thevoiceover Posted October 4, 2007 Report Share Posted October 4, 2007 I am curious on if anyone has anything that could convert HSL to RGB for me that I could run in some LabVIEW code.. I could have sworn I had a .dll way back that did this, but I can't find it... I couldn't find anything in LV that did this either... I am running 7.1.1 Quote Link to comment
siva Posted October 5, 2007 Report Share Posted October 5, 2007 QUOTE(thevoiceover @ Oct 4 2007, 12:48 AM) I am curious on if anyone has anything that could convert HSL to RGB for me that I could run in some LabVIEW code.. I could have sworn I had a .dll way back that did this, but I can't find it... I couldn't find anything in LV that did this either... I am running 7.1.1 You could build your own .dll or SubVI using the standard conversion formula available at, http://en.wikipedia.org/wiki/HSL_color_space Quote Link to comment
Neville D Posted October 5, 2007 Report Share Posted October 5, 2007 There are functions in the IMAQ Vision tool-kit from NI that allow you to do that and much more. It is expensive, though. Neville. Quote Link to comment
thevoiceover Posted November 1, 2007 Author Report Share Posted November 1, 2007 QUOTE(Neville D @ Oct 4 2007, 10:54 AM) There are functions in the IMAQ Vision tool-kit from NI that allow you to do that and much more. It is expensive, though.Neville. Yes and I am broke.... Oh well.. Quote Link to comment
PJM_labview Posted November 1, 2007 Report Share Posted November 1, 2007 QUOTE(thevoiceover @ Oct 30 2007, 03:51 PM) Yes and I am broke.... Oh well.. Use the following code to write your own "HSL to RGB.vi" in LabVIEW. It does not take that long. /****************************************************************************** FUNCTION: HLStoRGB PURPOSE: Convert from HSL to RGB IN: Hue, Saturation, Luminance from 0 to 1 RETURN: RGB color (0xRRGGBB) COPYRIGHT:1995-1997 Robert Mashlan Modified for LabWindows/CVI, 1999 Guillaume Dargaud ******************************************************************************/ typedef unsigned char BYTE; // 8-bit unsigned entity COLORREF HLStoRGB(const double H, const double L, const double S ) { double r,g,b; double m1, m2; if (S==0) r=g=b=L; else { if (L <=0.5) m2 = L*(1.0+S); else m2 = L+S-L*S; m1 = 2.0*L-m2; r = HueToRGB(m1,m2,H+1.0/3.0); g = HueToRGB(m1,m2,H); b = HueToRGB(m1,m2,H-1.0/3.0); } return MakeRGB((BYTE)(r*255),(BYTE)(g*255),(BYTE)(b*255)); }/****************************************************************************** FUNCTION: HueToRGB PURPOSE: Convert a hue (color) to RGB COPYRIGHT:1995-1997 Robert Mashlan Modified for LabWindows/CVI, 1999 Guillaume Dargaud******************************************************************************/static double HueToRGB(const double m1, const double m2, double h ) { if (h<0) h+=1.0; if (h>1) h-=1.0; if (6.0*h < 1 ) return (m1+(m2-m1)*h*6.0); if (2.0*h < 1 ) return m2; if (3.0*h < 2.0) return (m1+(m2-m1)*((2.0/3.0)-h)*6.0); return m1;} PJM Quote Link to comment
Tim_S Posted November 10, 2007 Report Share Posted November 10, 2007 This what you're looking for? QUOTE(thevoiceover @ Oct 3 2007, 02:18 PM) I am curious on if anyone has anything that could convert HSL to RGB for me that I could run in some LabVIEW code.. I could have sworn I had a .dll way back that did this, but I can't find it... I couldn't find anything in LV that did this either... I am running 7.1.1 Quote Link to comment
