  • Similar Content
    • By hooovahh
      View File Hooovahh Array VIMs
      Here is the Hooovahh Array VIMs.  This initial release contains 14 VIMs for manipulating array data, which are intended to replace OpenG functionality, but with the added benefit of data type propagation, and increased performance using newer array manipulation techniques.  In later versions other Array manipulation functions were added moving all the OpenG stuff to their own palette.
      Most of the OpenG functions are unchanged, but a few use the newer conditional and concatenating tunnels.  And a few functions have added performance based on other inputs.  For instance the Delete Array Elements can operate in a more efficient way if the input indexes are already sorted.  The Filter 1D array can also be more efficient if the input is known to not contain any duplicates.
      Because these packages contain VIMs, they require LabVIEW 2017 or newer.  Having these functions be VIMs mean all functions work with various array data types.  Included functions are:
      Conditional Auto-Indexing Tunnel Delete Elements from (1D or 2D) Array Filter 1D Array Index (1D or 2D) Array, Scalar, Row, Column Remove Duplicates from 1D Array Reorder (1D or 2D) Array Reverse 1D Array Slice 1D Array Sort (1D or 2D) Array Convert 1D to 2D Convert 2D to 1D Find Subarray Force Array Min/Max Size Foreign Key Sort Submitter hooovahh Submitted 10/11/2017 Category *Uncertified* LabVIEW Version 2018 License Type BSD (Most common)
    • By hooovahh
      Here is the Hooovahh Array VIMs.  This initial release contains VIMs for manipulating array data, which are intended to replace OpenG functionality, but with the added benefit of data type propagation, and increased performance using newer array manipulation techniques.  In later versions other Array manipulation functions were added moving all the OpenG stuff to their own palette.
      Version 2.0 changed the suffix naming standard.  Updating may mean replacing calls to the new versions since the name on disk has changed.  This was for consistency and I'm sorry for breaking compatibility.  The added type defs in 2.0 may break compatibility too but these help avoid code breaking bugs since VIMs allowed any data type previously.
    • By WILSTi
      Hello,
      I'm developing an application to play "Battleship" with another opponent through serial communication. I currently have the following difficulty:
       I have not been able to fill the Array with my opponent's ships, I can modify a position, but by changing the position, the result of the previous position returns to its original value.
      VI operation:
      For my turn, using the radio buttons, I select the coordinate and press the SEND button. My opponent answers me with a 1 if I hit or with a 0 if I failed, this data is what I couldn't keep in the array.
      Best regards,
      3Q.vi
    • By Ram Prakash
      Can anyone please tell what a DVR [ Data value reference ] is ? I want to know at what situation it will be used and what are the advantages we get by using DVR. I am really confused in this topic . If someone has any code in which they have worked with DVRs. kindly share it to me.
      Thank you.
    • By Chen Li
      The program obtains the number of messages in the hardware buffer through ZCAN_GetReceiveNum function, and then calls ZCAN Receive to complete the received data. When the amount of data reaches 1000 frames / s, the program will crash.
      UINT ZCAN_Receive(CHANNEL_HANDLE channel_handle,  ZCAN_Receive_Data* pReceive,  UINT len,  INT wait_time = -1);
      I think there is something wrong with creating the parameter array ZCAN Receive Data* pReceive. Has anyone ever encountered a similar problem?
      Receive.zip
