Francois Normandin Posted January 19, 2010 Report Posted January 19, 2010 Name: Open Office RGT addon Submitter: Francois Normandin Submitted: 18 Jan 2010 Category: LabVIEW IDE LabVIEW Version: 2009License Type: BSD (Most common) Public Git repo (source code): https://bitbucket.org/normandinf/openofficergt ==================================== Open Office RGT addon v0.2.0 beta Copyright © 2010-2016, François Normandin. All rights reserved. Author:François Normandin Contact Info: Contact via PM on www.lavag.org LabVIEW Versions: Created and tested with LabVIEW 2009 Dependencies: Report Generation toolkit (part of it is included in the base package: Word & Excel require license) Description: This package contains an installer and class to use the AODL (An OpenDocument library) with the Report Generation toolkit from National Instruments. Includes: - ooWriter class - AODL classes (and DLLs) - PreInstall and PreUninstall VIs to backup the only modified NI VI: New Report.vi (in Utility\NIReport.llb) Instructions: After installing package with VIPM, use the NI Report Generation palette as usual. Known Issues: 1- ooWriter: Styles integration is incomplete. Needs to have a real "style" class created that will comply with current standard in RGT. Adding an image is not working correctly: it is embedded in a paragraph instead of being standalone. 2- ooCalc: no integration yet, but rather similar to ooWriter in principle. (All the roadblocks will be cleared by ooWriter) 3- This code has been done with LV2009. I see no problem for using with LV 8.2 and up, it's just a matter of saving for previous version and distribute. This will be done at a later date. Acknowledgements: National Instruments. (NI Report Generation Toolkit) ** LVOOP rocks ** AODL by Sun Microsystems, Inc. Copyright 2007 History: v0.2.0: released on bitbucket (Git) for community v0.1.0: Initial release of the code. (LV2009) License: LabVIEW libraries of OpenOffice for RGT addon are licensed under BSD. AODL us distributed under the LGPL license. (see license files for more detail) Support: If you have any problems with this code or want to suggest features: please go to www.lavag.org and Navigate to the discussion page. Distribution: This code was downloaded from the LAVA Code Repository found at www.lavag.org ============================ Click here to download this file 2 Quote
Mark Balla Posted January 24, 2010 Report Posted January 24, 2010 Certified 1-24-2010 Moved to LabVIEW IDE Quote
mgunning Posted May 25, 2010 Report Posted May 25, 2010 Is it possible to get a LabVIEW 8.2.1 version of this? I don't have LabVIEW 2009 to backsave it. Quote
Yair Posted May 25, 2010 Report Posted May 25, 2010 I don't think an 8.2 version will help you. Based on the description here, it looks like this plugs into the OOP version of the RGT, which was only released with 8.6 (and which I believe also relies on certain LVOOP features which weren't available in 8.2, so you couldn't backsave that even if the license allowed it, which it probably doesn't). Quote
Micael Posted June 2, 2010 Report Posted June 2, 2010 Hi all, Did anyone manage to backsave the addon to LV8.6 ? I tried, but it seems more complicated than just a "save for previous version"... Thanks Quote
Francois Normandin Posted June 2, 2010 Author Report Posted June 2, 2010 On 6/2/2010 at 9:14 AM, Micael said: Hi all, Did anyone manage to backsave the addon to LV8.6 ? I tried, but it seems more complicated than just a "save for previous version"... Thanks This is why I didn't do it yet. I developed it in LV2009 and would need to make sure the directory structure is the same. This work is done at home on my spare time and since I don't have 8.6 installed on my personal computer, that's not my priority right now. With the beautiful season coming back, I anticipate even less time for that. Sorry. Quote
LAVAslide Posted December 9, 2010 Report Posted December 9, 2010 Francois -- great work with this toolkit! Is there any update for the integration of ooCalc? Quote
Francois Normandin Posted December 9, 2010 Author Report Posted December 9, 2010 On 12/9/2010 at 8:36 PM, LAVAslide said: Francois -- great work with this toolkit! Is there any update for the integration of ooCalc? Unfortunately I haven't. This was a hobby project at home and I never got time to dig in again and complete at least ooCalc to the level I got ooWriter. It wouldn't be difficult to do, but I think that I might restart again using a UML Design Software to really take a huge bite at it... and take a slightly better class design. My biggest problem is to keep the "Document" reference that is essentially "by-reference" in the .NET model and I'm trying to port it to the dataflow paradigm. I was tempted to make it a singleton by-reference class, but I'd prefer to leave some latitude for handling multiple documents in parallel... so I still have to put some thoughts into it. Since you mentioned in the PM that you're looking into integrating it at your company, don't hesitate to ask me specific questions if you have a roadblock in your dealings with the AODL integration for ooCalc. I didn't deal with "Cells" in ooWriter, by Cell is a child class of Content, just as Paragraph and sText for ooWriter. Much of the structure I used for ooWriter is directly portable to ooCalc. You just need to pay attention which .net class you cast to keep the dataflow. Most of the time, I've used the Document and Content classes to make it flexible. Quote
BastiFantasti Posted August 30, 2011 Report Posted August 30, 2011 Hi, I've installed your addon in LV2011 (RGT 2011) and it works fine in the IDE. But when creating an executable using the RGT (only for Microsoft Word) the application throws an error 2208 and doesn't execute on a machine without the full development system. Can anybody confirm this? Regards, Bastian Quote
Francois Normandin Posted August 30, 2011 Author Report Posted August 30, 2011 On 8/30/2011 at 9:23 AM, BastiFantasti said: Hi, I've installed your addon in LV2011 (RGT 2011) and it works fine in the IDE. But when creating an executable using the RGT (only for Microsoft Word) the application throws an error 2208 and doesn't execute on a machine without the full development system. Can anybody confirm this? Regards, Bastian Hi Bastian, just to make sure... this add-on doesn't give you access to Word and Excel reports without a purchased license from NI. It simply adds OpenOffice Writer to the list of choices in the Report Generation Palette. If you have a valid RGT for Word license and my add-on doesn't work in an executable, then it's something I'll investigate. There shouldn't be any links between the RGT for Word/Excel sold by NI and this piece of code, but the package does replace a single VI to select the right class (the one including ooWriter in the Enum). It has been done in LV2009, so perhaps something has changed in LV2011. Did you ever try the addon in an executable with LV2009 or 2010? (Is this a new issue with 2011?) Quote
Francois Normandin Posted April 15, 2016 Author Report Posted April 15, 2016 Sorry, I abandoned this project a few years ago. I've uploaded the project to Bitbucket as a Git repo, if you feel like contributing or forking it for your project. I'll see to add the VI Package files shortly for easy install. https://bitbucket.org/normandinf/openofficergt Quote
Francois Normandin Posted April 15, 2016 Author Report Posted April 15, 2016 (edited) - Updated the repo with package build spec - Removed the dependencies on OpenG methods (package is now dependency-free) - Added an explicit constructor for ooWriter (no more pre-install/post-install to backup the NIreport factory) - New palette for ooDocuments (vi.lib/OpenOffice RGT addon) - version 0.2.0 (beta) - still no ooCalc. - released the LabVIEW library under BSD (instead of LGPL). LGPL is only the AODL libraries part of the package. Edited April 22, 2016 by Francois Normandin 1 Quote
