Image grab without IMAQdx
I'd like to grab images from a USB 3 camera without using IMAQdx. Has anyone tried talking to a camera through the manufacturer's SDK. Basler has their Pylon SDK; FLIR has Spinnaker; Omron has their own SDK; etc. Doing this would require creating wrappers for the dll's in the SDK, and I wonder if anyone has done something similar.
We did such a thing for dalsa camera. It indeed require to write wrapping functions, but there is a help which describes how IMAQ image is stored in the memory so you should be able to cast vendor image format to LV IMAQ.
If you do not need any suphisticated camera and acquisition control this library is pretty basic and I have used it with success.
I might be missing something but I do not think that OpenCV has a good cam acquisition support.
I have wrapped the needed parts of the Pylon .NET SDK, which was reasonably easy.
The one thing which might help you with that specific one is that after you grab an image (either with a grab method or with a callback event), you can get the pixel data by getting the PixelData property from the grab result, calling .NET Object to Variant.vi on it and then converting the variant to a 1D U8 array. Note this could be an array with 3 bytes per pixel, which matches the LV picture control flattened format, or 1 byte per pixel, in which case you need to create a grayscale color table.
  • 3 years later...
Hi Yair - Would you mind sharing some example code to grab an image using the Pylon .net interface?
Edited by viSci
In that case, I would suggest posting something here in case others want it in the future. I don't remember offhand where I used that API and a quick search didn't reveal anything.
  • 1 month later...
In the past I have used the IMAQ drivers for getting the image, which on its own does not require any additional runtime license.  It is one of those lesser known secrets that acquiring and saving the image is free, but any of the useful tools have a development, and deployment license associated with it.  I've also had mild success with leveraging VLC.  Here is the library I used in the past, and here is another one I haven't used but looks promising.  With these you can have a live stream of a camera as long as VLC can talk to it, and then pretty easily save snapshots.
EDIT: The NI software for getting images through IMAQ for free is called "NI Vision Common Resources". This LAVA thread is where I first learned about it.
  • Like 2
