Antoine Chalons Posted April 25, 2009 Report Posted April 25, 2009 Hi all, I've just upgraded from TortoiseSVN 1.6.0 to 1.6.1, then restarted my computer and now my windows explorer will take between 5 and 10 seconds just to open a folder... If then I open the task manager and kill the process "TSVNCache.exe" windows explorer goes back to normal speed. I started using TortoiseSVN only a month ago so I don't have alot of experience with it and I'm a bit scared now.. Anyone has the same behaviour ? Quote
jdunham Posted April 25, 2009 Report Posted April 25, 2009 QUOTE (Antoine Châlons @ Apr 24 2009, 01:12 AM) I've just upgraded from TortoiseSVN 1.6.0 to 1.6.1, then restarted my computer and now my windows explorer will take between 5 and 10 seconds just to open a folder...If then I open the task manager and kill the process "TSVNCache.exe" windows explorer goes back to normal speed. I started using TortoiseSVN only a month ago so I don't have alot of experience with it and I'm a bit scared now.. Anyone has the same behaviour ? I googled "tortoise 1.6.1 performance" and the mailing list archives from earlier this week show that there is some kind of problem with the latest build. You could either pitch in and help them debug it or else roll back to 1.6.0. I have used it for a couple years without any major problems. Long ago it was really slow, but then the cache was rewritten and it got a lot better (until last week, I guess). Anyway, don't give up! Quote
TobyD Posted April 25, 2009 Report Posted April 25, 2009 QUOTE (Antoine Châlons @ Apr 24 2009, 01:12 AM) I started using TortoiseSVN only a month ago so I don't have alot of experience with it and I'm a bit scared now.. Anyone has the same behaviour ? I'm still at 1.5.9, but thanks for the heads up! Quote
PaulG. Posted April 25, 2009 Report Posted April 25, 2009 From the downloads page: "We got reports that upgrading sometimes does not work properly. If you have problems after updating TortoiseSVN, just uninstall it, reboot, and then install it again." No thanks. :thumbdown: Quote
gmart Posted April 25, 2009 Report Posted April 25, 2009 Perforce has a plugin for Windows Explorer as well. It installs automatically. I now do not install it since one of the early releases had a problem hanging my computer when the server was down. Anything that integrates to Explorer that can connect to a remote server is asking for trouble in my book. Of course that's how Tortoise works (and has worked fine for many releases) but I'm still leery of Explorer plugins. Quote
PJM_labview Posted April 25, 2009 Report Posted April 25, 2009 I am still at 1.5.2. In the past I noticed that the cache will go crazy on occasion (especially when you have a lot of code in a folder). I always keep an handy shortcut to a bat file that has the following "taskkill /f /im TSVNCache.exe". Note: I don't believe I used this recently (for sure not in the last 6 months if not longer). Quote
crelf Posted April 25, 2009 Report Posted April 25, 2009 QUOTE (TobyD @ Apr 24 2009, 11:43 AM) I'm still at 1.5.9, but thanks for the heads up! Yeah - we're still on 1.5.9 for now - we upgraded to 1.6.0 a couple of months ago and had issues, so we rolled back. Quote
Yair Posted April 26, 2009 Report Posted April 26, 2009 QUOTE (gmart @ Apr 24 2009, 07:41 PM) Of course that's how Tortoise works It doesn't as far as I know. The cache is fully local (the code is always checked out and you have a local copy to revert to or diff against) and I assume TSVN doesn't attempt any sort of connection to the server until you initiate a relevant action. I didn't check this, but it makes sense and I never had a problem when working with my disconnected laptop. This local cache is one of the reasons I like Subversion so much, as it makes working with LabVIEW code very fast, as compared to VSS, for instance, and allows you to see the modified files immediately. Quote
Antoine Chalons Posted April 28, 2009 Author Report Posted April 28, 2009 I've uninstalled and re-installed TSVN 1.6.1 and it seems to be better. Once a while, when my windows explorer starts being slow I run a batch file containing this : @echo offtaskkill /f /im TSVNCache.exestart TSVNCache.exe and it's fine again. [EDIT] I'm just thinking now... maybe it's not really a good idea to do that.. anyone knows if it could affect the operation of TVSN and screw things around? Quote
jdunham Posted April 28, 2009 Report Posted April 28, 2009 QUOTE (Antoine Châlons @ Apr 27 2009, 05:17 AM) I'm just thinking now... maybe it's not really a good idea to do that.. anyone knows if it could affect the operation of TVSN and screw things around? I suspect you are fine. AFAIK, TSVNCache is just a performance enhancement. It's job is to keep all the SVN glyphs on your icons accurate, so that if you change one file five subfolders down, then all if its parents in any open Explorer window will change their glyphs to show they've been modified. It's all about the icons and has nothing to do with your data or your working copy except for monitoring the status. I don't see how killing it could cause any problem except the icons are slower to update or fail to refresh themselves. Quote
PJM_labview Posted April 28, 2009 Report Posted April 28, 2009 I agree with Jason, there is no harm in doing this. By the way I believe the TSVNcache restart itself automatically (at least for me it does) so I think you can drop the "start TSVNCache.exe". PJM Quote
armin Posted April 30, 2009 Report Posted April 30, 2009 I experienced this exact same problem recently. I suggested some workarounds and performance fixes here. Basically you can turn the status cache off (which worked great for me as I didn't use the icon overlays very often), or include/exclude particular paths for the icon overlays to be used in. Hope that helps. Quote
Antoine Chalons Posted May 14, 2009 Author Report Posted May 14, 2009 Version 1.6.2 is out and the change log says : [...] - BUG: Segfault in TSVNCache. (Stefan) [...] - BUG: Deadlock in the TSVNCache.exe process. (Stefan) So hopefully this issue has been solved.. will let you know. Quote
TobyD Posted May 14, 2009 Report Posted May 14, 2009 QUOTE (Antoine Châlons @ May 13 2009, 01:17 AM) Version 1.6.2 is out and the http://sourceforge.net/project/shownotes.php?release_id=681520' rel='nofollow' target="_blank">change log says :[...] - BUG: Segfault in TSVNCache. (Stefan) [...] - BUG: Deadlock in the TSVNCache.exe process. (Stefan) So hopefully this issue has been solved.. will let you know. I upgraded from 1.5.9 to 1.6.2 yesterday. So far I haven't had any issues. Quote
Antoine Chalons Posted May 14, 2009 Author Report Posted May 14, 2009 QUOTE (TobyD @ May 13 2009, 05:40 PM) I upgraded from 1.5.9 to 1.6.2 yesterday. So far I haven't had any issues. yep, been running 1.6.2 for a whole day and everything seems to be fine. Quote
