grjgrj Posted August 22, 2018 Report Posted August 22, 2018 Hello. I need change some code for SbRIO-9626 with LabVIEW 2018. I have code from LabVIEW 2015. Right now I have only LabVIEW 2018. And I worked with it for SbRIO-9627. LabVIEW FPGA, LabVIEW Real-Time, NICRIO1800 driver istalled. And I install Xilinx ISE 11.5 Compilation Tool too. When I start compilation FPGA VI I got error about problem with compilation too (see attachment picture). Could you tell me how I can solve this problem? It is very important. Quote
Francois Normandin Posted August 22, 2018 Report Posted August 22, 2018 (edited) Have you checked the compatibility chart for getting the right version?http://www.ni.com/product-documentation/53056/en/ sbRIO-9627 is a Zynq FPGA. Check if ISE 14.7 might be reqiured. Edited August 22, 2018 by Francois Normandin Quote
infinitenothing Posted August 22, 2018 Report Posted August 22, 2018 Cross posted: https://forums.ni.com/t5/Real-Time-Measurement-and/LabVIEW-2018-and-SbRIO-9626/td-p/3830776 Quote
Susannaa Posted August 29, 2018 Report Posted August 29, 2018 (edited) Hello there where can i find the now using dianabol link of Use Vivado 2017 let me khnow if you have thanks Edited October 6, 2018 by Susannaa Quote
infinitenothing Posted August 30, 2018 Report Posted August 30, 2018 Search the downloads page on their site or try this: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/ssnav:dwl/q/vivado/ Quote
