jgcode Posted August 24, 2010 Report Posted August 24, 2010 I am getting the above RTM from a build - I have never seen those characters before in the RTM. All I am doing is a basic build - new project, single VI with a single control, no custom RTM, EXE build spec with default settings. Have tried reboot PC, but still the same - it looks like something has become corrupt? I have no idea ! Cheers -JG Quote
dannyt Posted August 24, 2010 Report Posted August 24, 2010 I am getting the above RTM from a build - I have never seen those characters before in the RTM. All I am doing is a basic build - new project, single VI with a single control, no custom RTM, EXE build spec with default settings. Have tried reboot PC, but still the same - it looks like something has become corrupt? I have no idea ! Cheers -JG Sorry if I am suggesting the obvious here, especially to a man of your experience, but is this not an inevitable result based on your previous post about the "No supported languages installed" or have you sorted that one out already ? Dannyt 1 Quote
jgcode Posted August 24, 2010 Author Report Posted August 24, 2010 Sorry if I am suggesting the obvious here, especially to a man of your experience, but is this not an inevitable result based on your previous post about the "No supported languages installed" or have you sorted that one out already ? Dannyt No, please, suggest away - I do stupid stuff all the time Unfortunately its not related (the last one was DSC-related) - I was more complaining about the lack of error messaging. (Why does not it just say you need to include Enhanced DSC Support?, or automatically do it for me in the build, or warn me at build time?) Anyways, the above is happening on my PC but works fine on another PC I just tested so I am confused at the moment. That was another build where I was testing some code as I have a worse issue at the moment - my app code works in Dev Environment but not in Run Time, it is broken - and I hate those ones! So generally I have been rather angry today. Quote
crelf Posted August 24, 2010 Report Posted August 24, 2010 Is this a deployed application? If so, what were your language settings in the installer? Quote
jgcode Posted August 25, 2010 Author Report Posted August 25, 2010 I see the same in my palettes. Did you find a fix? Is this a deployed application? If so, what were your language settings in the installer? Yes, it is a build application (didn't use an installer, just an built the executable as I was testing) All languages were ticked, but its not the build spec I think, as this builds fine on another PC without the above issue. Not sure when my LabVIEW flipped, but one day it was working and the next I got the above issue! Quote
MikaelH Posted August 25, 2010 Report Posted August 25, 2010 Are you using the "English" setting in the "Control Panel->Reginal and Language Options->Advanced->Langauge for non-Unicode program->Drop Down list box" ? 1 Quote
jgcode Posted August 25, 2010 Author Report Posted August 25, 2010 Are you using the "English" setting in the "Control Panel->Reginal and Language Options->Advanced->Langauge for non-Unicode program->Drop Down list box" ? Thanks Mikael I just checked, it is set for English. Quote
jgcode Posted August 25, 2010 Author Report Posted August 25, 2010 This is what the Application Splash Screen looks like: Quote
Ton Plomp Posted August 25, 2010 Report Posted August 25, 2010 This is what the Application Splash Screen looks like: I had this for VIPM (but only for VIPM). Ton Quote
jgcode Posted August 25, 2010 Author Report Posted August 25, 2010 I had this for VIPM (but only for VIPM). Ton Did it get fixed somehow? This one is really weird - I think something has gone haywire with the IDE, contemplating reinstall. Quote
Ton Plomp Posted August 26, 2010 Report Posted August 26, 2010 Did it get fixed somehow? This one is really weird - I think something has gone haywire with the IDE, contemplating reinstall. A repair fixed it. What really weird was that only on e install of VIPM did that, and that error logs on disc had some Unicode issues as well. Never really studied it though. Ton Quote
jgcode Posted August 27, 2010 Author Report Posted August 27, 2010 This topic is continued on ni.com. Quote
