Kiven Jia Posted November 24, 2025 Report Posted November 24, 2025 Hi Team, I'm trying to hide a line of text by setting its height to 0, but when I do, the text is still visible on the control. Is there a better way to solve this problem? The reason I don't want to update the item Names is that I think it might be inefficient. Thanks and looking forward to your best practices. Quote
hooovahh Posted November 24, 2025 Report Posted November 24, 2025 I don't know of a way to remove these lines. The best solution is the one you probably already know, and that is to show all rows like normal, but then delete the data from being written. I have a similar issue in cases where I want to hide columns. Quote
Mads Posted November 24, 2025 Report Posted November 24, 2025 Generate a worst case list and update it at the (truly) necessary rate, with panel updates deferred while you are doing your required changes (if more than one property change is needed). If it runs fine, you saved yourself a premature optimization...If it does not look good, reevaluate if the update rate and list size is really required... Quote
Kiven Jia Posted November 25, 2025 Author Report Posted November 25, 2025 Thanks for the replies from both of you. And also helped me confirmed that I'm not miss something I don't know. Quote
