ecarrig Posted September 18, 2007 Report Share Posted September 18, 2007 hello, I'm having trouble getting the "Time" label on the x-axis of a series of waveform graphs to read "Time [sec]". I'm not married to this particular approach, but I need to do something like this so that screenshots generated for our customers will have the appropriate units. I believe the best way to change this is by writing "Time [sec]" to a property node of the graph. I'm pretty sure I have the right varible (see post title). I can get the desired effect to work on toy examples, but when I try this tactic in a real program it doesn't work. I have placed them in and outside of a flat sequence which is the major structure of the VI. No errors... but nothing happens and I still have "Time" along the bottom of my graph... any ideas? thanks Eamon Quote Link to comment
LAVA 1.0 Content Posted September 18, 2007 Report Share Posted September 18, 2007 Please place a screen shot of the portion of code you have that you state is not working. Quote Link to comment
MikaelH Posted September 18, 2007 Report Share Posted September 18, 2007 You're using the right property node! Try taking the working graph in your Toy Example, and copy the graph and replace it with the one in your main application. //Mikael Quote Link to comment
Ton Plomp Posted September 19, 2007 Report Share Posted September 19, 2007 Multiple XScales? Are you sure it's the XScale label that's shown in the real program (and not some static text) Ton Quote Link to comment
ecarrig Posted September 21, 2007 Author Report Share Posted September 21, 2007 Thanks for looking. I've included a few screenshots... one of the working toy example and one of the same code (i think ) that does not work in a flat sequence in my larger program. The function of this VI is to open an .lvm file, process it, and display the important data. Interestingly enough, I ran the program once with a bad .lvm file and the poperty node worked fine -- the graph read time [sec]. I am forced to conclude that somehow opening an .lvm file trumps redefining the property node, regardless of where the property node gets redefined. thanks Eamon Quote Link to comment
Grampa_of_Oliva_n_Eden Posted September 21, 2007 Report Share Posted September 21, 2007 QUOTE(ecarrig @ Sep 20 2007, 11:33 AM) Thanks for looking. I've included a few screenshots... one of the working toy example and one of the same code (i think ) that does not work in a flat sequence in my larger program. The function of this VI is to open an .lvm file, process it, and display the important data. Interestingly enough, I ran the program once with a bad .lvm file and the poperty node worked fine -- the graph read time [sec]. I am forced to conclude that somehow opening an .lvm file trumps redefining the property node, regardless of where the property node gets redefined. thanks Eamon Right-click on the graph and make sure the graph is set to "ignore attributes". Ben Quote Link to comment
LAVA 1.0 Content Posted September 21, 2007 Report Share Posted September 21, 2007 QUOTE(Ben @ Sep 20 2007, 10:40 AM) Right-click on the graph and make sure the graph is set to "ignore attributes".Ben Nice find Ben. I haven't worked w/ the dynamic type much, but I have experienced the struggle w/ the waveform attributes once or twice. I suppose another option for him would be to just change the attribute rather than the property, no? Quote Link to comment
Grampa_of_Oliva_n_Eden Posted September 21, 2007 Report Share Posted September 21, 2007 QUOTE(NormKirchner @ Sep 20 2007, 11:47 AM) Nice find Ben. I haven't worked w/ the dynamic type much, but I have experienced the struggle w/ the waveform attributes once or twice. I suppose another option for him would be to just change the attribute rather than the property, no? I don't use them either. I am just guessing based on the symptoms matching what I have seen using the waveform data types. You are probably correct. Ben Quote Link to comment
ecarrig Posted September 21, 2007 Author Report Share Posted September 21, 2007 that looks like it worked! thankyou very much Quote Link to comment
Grampa_of_Oliva_n_Eden Posted September 21, 2007 Report Share Posted September 21, 2007 QUOTE(Ben @ Sep 20 2007, 11:56 AM) I don't use them either.I am just guessing based on the symptoms matching what I have seen using the waveform data types. You are probably correct. Ben On a realted note.... Does the LAVA Tips and tricks mention that a WF data typed chart will plot points based on the t0 values? This allows non-periodic plotting. And similarly, an empty Y array of the WF will be ignode, and also a "NaN" will break the plot line. If not, you have been un-officially informed. Ben Quote Link to comment
