mje Posted October 1, 2010 Report Share Posted October 1, 2010 Warning! This is purely academic. My current implementations work fine, I'm just going into excessive details here... My lack of a real CS background here is going to show, but I'm wondering if there's a way to compute array intersections that don't operate in linear time (that is I'd like the operation time not to scale linearly with array size)? I have two methods I hammered out: The first one is probably a little less obvious, but I actually consider it more elegant as it operates in place on the two input arrays, and avoids N^2-time by not blindly doing a nested for loop. Big caveat is the input arrays need to be pre-sorted. Works for me though since the arrays I will be feeding it always will be sorted by virtue of how they were created. The second one is slower by a factor of about 5 on my system, I suspect mostly due to the extra memory allocation being done by concatenating the two input arrays, I'm sure the sort doesn't help either. I'll be honest, both of these work in about a millisecond for the data I'm throwing at them, either one is fine. However they're called in series after a few binary searches I've implemented, and after powering through multiple arrays in microseconds (yay log(N)!), I hate to bottleneck afterwards with serial calls to a function that operates on N-time. I will be iterating over this a few thousand times though, going into log-time can mean the difference of waiting a few seconds and being instantaneous. I like instantaneous. -m Quote Link to comment
ned Posted October 1, 2010 Report Share Posted October 1, 2010 The top approach looks pretty good to me. You could improve it slightly by pre-allocating the final array, then resizing it after the loop finishes. Also, this is purely aesthetic, but there's a Swap primitive available in the memory management palette that could replace the case structure at the top left. Quote Link to comment
ShaunR Posted October 1, 2010 Report Share Posted October 1, 2010 Array indexing inside a for loop is a killer. Actually concatenating isn't too bad due to optimisations (LV is very efficient with For-loops). I vaguely remember a challenge from Jim Kring to find a better method than concatenating for selecting arbitrary values from an array. I don't think there were any takers. So assuming that we have to concatenate in some form or another the best we can hope for is pre-processing. Along this line what about finding turning points? Maybe faster, maybe not but it would uses in-build functions (generally faster than native LV) and eliminate the array indexing. Quote Link to comment
ShaunR Posted October 1, 2010 Report Share Posted October 1, 2010 I thought I'd seen this problem bedore Here is another method that's similar to your first one rather than the second. This VI (wrote it a while ago now) returns the array differences but the theory is the same. Slightly different in that it actually does a search and eliminates data, therefore reducing the data set as it goes. Its very quick especially if the duplicates are sparse and isn't explicitly linked to the data-set size, rather the number of duplicates. Quote Link to comment
Francois Normandin Posted October 1, 2010 Report Share Posted October 1, 2010 Array indexing inside a for loop is a killer. Actually concatenating isn't too bad due to optimisations (LV is very efficient with For-loops). I vaguely remember a challenge from Jim Kring to find a better method than concatenating for selecting arbitrary values from an array. I don't think there were any takers. So assuming that we have to concatenate in some form or another the best we can hope for is pre-processing. Along this line what about finding turning points? Maybe faster, maybe not but it would uses in-build functions (generally faster than native LV) and eliminate the array indexing. Isn't the array intersection the result of the terms present in both arrays? You show the list of terms that are present at least in one, not both. Quote Link to comment
SuperS_5 Posted October 1, 2010 Report Share Posted October 1, 2010 Using parallel for loops will be faster if using large arrays and multiple processors. Quote Link to comment
ned Posted October 1, 2010 Report Share Posted October 1, 2010 Array indexing inside a for loop is a killer. Actually concatenating isn't too bad due to optimisations (LV is very efficient with For-loops). I vaguely remember a challenge from Jim Kring to find a better method than concatenating for selecting arbitrary values from an array. I don't think there were any takers. So assuming that we have to concatenate in some form or another the best we can hope for is pre-processing. Along this line what about finding turning points? Maybe faster, maybe not but it would uses in-build functions (generally faster than native LV) and eliminate the array indexing. There's no need to concatenate in a loop at all here. You know in advance that the intersection array cannot be larger than the smaller of the two input arrays, so you can preallocate an array of that size. Track the current array index in a shift register. Each time there's a match, use replace array subset instead of build array, and increment the array index. When the loop finishes, resize the array to the final value of the index shift register. This is much faster than concatenating in a loop. Quote Link to comment
SuperS_5 Posted October 1, 2010 Report Share Posted October 1, 2010 ops forgot to take out the timing info for single threaded mode......ignore the timing part of that for loop. Quote Link to comment
ShaunR Posted October 1, 2010 Report Share Posted October 1, 2010 (edited) Isn't the array intersection the result of the terms present in both arrays? You show the list of terms that are present at least in one, not both. Indeed. It was a quick demonstration of a theory rather than a solution. If you change it like so...... Then you get unique intersection values for example. There's no need to concatenate in a loop at all here. You know in advance that the intersection array cannot be larger than the smaller of the two input arrays, so you can preallocate an array of that size. Track the current array index in a shift register. Each time there's a match, use replace array subset instead of build array, and increment the array index. When the loop finishes, resize the array to the final value of the index shift register. This is much faster than concatenating in a loop. Sweet. that'd be even faster Edited October 1, 2010 by ShaunR Quote Link to comment
mje Posted October 1, 2010 Author Report Share Posted October 1, 2010 First yes, intersection is the element present in both arrays. Of course, there's no need to do the concatenation. However my use case has the input arrays potentially being orders of magnitude larger than the intersections, I really don't want to do an allocation like that if I don't have to. Plus, NI has some really good optimizations for array sizes. Tests I've done earlier implied when arrays are allocated, a chunk of memory larger than the array size is used, allowing the array to grow without reallocations. I believe it seemed that reallocations only happened every time the array doubled in size or so (within reason, I'm sure larger arrays work off fixed size padding, possibly small ones too). With those considerations, I left the concatenation operation in the loop. For the record, I think there are three things that can be done with the arrays: Operate in place on one of the input arrays (that is overwriting it as you go). Trim it when finished. This implies the VI will have to always copy its inputs as not to alter data on the calling VIs wires. Pre-allocate an intersection array sized to the smaller of the two inputs. Trim when finished. Concatenate within a loop. Again, I'm banking on compiler optimizations and my use case that #3 is fastest. I'll have to look into ShaunR's idea, not sure how fast it will run (don't know much about that function). Also completely forgot about possibly parallelizing. Good idea! Quote Link to comment
ned Posted October 1, 2010 Report Share Posted October 1, 2010 For the record, I think there are three things that can be done with the arrays: Operate in place on one of the input arrays (that is overwriting it as you go). Trim it when finished. This implies the VI will have to always copy its inputs as not to alter data on the calling VIs wires. Pre-allocate an intersection array sized to the smaller of the two inputs. Trim when finished. Concatenate within a loop. If you want to be really efficient about this, and you don't need to reuse the arrays after computing the intersection, you can reuse the non-auto-indexed array to store the intersection, and trim that when the loop exits. This gets you the benefit of both 1 and 2. Quote Link to comment
mje Posted October 2, 2010 Author Report Share Posted October 2, 2010 Yes, good point, ned. Now I think I might be a little obsessive. But here's some data. Method A: This is a slightly modified version of the first method I put up in my original post. Concatenation in loop. (Method B is not worthy of mention it's so slow, it's the second one in my original post) Method C: Modified to pre-allocate the intersection array, then trim it as necessary. Method D: Re-uses one of the input arrays, then trims it as necessary. I'd expect that this has an implicit allocation though if the compiler decides that the VI can't operate in place on the caller's data (not verified). The metrics are that for sets where the intersection is very small compared to the input (say 2 elements out of 10 000), method A is fastest, but not by much. Note this is my typical use case. A: 561 C: 655 D: 624 When the intersection is larger, say 2500 out of 10 000 elements, method A starts to show its limits due to in-loop concatenation. Method D works out to be fastest. A: 1326 C: 780 D: 608 I'm surprised A doesn't show more of an improvement in small intersections. Given that find, I think D is the clear winner. Still trying to wrap my brain around if this could be done more intelligently by applying binary type searching rather than indexing, but I think I'm satisfied enough for now. I'll add that given the poor performance of B, I didn't even explore parallelism. Yet to look into the derivative methods, but I suspect they'll be quite slow given that for no other reason the data needs to be cast to arrays of doubles, but I expect the differential function to be the real bottleneck, never mind a linear iteration still needs to be done to build the intersection array. Might explore after getting some sleep. Quote Link to comment
jzoller Posted October 2, 2010 Report Share Posted October 2, 2010 (edited) Still trying to wrap my brain around if this could be done more intelligently by applying binary type searching rather than indexing, but I think I'm satisfied enough for now. I think you can get to O(m log n) with this using a binary search. (NI's binary search vi's are here.) Sort and binary search are (most likely) O(log n), and the for loop is O(m). Of course, this doesn't catch duplicates, and NaN's can make it a little cross-eyed. Joe Z. Edit: Come to think of it, you don't actually need to sort your smaller array. Edited October 2, 2010 by jzoller Quote Link to comment
Bytelabs Posted March 31, 2017 Report Share Posted March 31, 2017 I create vi that intersec 2 array using only one for loop. Array_Intersect Arrays.vi Quote Link to comment
hooovahh Posted March 31, 2017 Report Share Posted March 31, 2017 I'm not an expert at this type of function, but your version doesn't produce the same output as the others. In your VI I gave Array 1 = [4] and Array 2 = [5] and the output was [4,5], and the first VI posted here results in an empty array for that input. I haven't done any speed test but with the advent of the conditional indexing terminal I'd suspect the simplest solution to be the modified version of what SuperS posted. Edit: Oh but that does include duplicates multiple times. Maybe a remove duplicates from the Array B, or remove duplicates from Array A and B since that output will never be larger than Array B. Quote Link to comment
COsiecki Posted April 13, 2017 Report Share Posted April 13, 2017 Going off Hooovahh's code, since you say the inputs are sorted, you could use the found index as the initial search location for the next iteration. I know you lose the parallel-for-loop benefits, but it may make up for that by having a decreasing search pool for each subsequently found element, You'd need to catch when the B element wasn't found so you don't reset your starting point. Quote Link to comment
