John Lokanis Posted March 15, 2009 Report Posted March 15, 2009 Here is something that has bugged me for awhile: If I open a project and then open a VI that has a lot of sub-vis, it takes a very long time to open (many minutes). I can see the 'VI loading' dialog and it is iterating through the sub-vis at a rate of about 1 VI per second. Once the VI finally loads, I can close it and then reopen it and it opens in about 2 seconds. So, at first I thought it was cached on the second load and that is why it was fast. But, if I close the project and then reopen it, then load a simple VI with very few sub-VIs first, that VI will open fairly quickly. If I then try to open my big VI, it will also open quickly (in seconds). In fact, it opens so fast that I never see the 'VI loading' dialog at all. So, does anyone know what is going on here? This only happens if I load the VIs from a project. If I load them directly they open instantly. -John Quote
John Lokanis Posted March 25, 2009 Author Report Posted March 25, 2009 Am I the only one with this problem? Now I really feel alone... Quote
Rolf Kalbermatter Posted March 25, 2009 Report Posted March 25, 2009 QUOTE (jlokanis @ Mar 24 2009, 02:16 PM) Quote Am I the only one with this problem? Now I really feel alone... Anything special about your setup? Project or project VIs on a network drive? LabVIEW starting up from a network drive? It seems that there must be something like this. Something similar though not to LabVIEW only I see on my machine if I do not have a connection to my VPN server. Presumably because I have a path somewhere in the registry that points to a location on a shared drive only available when logged in through VPN. But Widnows seems to check that path anyhow everytime I click on a file in Explorer . It's annoying but not annoying enough to really dig through the registry to find the offending entry. Rolf Kalbermatter Quote
Neville D Posted March 25, 2009 Report Posted March 25, 2009 Do you have a lot of targets in your project? Where does it slow down in the loading? Your VI's or vi.lib VI's? N. Quote
Clio75 Posted March 25, 2009 Report Posted March 25, 2009 when I open the first VI it's slow. But I thing in my case its due to loading the visa resources(serial ports, GPIB to instruments, etc etc) The reason I thing this, is that this only apply to first VI that using visa. This was much faster in 8.6 that 7.0 Quote
John Lokanis Posted March 25, 2009 Author Report Posted March 25, 2009 No network drives. Local storage only. I am connected to version control (perforce). I do have a lot of .NET calls and I do use VISA in some places. Quote
mje Posted March 25, 2009 Report Posted March 25, 2009 I see this as well. I always attributed it to LabVIEW and/or the OS doing some caching. The effect is more pronounced when working off network drives, but locally there's still an observable difference. Quote
Aristos Queue Posted March 26, 2009 Report Posted March 26, 2009 My bet: Source code control and/or installed LV modules. The first time you open a VI in a project, if you have SCC enabled, all the SCC VIs that manage that connection load into memory and then stay there. The various LV modules (real-time, FPGA, PDA, etc) can also add plug-ins to the project that respond to the loading of VIs. Quote
LAVA 1.0 Content Posted March 26, 2009 Report Posted March 26, 2009 QUOTE (Aristos Queue @ Mar 25 2009, 01:13 AM) Quote My bet: Source code control and/or installed LV modules.The first time you open a VI in a project, if you have SCC enabled, all the SCC VIs that manage that connection load into memory and then stay there. Strange, I would expect that these loaded when a project is openend. Ton Quote
Aristos Queue Posted March 26, 2009 Report Posted March 26, 2009 QUOTE (Ton @ Mar 25 2009, 04:36 AM) Quote Strange, I would expect that these loaded when a project is openend. Why? There are various uses of the project, most notably building an app, that does not involve opening a VI (note I distinguish loading a VI vs opening a VI, since AppBuilder obviously must load VIs). The project loads the pieces it needs as it needs them. Quote
LAVA 1.0 Content Posted March 27, 2009 Report Posted March 27, 2009 QUOTE (Aristos Queue @ Mar 25 2009, 01:13 AM) Quote My bet: Source code control ..... QUOTE (Ton @ Mar 25 2009, 11:36 AM) Strange, I would expect that these loaded when a project is openend. QUOTE (Aristos Queue @ Mar 25 2009, 02:16 PM) Why? There are various uses of the project, most notably building an app, that does not involve opening a VI (note I distinguish loading a VI vs opening a VI, since AppBuilder obviously must load VIs). The project loads the pieces it needs as it needs them. Well all these nice overlay icons for SCC'd items are the reason why I would expect that SCC VIs load direcly upon opening a project. Ton Quote
Aristos Queue Posted March 27, 2009 Report Posted March 27, 2009 QUOTE (Ton @ Mar 26 2009, 03:07 AM) Quote Well all these nice overlay icons for SCC'd items are the reason why I would expect that SCC VIs load direcly upon opening a project. Some SCC VIs do load with the project, but not all. Those for status load immediately. Those for checking in/out wait until there's something open that you could edit. Quote
