CRC sub vi
I have a sub vi that I have used to calculate the CRC for a set of data. It works perfectly, as the data stays the same the crc stays the same. I have run into this issue where once I implement the sub vi into the main Vi the CRC value will change every time I hit run when the data has not changed.
If there is a reason why it is happening or if anyone knows how to fix it that would be great
thank you
thank you
Can you post your code?
Here is the CRC conversion that I used in one of the sub vi. This works properly. In my main VI, everything is within an event structure in a while loop. Would that be why the CRC updates every time?
