NI and that one seemed to work fine for me in both LV 8.0.1 and LV8.2.1. I put the following VI into my <LabVIEW>/project directory in LV 8.0.1 and LV 8.2.1 and it shows up in the "Tools" menu as "Clean Up Wires...". Let me know how this works for you* http://forums.lavag.org/index.php?act=attach&type=post&id=6235 (LV8.0.1) *note: I couldn't figure out how to set the docmods so that LabVIEW would know that the VI had changed (hence prompting for a save on close) after this VI executes. Can anyone help me out with that? Quote
orko Posted June 29, 2007 Report Posted June 29, 2007 UPDATE: -------- I've fixed the "Clean Up Wires.vi" utility so that it works with Undo and records modifications on the BD (prompts for save). I'm unsure though whether the desired undo behavior would be to undo each wire individually or to undo the whole cleanup in one shot. The current version works on each wire individually. http://forums.lavag.org/index.php?act=attach&type=post&id=6248 (LV8.0.1) Quote
Rolf Kalbermatter Posted June 29, 2007 Report Posted June 29, 2007 QUOTE(orko @ Jun 27 2007, 06:44 PM) UPDATE:-------- I've fixed the "Clean Up Wires.vi" utility so that it works with Undo and records modifications on the BD (prompts for save). I'm unsure though whether the desired undo behavior would be to undo each wire individually or to undo the whole cleanup in one shot. The current version works on each wire individually. Each wire individually doesn't sound intuitive to me. Usually every user action is considered an Undo Transaction and selecting your wiring cleaner tool in the menu would seem to me one single user action. Imagine your tool doing 500 wire modifications and then the user realizes he wants to undo the operation just before he selected your tool. Ouch!!!!!! Rolf Kalbermatter Quote
gb119 Posted June 29, 2007 Report Posted June 29, 2007 QUOTE(orko @ Jun 26 2007, 11:19 PM) I couldn't get the "scripting tools:Get all Objects.vi" to work in LV 8.2.1. It would gather objects, but probing into it on my system I found that it couldn't find any wires. Not sure why, but Jim Kring pointed out that the traverseref.llb VIs were updated by NI and that one seemed to work fine for me in both LV 8.0.1 and LV8.2.1.I put the following VI into my <LabVIEW>/project directory in LV 8.0.1 and LV 8.2.1 and it shows up in the "Tools" menu as "Clean Up Wires...". Let me know how this works for you* http://forums.lavag.org/index.php?act=attach&type=post&id=6235''>http://forums.lavag.org/index.php?act=attach&type=post&id=6235'>http://forums.lavag.org/index.php?act=attach&type=post&id=6235 (LV8.0.1) Ah, yes. I had a slight failure to engage brain when I wrote my version. It'll be fixed in the next release of the Scripting Tools (a Wire is a GObject, but isn't returned by the All Objects[] method of the Diagram class...). Using the Traverse for References is neater in many ways I suspect, but why not ask Traverse for References just to return Wire class references, rather than GObjects and then filtering as at present ? Quote
orko Posted June 29, 2007 Report Posted June 29, 2007 QUOTE(rolfk @ Jun 28 2007, 01:57 AM) Imagine your tool doing 500 wire modifications and then the user realizes he wants to undo the operation just before he selected your tool. Ouch!!!!!! Quite true! I've changed the behavior to undo all wire cleanups with a single undo. QUOTE(Gavin Burnell) Using the Traverse for References is neater in many ways I suspect, but why not ask Traverse for References just to return Wire class references, rather than GObjects and then filtering as at present ? Good point! I've changed this over to just extract wire references from the BD. Here is the latest version: http://forums.lavag.org/index.php?act=attach&type=post&id=6257''>http://forums.lavag.org/index.php?act=attach&type=post&id=6257'>http://forums.lavag.org/index.php?act=attach&type=post&id=6257 (LV8.0.1) Quote
