Shift register terminals as default for error clusters and reference
QUOTE(Tomi Maila @ Nov 20 2007, 03:46 AM)
When wiring error into a loop, the most common use case is to have a shift register to pass the error from iteration to iteration. Hence shift registers should be the default terminal type for error clusters when wired to a loop.
And refnums, too :)
And refnums, too :)
And refnums, too :)
QUOTE(Jim Kring @ Nov 21 2007, 07:00 AM)
And refnums, too :)
But refnums of cause only need a shift register when you're using a for loop (to solve the issue when N=0).
//Mikael
And refnums, too :)
//Mikael
QUOTE(Jim Kring @ Nov 20 2007, 03:00 PM)
And refnums, too :)
Why would you need refnums to be shift registers? Unless you're closing the reference within the loop and replacing it with a not-a-refnum constant, I'd expect they would pass through a loop unmodified, and I don't think there would be a benefit to using a shift register over a tunnel (although I don't think there would be a disadvantage, either, which might be enough to make your point).
And refnums, too :)
QUOTE(ned @ Nov 20 2007, 10:17 PM)
Because if for loop is never executed (N=0), the reference is not passed trough the loop, but a default NULL reference is returned at the other end of the loop instead.
Tomi
Tomi
QUOTE(Tomi Maila @ Nov 20 2007, 03:21 PM)
Tomi
Ah, right. I've been bitten by that one before, and now my solution is usually to fork the wire outside the for loop.
Tomi
QUOTE(Tomi Maila @ Nov 20 2007, 12:46 PM)
EDIT: The same should apply for all reference types.
I agree absolutely.
Did you already suggest this on NI's site?
I agree absolutely.
QUOTE(ned @ Nov 20 2007, 03:17 PM)
Another reason (except the N=0 issue which I think was changed at some point around 7.x) is that wiring the refnum out of the loop defaults to autoindexing for the for loop which is almost never what it should do. Using shift registers solves that too.
I can't count how many times I've pointed out a tunneled error cluster in a co-worker's code and each time it's the same response -- "Ack! I forgot about that..."
The majority of times, a shift register is definitely the right choice, so I agree totally it should be the default.
PS. Sometimes I am the co-worker :laugh:
