Ano Ano Posted August 29, 2012 Report Share Posted August 29, 2012 Hello, I have a Omron E5CN Temperature controller that I want to use with Labview and Modbus. I am able to communicate with this controller using Omron's Thermomini software. MAX is able to validate the and open a session with the device. The controller is connected via a RS232 to USB converter. I set the controller to modbus but no luck. Maybe its because I dont know how to use the modbus drivers, I havent attempted to use such a device with Labview so I am lost with all this machine codes ! Any advice towards a newbie on how to use this controller with Labview/Modbus? The programming manual for this controller is here Quote Link to comment
Tim_S Posted August 29, 2012 Report Share Posted August 29, 2012 The hardest thing to find is the base Modbus address. No manufacturer seems to put the exact correct address in their manuals, so you'll have to hunt a bit to find the correct base address. Everything after that is offset from the base address. Quote Link to comment
JamesMc86 Posted August 29, 2012 Report Share Posted August 29, 2012 Which mod us library are you using? Is it the free one off ni.com? From a quick look at the commands you need to be using the register accesses for the data. With the free mod us library I believe you should then be able to send the addresses as the manual suggests, some other implementations require an offset depending on the data you are reading. Generally 3 for read only registers (or variables as the manual calls thru) or 4 for read/write registers so the address for a read only register at address 1 appears as 40001. the addresses appear to be detailed in section 6. Hopefully this is a starting point to decipher some of the data you are seeing. Let me know what library your using and I may. E able to be a little more specific. Quote Link to comment
ShaunR Posted August 29, 2012 Report Share Posted August 29, 2012 I would start with the "echo" command. Once you get that working (i.e. eliminate all the serial configurations and get something tangible back); it should be plain sailing from there. Quote Link to comment
Neville D Posted August 30, 2012 Report Share Posted August 30, 2012 There seems to be a bug in the Modbus CRC calculation vi in the NI library. Replace it with the attached VI that I got from Steve Brooks on the NI website. MBcrc.vi 1 Quote Link to comment
Ano Ano Posted September 18, 2012 Author Report Share Posted September 18, 2012 This file is written with Labview v11, can you please down-convert it to v10.1? Quote Link to comment
asbo Posted September 18, 2012 Report Share Posted September 18, 2012 Backsaved to LabVIEW 8.0. MBcrc.LV80.vi There seems to be a bug in the Modbus CRC calculation vi in the NI library. Replace it with the attached VI that I got from Steve Brooks on the NI website. Do you know what the changes were in this VI? Quote Link to comment
Neville D Posted September 28, 2012 Report Share Posted September 28, 2012 Sorry, just saw this. I don't remember now, but I checked the CRC generation code and the NI version didn't exactly conform to the ModBUS spec document (Pg 14 & Pg 39): http://www.modbus.org/docs/Modbus_over_serial_line_V1_02.pdf Bottom line was: Steve Brooks' version worked with a ModBUS device I was using, and the NI version didn't. Quote Link to comment
Xuan-Thai Nguyen Posted August 20, 2019 Report Share Posted August 20, 2019 Hi every one, I can connect and run E5CN tempt. controller to Labview through Modbus. Attached files are my programming test for E5CN. E5CN_test new.vi MBcrc (2).vi String Hex to Interger Decimal.vi Quote Link to comment
Porter Posted August 20, 2019 Report Share Posted August 20, 2019 I would highly recommend that you use one of the existing modbus libraries to communicate with the E5CN. See: OR: https://github.com/NISystemsEngineering/LabVIEW-Modbus-API Quote Link to comment
Xuan-Thai Nguyen Posted August 21, 2019 Report Share Posted August 21, 2019 Dear Poster, Thank you for your recommendation. How do I install Labview modbus API? Quote Link to comment
Porter Posted August 21, 2019 Report Share Posted August 21, 2019 Its easiest to use VI Package manager. Just search for Modbus, select the package and install. Quote Link to comment
