deleting a portion of a string not an array
I have tried repeatably to delete the last few letters from a specific array.
I can not get it to work with the subset function nor the delete portion of array function.
Any suggestions?
Your post is a bit confusing as you're interchanging string and array terms. Cleaning that up and posting a bit of what you've tried would help people give better feedback. It sounds like you're using primitives that would do what you want, so it would be helpful to see how you are using them.
Michael, technically what you write is only true for an input array of exactly 5 elements. If you really always want to remove the last three elements the OP needs to use an Array Length node, subtract the number of elements he wants to remove from this length and wire that to the offset. In that case you can leave the size input unwired because it will default to the rest of the array.
Expand
That's too complicated.  Just wire the 3 to the Length and leave the Index unwired.  Delete From Array will default to deleting from the end.
The OP didn't clarify his requirements so we could all be wrong. But ya, all you guys say is true. - Thanks.
My intent was to start the conversation, not to provide the best solution. I just wanted to show how the delete from array works and to provide some visuals.
