Control look out: Classic<->Modern style
Hello, I wish I can change the look out style of FP elements.
E.g. I created a modern cluster or array and want to change it to classic style and make than boarders transparent.
Eugen
QUOTE(Tomi Maila @ Sep 4 2007, 05:22 PM)
You mean you want to do this manually for some VIs or automatically for a large number of VIs?
Yes, manually. I know I can use Control->Replace and then replace my modern object to a classic. But it doesn't work for clusters and arrays. Furthermore if I replace a object to any other, then the new loses properties, like formatting.
Eugen
You can make the borders of 3D structures transparent:
  1. Right click on the border using the paint tool.
  2. Hover on top of the T color.
  3. Press the space bar a couple of times. This alternates between foreground and background color. One of these should make the border transparent.
You could probably also do the programmatic replacing - there is a Control class (private) method which allows you to replace a control with another one, but I believe it suffers from the same problems you mentioned with the manual replace.
What I would probably do about that is use KShif's property saver to transfer the properties (although I don't know if it would handle all kinds of objects) and replace the controls inside the arrays and clusters instead of the arrays and clusters themselves.
QUOTE(yen @ Sep 5 2007, 08:29 PM)
Can you post an example of completely transparent 3D Cluster (no borders and no shadow must be visible) here? Please. I don't think it's possible.
Sorry, I don't love/use private methods and properties.
That is too difficult for this. I wish it would be implemented in LV, like:
rightklick on
Control->Control Style->Classic
->Modern
->System (optional, if possible)
Eugen
QUOTE(Eugen Graf @ Sep 5 2007, 09:57 PM)
Can you tell the difference between a completely transparent modern cluster and a completely transparent classic cluster? :blink:
Anyway, attached is a VI with a transparent modern cluster, created using the simple method I explained. There's also a modern numeric, just to make it more obvious, so that you'll believe me that it is possible.
QUOTE
LV
like, rightklick on
->Modern
Sounds like a reasonable idea. Why not submit it to NI's product suggestion center?
QUOTE(Eugen Graf @ Sep 4 2007, 05:42 PM)
Even if this is solved for the simple task of making a transparent cluster, I'd still like to have a "change control style" option to change the style of controls on a front panel.
This would be very usefull for the cases when I want to use a VI from a 3D-style-project inside a system-style-project.
I'm not only thinking about complex clusters, even a simple numeric control contains lots of configuration data. If you are tweaking all the tabs in the properties dialog (which I usually do for real world user interface panels), you have to set all those properties again for the replacement control. This is a very time-consuming task compared to the simple wish "I want to change what the control looks like".
