Ravinath Posted January 17, 2018 Report Posted January 17, 2018 Hye.Im trying to connect GD02Rev2.0 (driver for the g15 cube servo) with myRio. I have to connect the Rx Tx and Control pin of the driver to the myRio to run the motor. It seems like i have to create serial communication in labview.Can anyone help me on this.thanks.The driver looks like below: Quote
hooovahh Posted January 17, 2018 Report Posted January 17, 2018 Crosspost I've never used this product, or MyRIO at all, sorry. Quote
Jordan Kuehn Posted January 17, 2018 Report Posted January 17, 2018 Have you tried using the UART lines on the myRIO in conjunction with the express vi? If that doesn't work (it should) you could attempt to install linux drivers for a USB to Serial converter on the myRIO. Good luck though. Quote
infinitenothing Posted January 17, 2018 Report Posted January 17, 2018 I'm not sure what the myRIO has built in (USBtoSerial drivers built in? CLIP?) but if you had to, you could always just program the FPGA and use a level shifter: Quote
hooovahh Posted January 17, 2018 Report Posted January 17, 2018 Oh there are plenty of USB to Serial converters that will show up and work and you can use them using the standard VISA calls. There are also UART TX and RX converters to RS-232 like the MAX232 or the one you linked to. But is your device actually RS-232 serial? I'm not so certain but again I've never used that hardware. Read up on the documentation. Either way you can come up with something that works. Quote
Jordan Kuehn Posted January 17, 2018 Report Posted January 17, 2018 5 minutes ago, hooovahh said: Oh there are plenty of USB to Serial converters that will show up and work and you can use them using the standard VISA calls. From the one project I had with a myRIO I think some USB cameras will work and I think I got a usb to ethernet device to work without installing drivers. I would be surprised if a regular USB to Serial converter would work out of the box on a myRIO, but is theoretically possible. Quote
hooovahh Posted January 17, 2018 Report Posted January 17, 2018 This advice is based on the fact that other Linux RT devices enumerate USB to Serial converters without any additional work. https://forums.ni.com/t5/NI-Linux-Real-Time-Documents/USB-Devices-tested-on-NI-Linux-RT-myRIO-cRIO-9068/ta-p/3522002 Every USB to serial converter I've tried has worked in my 9134 (mix of Prolific and FTDI). I've also seen posts where people talk about plugging in Arduinos to a MyRIO which enumerated as a VISA device, but again I have no experience with this. Quote
Rolf Kalbermatter Posted January 18, 2018 Report Posted January 18, 2018 14 hours ago, hooovahh said: This advice is based on the fact that other Linux RT devices enumerate USB to Serial converters without any additional work. https://forums.ni.com/t5/NI-Linux-Real-Time-Documents/USB-Devices-tested-on-NI-Linux-RT-myRIO-cRIO-9068/ta-p/3522002 Every USB to serial converter I've tried has worked in my 9134 (mix of Prolific and FTDI). I've also seen posts where people talk about plugging in Arduinos to a MyRIO which enumerated as a VISA device, but again I have no experience with this. Depending on the LabVIEW realtime version used it may be necessary to add an extra configuration file to the system (this is for Linux based cRIOs but should be the same for myRIO): For FTDI based devices this usually seems to work out of the box, but your mileage may vary depending on the USB vendor and product IDs used by the manufacturer of the device. But the NI Linux realtime kernel has additional drivers to support other adapters too. The first check is to run lsmod from a command line on the controller (you know what SSH is, don't you) to see what module drivers are currently loaded. First run it before the adapter is plugged in after a full reset of the system and then after plugging in the adapter. There should be at least one new driver module loaded which has usbserial as parent. If this already fails the adapter is not recognized by the Linux USB subsystem. Once lsmod has shown a driver to be loaded make sure the adapter is plugged in and then look for /dev/ttyUSB devices by entering ls -l /dev/ttyUSB* on the command line. This should give a listing similar to: crw-rw-rw- 1 admin tty 188, 1 Oct 28 02:43 /dev/ttyUSB0 Important here is that at least the first two rw- are present and that the group (after the admin owner) is set to tty. If VISA recognizes the port but lists it as Not Present one of these settings is most likely wrong. To change the permissions with which a specific device is mounted by the kernel device discovery subsystem there are two different methods depending on which Linux kernel version is used. NI Linux Realtime 2013 This uses the old mdev system to add dynamic devices. Make sure to add following line to /etc/mdev.conf ttyUSB[0-9]* root:tty 666 Possibly the root entry should be replaced by whatever the login name of the administrative account is on that system (admin). NI Linux Realtime 2014 (and supposedly newer) This uses the newer udev system to add dynamic devices. Create a text file with the name ttyUSB.rules with following contents: KERNEL=="ttyUSB[0-9]*", GROUP="tty", MODE="666" Add this file into this directory: /etc/udev/rules.d 1 Quote
Ravinath Posted January 19, 2018 Author Report Posted January 19, 2018 On 1/18/2018 at 1:49 AM, Jordan Kuehn said: Have you tried using the UART lines on the myRIO in conjunction with the express vi? If that doesn't work (it should) you could attempt to install linux drivers for a USB to Serial converter on the myRIO. Good luck though. UART means to connect the Tx and Rx.but how about the control pin?can you get me any examples to create the vi in labview?thanks Quote
hooovahh Posted January 19, 2018 Report Posted January 19, 2018 Are you asking about how to use UART on a myRIO? Someone already mentioned using the express VI, but here is a video demonstrating it. You may also be interested in the myRIO Essentials Guide, which has videos and instructions on how to connect to various sensors. Quote
Ravinath Posted February 1, 2018 Author Report Posted February 1, 2018 (edited) hye.I have attached the datasheet of the driver and the servo.can you help me on how to create the communication in labview?thanks G15_CubeServo_UserManual.pdf GD02 Rev2.0 User's_Manual.pdf Edited February 1, 2018 by Ravinath Quote
infinitenothing Posted February 1, 2018 Report Posted February 1, 2018 Have you tried the express VI? It looks like you don't need a shifter. Quote
Ravinath Posted February 2, 2018 Author Report Posted February 2, 2018 (edited) 10 hours ago, infinitenothing said: Have you tried the express VI? It looks like you don't need a shifter. hye i have found this. but not sure how to use this concept to run the servo Edited February 2, 2018 by Ravinath Quote
Ravinath Posted February 11, 2018 Author Report Posted February 11, 2018 On 1/18/2018 at 1:49 AM, Jordan Kuehn said: Have you tried using the UART lines on the myRIO in conjunction with the express vi? If that doesn't work (it should) you could attempt to install linux drivers for a USB to Serial converter on the myRIO. Good luck though. On 2/2/2018 at 4:24 AM, infinitenothing said: Have you tried the express VI? It looks like you don't need a shifter. hye i have the arduino coding to run the servo motor.can you know how to convert it into the labview software?thanks Quote
infinitenothing Posted February 14, 2018 Report Posted February 14, 2018 Are you looking for an automated tool or free labor? If it's the former, I don't know of one. Quote
Ravinath Posted March 3, 2018 Author Report Posted March 3, 2018 can help me on this construction? i have created the serial communication in labview as below.but im not sure whether the the construction for the control pin is correct or not.by the way i want to run the g15 cube servo with gd02 rev 2.0 driver. Quote
JKSH Posted March 7, 2018 Report Posted March 7, 2018 On 2/11/2018 at 7:21 PM, Ravinath said: hye i have the arduino coding to run the servo motor.can you know how to convert it into the labview software?thanks On 3/3/2018 at 5:33 PM, Ravinath said: can help me on this construction? i have created the serial communication in labview as below.but im not sure whether the the construction for the control pin is correct or not.by the way i want to run the g15 cube servo with gd02 rev 2.0 driver. Please understand: All of this is a lot of work! It can take several days of full-time work to finish. It is not reasonable to expect people on this forum to do your work for free. Someone needs to read through the data sheets. They might need to reverse-engineer the Cyton G15 shield hardware and/or code. Then, they need to make wires between the myRIO and the GD02, and make wires between the GD02 and the servo. They also need to write software for the myRIO to communicate with the GD02. Finally, they need to test everything. You should either hire someone to teach you how to do all of this, or hire someone to do it for you. Quote
Ravinath Posted March 7, 2018 Author Report Posted March 7, 2018 7 hours ago, JKSH said: Please understand: All of this is a lot of work! It can take several days of full-time work to finish. It is not reasonable to expect people on this forum to do your work for free. Someone needs to read through the data sheets. They might need to reverse-engineer the Cyton G15 shield hardware and/or code. Then, they need to make wires between the myRIO and the GD02, and make wires between the GD02 and the servo. They also need to write software for the myRIO to communicate with the GD02. Finally, they need to test everything. You should either hire someone to teach you how to do all of this, or hire someone to do it for you. anyway thanks sir.i will try my best Quote
