Is the Front Panel selected?
I'm searching a way to simply know if the Front panel is currently selected.
Hi Jonathan
There is a property node to check the current VI:
post-10325-0-38548000-1292138795_thumb.p
Might be worth mentioning this OpenG VI too?:
post-10325-0-56711900-1292138793_thumb.p
Cheers
-JG
Jut a note.
This property node only tells you if the VI is in front of other VIs.
If you click on (say) your web browser, it will still say it is front most.
Edited by ShaunR
The same thing hapens with Is.Frontmost properties if I click on the desktop.
