Jan Klasson Posted July 1, 2011 Report Posted July 1, 2011 We have relesed GOOP Development Suite v4.1. Most important features are: - support for RT - GOOP3 to GOOP4 conversion - A new design pattern: Active object supporting dynamic events. About design pattern. To keep generated code to a minimum only basic functionality is added by default into the GOOP 4 class. As a complement we introduced the "Add Design Pattern" feature which can be used to add extra features to the class, for example: persistent, class attributes and active object. As usual the tool adds the same features, create class/UML code generation/etc, for native LabVIEW classes aswell as the by-reference based templates. GOOP4 Class template version is updated so run the ClassTemplateUpdate feature to update existing code. Download installer and read more: www.symbio.com/goop One month free trial included, there is also the free Community Edition. Contact goop@symbio.com for questions. GOOP 3 vs. GOOP 4. For new projs we recommend GOOP 4. It is built using the DVR, it will perform better and we have kept the generated extra code to a minimum. Thanks, Jan Klasson and Mike Holmström Symbio, former Endevo Quote
viSci Posted July 1, 2011 Report Posted July 1, 2011 Ran the GOOP4 installer, restarted LV and found LV searching for many files that were not present from the install, is there a companion installation that needs to be run as well? Quote
MikaelH Posted July 2, 2011 Report Posted July 2, 2011 Everything is included in the big zip file, make sure you get the whole file downloaded. For large files I normally try to avoid using IE ;-) Cheers, Mike Quote
viSci Posted July 2, 2011 Report Posted July 2, 2011 The GOOP overlords must be angry at me... I just tried to download from another machine (windows 7). Got the zip file but the unzip error-ed out about 1/2 way through on the this file Quote
MikaelH Posted July 3, 2011 Report Posted July 3, 2011 FYI we're having some download problems from our servers right now, we're working on it. Apologize for the inconvenience. Cheers, Mike Quote
MikaelH Posted July 8, 2011 Report Posted July 8, 2011 Okay guys the servers are up and running now. Currently these links are working: http://goop.endevo.net/GDS/GDS_4.1_2009.zip http://goop.endevo.net/GDS/GDS_4.1_2010.zip http://goop.endevo.net/GDS/GDS_4.1_2010-64.zip Cheers, Mike Quote
Ad Dekkers Posted August 8, 2011 Report Posted August 8, 2011 Okay guys the servers are up and running now. Currently these links are working: http://goop.endevo.net/GDS/GDS_4.1_2009.zip http://goop.endevo.net/GDS/GDS_4.1_2010.zip http://goop.endevo.net/GDS/GDS_4.1_2010-64.zip Cheers, Mike Hello Mike, Is there also a 2011 version? Quote
MikaelH Posted August 8, 2011 Report Posted August 8, 2011 You can find them here: http://goop.endevo.net/GDS/GDS_4.1_2011.zip http://goop.endevo.net/GDS/GDS_4.1_2011-64.zip These have not been tested on the official 2011 release yet, but has been tested on the Beta version. And I can say that this version of LabVIEW worked with GDS perfectly from the start. Cheers, Mike Quote
Bjarne Joergensen Posted August 9, 2011 Report Posted August 9, 2011 You can find them here: http://goop.endevo.n...DS_4.1_2011.zip http://goop.endevo.n...4.1_2011-64.zip These have not been tested on the official 2011 release yet, but has been tested on the Beta version. And I can say that this version of LabVIEW worked with GDS perfectly from the start. Cheers, Mike But Mikael I got this error when trying to unZip: ! C:\Users\bjaj\Downloads\GDS_4.1_2011 (1).zip: CRC failed in GDS_Installer_Q5V\Files\ClassProviders\DesignPatterns\ActiveObjects\ActiveObjects_QueueQueue_SubVIs\ActiveObjects_QueueQueue_SendMsgToProcess_6x8x6_Singleton.vi. The file is corrupt Cheers Bjarne Quote
MikaelH Posted August 9, 2011 Report Posted August 9, 2011 Sorry about that. Try these files instead: http://goop.endevo.net/GDS/GDS_4.1_2011.zip http://goop.endevo.net/GDS/GDS_4.1_2011-64.zip Cheers, Mike Quote
Rammer Posted May 25, 2012 Report Posted May 25, 2012 Is GOOP v4.1 suppose to work with LV 2011 SP1? If I run the installer it craps out on the mass compile and corrupts the entire labview installation. I have tried 4 times. Anyone gotten this to work? Thoughts why it does not? Looks like I will skip SP1. John Quote
MikaelH Posted May 25, 2012 Report Posted May 25, 2012 I'll look into it. Normally the mass compile should not come up. But the latest version(4.5) I'm working on works just fine in all version fromm 2010 to 2012. We do have a 4.2 release ready, but we're just finishing up the documentation. //Mike Quote
AjayMV Posted October 29, 2012 Report Posted October 29, 2012 Can anybody explain about "Active Object: Queues to and from process" design pattern? As I am new to these GOOP and learning design patters to apply for my project, I would like to have some description about "Active Object: Queues to and from process" design pattern. Kindly let me know if any knowledge base is available. Thanks, Ajay Quote
drjdpowell Posted October 29, 2012 Report Posted October 29, 2012 Can anybody explain about "Active Object: Queues to and from process" design pattern? Haven’t use GOOP, but Daklu’s “Slave Loop” is an example of an active object with queues to and from the process. Actor Framework is another example, but Daklu’s design will be simpler to understand. — James Quote
MikaelH Posted October 29, 2012 Report Posted October 29, 2012 Can anybody explain about "Active Object: Queues to and from process" design pattern? As I am new to these GOOP and learning design patters to apply for my project, I would like to have some description about "Active Object: Queues to and from process" design pattern. Maybe this video will help you out: http://goop.endevo.net/GDS/videos/DesignPatterns (you can fast forward to 4:40 to get to the Active Object implementation) If you still have any questions, let me know and I'll help you. //Mike Quote
AjayMV Posted October 30, 2012 Report Posted October 30, 2012 Mike, thanks for the information. Regards, Ajay Maybe this video will help you out: http://goop.endevo.n.../DesignPatterns (you can fast forward to 4:40 to get to the Active Object implementation) If you still have any questions, let me know and I'll help you. //Mike Quote
MikaelH Posted October 30, 2012 Report Posted October 30, 2012 Mike, thanks for the information. Regards, Ajay No worries, keep your eyes open and you'll soon see the release on GDS 4.5 :-) Quote
