Neil Pate Posted February 14, 2014 Report Share Posted February 14, 2014 Hi All, I have some old code I need to make some changes to, and am not certain what version of LV it is done in. I so not have those old versions installed on my PC, and don't really want to install the wrong version. The .lvproj has <Project Type="Project" LVVersion="10008000"> in it, does anybody know if this is 8.6 or 8.6.1? My suspicion is that is it 8.6.1 Thanks Neil Quote Link to comment
ShaunR Posted February 14, 2014 Report Share Posted February 14, 2014 Hi All, I have some old code I need to make some changes to, and am not certain what version of LV it is done in. I so not have those old versions installed on my PC, and don't really want to install the wrong version. The .lvproj has <Project Type="Project" LVVersion="10008000"> in it, does anybody know if this is 8.6 or 8.6.1? My suspicion is that is it 8.6.1 Thanks Neil LV 2010 2013 = 13008000 2012 = 12008000 2011 = 11008000 2010 = 10008000 2009 = 9008000 2 Quote Link to comment
Neil Pate Posted February 14, 2014 Author Report Share Posted February 14, 2014 Thanks Shaun, I am quite surprised by this as I was pretty sure it was 8.6. Now I have to do a bit of thinking! Quote Link to comment
crossrulz Posted February 14, 2014 Report Share Posted February 14, 2014 If you want to make sure, then open a VI in the project and go to the VI Properties. In the List Unsaved Changes dialog it will tell you what version the file was last saved in. 1 Quote Link to comment
Neil Pate Posted February 14, 2014 Author Report Share Posted February 14, 2014 If you want to make sure, then open a VI in the project and go to the VI Properties. In the List Unsaved Changes dialog it will tell you what version the file was last saved in. Thanks, I did not know about this feature. Sure enough it is 2010. Now I am really confused as I would have bet (and lost) a lot of money that it was 8.6! Quote Link to comment
GregFreeman Posted February 14, 2014 Report Share Posted February 14, 2014 I think it was actually Crossrulz that made me aware of this tool which is usually my go-to for this sort of thing. Otherwise, I end up opening the project and accidentally saving out of habit and then having to roll back through version control. However, this will only show the version of the file you clicked on, so it doesn't help if your project was saved in 20xx but a couple VIs are a different version for one reason or another. In that type of scenario, I think you'd have to go with the method mentioned above to verify all. Quote Link to comment
