Store time stamp data in configuration file?
I'm trying to store time stamp data in a configuration file, but am not having much luck. I noticed there is a time stamp data type, but can't figure out how to store it directly in the ini file.
As a backup I tried converting the timestamp to a double first, but I keep losing digits that way. It won't store the full precision in the ini file.
Any ideas?
Thanks,
George
You should be able to use the "format into string" and "scan from string" functions to store a human readable timestamp in an INI file with considerable accuracy.
Try this format string:
 %^<%Y-%m-%dT%H:%M:%S%16uZ>T
modify the 16u portion to set the fractional seconds.
ISO-8601 Persistent Timestamp.vi
LabVIEW's 128 bit timestamp is accurate to 0.05421010862427522170... attoseconds
http://www.ni.com/white-paper/7900/en
Edited by Phillip Brooks
Accurate.  You keep using that word.  I do think it means what you think it means. :)
Precise, sure, but accurate, no. Not yet anyway.
Of interest, why do the fractional seconds truncate rather than round?  If using the format in your signature (%3u) I get
2013-03-18T20:40:36.8988289833068847Z current time
2013-03-18T20:40:36.898Z formatted time
