NickC Posted December 10, 2014 Report Posted December 10, 2014 Hi, I would like to generate the results in to html report and I should have control from front panel. Attached html template and front panel screen shots Report.htmlFetching info... Quote
Jordan Kuehn Posted December 10, 2014 Report Posted December 10, 2014 (edited) http://www.ni.com/example/27568/en/ First link is a bit dated. Check out these options, but you are looking for standard reports generated by the Report Generation Toolkit. http://www.ni.com/white-paper/13926/en/ Edited December 10, 2014 by Jordan Kuehn Quote
NickC Posted December 10, 2014 Author Report Posted December 10, 2014 Thank you Jordan Kuehn. I have checked those links. I think there is no much information in first link and in second link is like direct option to printer. Quote
ak_nz Posted December 10, 2014 Report Posted December 10, 2014 On 12/10/2014 at 7:40 PM, NickC said: Thank you Jordan Kuehn. I have checked those links. I think there is no much information in first link and in second link is like direct option to printer. The second link demonstrates an example of the Report Generation Toolkit. The example shows saving the report to an html file. Quote
infinitenothing Posted December 10, 2014 Report Posted December 10, 2014 A little bit off topic but if you wrote this sequence in TestStand, you'd already have HTML report generation by default. You'd also have a database, user logins, etc. Quote
jcarmody Posted December 11, 2014 Report Posted December 11, 2014 On 12/10/2014 at 9:55 PM, infinitenothing said: A little bit off topic but if you wrote this sequence in TestStand, you'd already have HTML report generation by default. You'd also have a database, user logins, etc. That's one of the sticking points I have with convincing folks to use TestStand. The HTML reports are about useless (without adding some thought and effort). Quote
NickC Posted December 11, 2014 Author Report Posted December 11, 2014 Sorry, I did not get your point. I have attached VI. I am evaluating different types checks. I would like generate those results along with the values into a report. Please could anybody suggest me how to proceed? NEO VI Example.llbFetching info... Quote
NickC Posted December 17, 2014 Author Report Posted December 17, 2014 Now I am able to store my results into a file. But I am unable to do for multiple cases. Could someone suggest how to do it? Quote
MikaelH Posted December 18, 2014 Report Posted December 18, 2014 We have created our own HTML reporting tool, it uses JQuery and JQPlot, so you can have plots that you can zoom into and right click export to xls functions. The best part is that it's a single html file page, that means that any images gets embedded in it. We refer to some style sheets and js files located on a local server, but then the file gets pretty big. Here is an report example. 20141219_080953_My Awesome Report_SN012334.htmlFetching info... Quote
NickC Posted December 19, 2014 Author Report Posted December 19, 2014 Well...Thank you. I am not going to show any graphs or charts in my html report. I am performing some calculation in multiple case structures based on some can message filtering. Results from all those case structures I would like write in one file. Could some attached some example VI. Quote
cac5610268 Posted October 14, 2016 Report Posted October 14, 2016 On 12/18/2014 at 9:14 PM, MikaelH said: We have created our own HTML reporting tool, it uses JQuery and JQPlot, so you can have plots that you can zoom into and right click export to xls functions. The best part is that it's a single html file page, that means that any images gets embedded in it. We refer to some style sheets and js files located on a local server, but then the file gets pretty big. Here is an report example. 20141219_080953_My Awesome Report_SN012334.htmlFetching info... Expand Hello Mikael, is this HTML reporting tool available for purchase or download somewhere? -Cristian Quote
MikaelH Posted October 16, 2016 Report Posted October 16, 2016 Sorry, it's using lots of internal libraries, but I've attached the the same HTML report with the JS and CSS files externally linked (this is the default way we save the plots, we refer to all JS and CSS files from a server). In this version you can see how easy it is to use the JQPlot API Report.zip Quote
