Quote
Integrated Development Environment. This is another request I made to the NI rep. He had an answer that sounded reasonable but I forgot what it is. The fact that fulfilling the wish is impossible doesn't stop me from requesting it. (Yes, please move that mountain 2 miles south so I have a better view of it.) Labview windows all over the place drives me absolutely nuts. I connect my laptop to multiple monitors at home and at work; it is not uncommon for me to open a vi and have the window be located completely off the screen!
It took me a while to figure out what you meant here. LV does have an integrated development environment, a very complete integration. When I'm told "there's no IDE for this language", I think of a case where someone edits their code in a text editor and then goes to a command line to do a compile.
What you're asking for is a MDI (Multiple Document Interface) for the IDE. That was attempted in LV8.0 and beta users killed it quickly. Very quickly. Since then we've had internal teams continuously researching different environment options. If you look at the LEGO Mindstorms NXT product, you'll see one MDI environment for LabVIEW. The LEGO environment didn't need front panels, which solved one of the major headaches of MDI. Major issues of window management include the context help, the palettes, probes and reentrant VI clones. None of the MDI environments attempted thus far has been as good as the current scenario of individual windows.
The handling of VIs moving from a machine with monitor specs XYZ to another machine of monitor specs ABC is a separate issue, one that has also been addressed in the last couple of releases and is continuing to be worked on.
