Linear Actuator
Hansell
Actuators need a controller and an amplifier. LV communicates with the controller. I've used rotary actuators that had built-in controllers and amplifiers, but they were serial devices and a "driver" wasn't needed. I know a few of the bigger motion control companies (Aerotech, Parker) will sell you "Software Development Kits" :laugh: for LabVIEW if you are going the separate controller/amplifier route.
QUOTE (Hansell @ Jul 22 2008, 01:09 PM)
Try http://www.copleymotion.com/' rel='nofollow' target="_blank">Copley Motion? I've been controlling their stepper motor amplifiers through LabVIEW (they provide a free ActiveX component and LabVIEW examples). They work well in my application and were simple to set up. I haven't used their linear actuators but I'm willing to guess that they're equally easy to use.
What sort of force and frequency response are you after?
All the actuators I work with at work, are fed an analogue signal that controls the shuttle in the servo, A PID loop is then used to control the displacement or load.
Can you give a bit more information on the application?
QUOTE (Hansell @ Jul 22 2008, 07:09 PM)
http://www.maxonmotor.com/
Maxon has LabVIEW drivers for its drives RS232/CAN-bus
I used a maxon motor/drive with RS232 driver for a test bench - works great...
What is your application?
What do you need to do?
