Calculating CRC
Hi
I have this code in C(and I don't understand it :angry: )
Is there someone that can help me translate it to labview?
Thanks in advance.
Bjarne
  typedef uint16_t (*bit_order_16)(uint16_t);
  typedef uint8_t (*bit_order_8)(uint8_t);
  uint16_t straight_16(uint16_t value)
    return value;
  uint16_t reverse_16(uint16_t value)
    uint16_t reversed = 0;
    for (int i = 0; i < 16; ++i)
      reversed <<= 1;
      reversed |= value & 0x1;
      value >>= 1;
    return reversed;
  uint8_t straight_8(uint8_t value)
    return value;
  uint8_t reverse_8(uint8_t value)
    uint8_t reversed = 0;
    for (int i = 0; i < 8; ++i)
      reversed <<= 1;
      value >>= 1;
    return reversed;
  uint16_t crc16(uint8_t const *message, int nBytes,
    bit_order_8 data_order, bit_order_16 remainder_order,
    uint16_t remainder, uint16_t polynomial)
    for (int byte = 0; byte < nBytes; ++byte)
      remainder ^= (data_order(message[byte]) << 8);
      for (uint8_t bit = 8; bit > 0; --bit)
        if (remainder & 0x8000)
          remainder = (remainder << 1) ^ polynomial;
        else
          remainder = (remainder << 1);
    return remainder_order(remainder);
  uint16_t crc16ss(uint8_t const *message, int nBytes, uint16_t initial, uint16_t poly)
    return crc16(message, nBytes, straight_8, straight_16, initial, poly);
  uint16_t crc16rr(uint8_t const *message, int nBytes, uint16_t initial, uint16_t poly)
    return crc16(message, nBytes, reverse_8, reverse_16, initial, poly);
  uint16_t crc16rs(uint8_t const *message, int nBytes, uint16_t initial, uint16_t poly)
    return crc16(message, nBytes, reverse_8, straight_16, initial, poly);
Hi
I have done that and can't find any CRC calculator that give the same result :throwpc:
I got these data:
0x00, 0x01, 0x02, 0x80, 0xe2, 0x45, 0x00, 0x00, 0x00, 0x00, 0x07, 0xdf, 0x33, 0x00, 0x00, 0x00, 0x0f, 0xeb, 0x02, 0x80, 0xe2, 0x45, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
and expect this CRC16: 0xcd58
regards Bjarne
Edited by Bjarne Joergensen
Hi
I got these data:
regards Bjarne
If you can't give me some numbers I can put straight into LabVIEW, I'm not going to even try.:P You also haven't told us what the polynomial is so we don't know which flavour of CRC it actually is.
Google should have told you that the code is 3/5ths of "this one"
Once you know which flavour just put LabVIEW in front of your search term (e.g. LabVIEW CRC16 xmodem) and you will find plenty of pre-written VIs like "The Inline CRC Reference Library",
I don't see any issues with the algo at first glance. You did say it used bit reverse (the two other functions) and I don't see you doing that, however.
