lelluzo Posted July 26, 2007 Report Posted July 26, 2007 I need to save multiple file from a site. Every file have to be dowloaded anda saved in a folder. I try Activex or .vi found in the net but them can save only text or html. For me is good to dowload the raw file of pdf and in second time with Reader i will open it. I already tried whith WinInet but not good idea. Thank you lelluzo Quote
Eugen Graf Posted July 26, 2007 Report Posted July 26, 2007 You can install a PDF-Printer to Print anything to PDF with Print Report.vi (you can find it in Report Palette). Eugen Quote
Karissap Posted July 27, 2007 Report Posted July 27, 2007 You could use a program like wget It will be able to download pdfs from the internet. You could call it from the command line using System Exec.vi Quote
MikaelH Posted July 27, 2007 Report Posted July 27, 2007 QUOTE(lelluzo @ Jul 26 2007, 07:27 AM) I need to save multiple file from a site. Every file have to be dowloaded anda saved in a folder.I try Activex or .vi found in the net but them can save only text or html. For me is good to dowload the raw file of pdf and in second time with Reader i will open it. I already tried whith WinInet but not good idea. Thank you lelluzo Just use the DataSocker Read, and save the file. http://forums.lavag.org/index.php?act=attach&type=post&id=6458 Also see: http://forums.lavag.org/index.php?showtopic=100 //Mikael Quote
jbrohan Posted July 27, 2007 Report Posted July 27, 2007 I use cURL. It is a very powerful way of interacting with websites. You can upload and download any type of file and start web pages. This is very handy to run .php files from your Vi. http://curl.netmirror.org/docs/faq.html John Quote
orko Posted July 27, 2007 Report Posted July 27, 2007 QUOTE(MikaelH @ Jul 25 2007, 06:17 PM) Just use the DataSocket Read, and save the file. I really like this one :thumbup: The cool thing is that you can download binary files such as pictures, movies, pdfs, etc. using this method. *Note! This works great if you're saving a text file (txt,html,xml,etc) but if you're saving a binary file (jpg,pdf,etc) you'll have to write the string to the "write to binary file" primative versus the "write to text file" primative or you'll get data corruption. Just because you are able to download it through the datasocket using the [text] format doesn't mean it's a text file... Question: does anyone know of a complete list of URL format speficiers ( [text], , etc) somewhere I can stare at? I also am curious what is handling these specifiers... is it your default browser, or some core TCP/IP functions of the OS? Quote
LAVA 1.0 Content Posted July 27, 2007 Report Posted July 27, 2007 QUOTE(orko @ Jul 26 2007, 11:52 AM) Question: does anyone know of a complete list of URL format speficiers ( [text], , etc) somewhere I can stare at? I also am curious what is handling these specifiers... is it your default browser, or some core TCP/IP functions of the OS?If I understand your question, it's your browser that is handling this; they are referred to as Mime types[/post]What does the internet have to do with Marcel Marceau? I have no idea (OK I was a mime; and can still do the walk and box and rope shtick.) Quote
crelf Posted July 27, 2007 Report Posted July 27, 2007 QUOTE(LV Punk @ Jul 27 2007, 03:25 AM) (OK I was a mime; and can still do the walk and box and rope shtick.) This I gotta see! Are you coming to NI-Week? Quote
orko Posted July 27, 2007 Report Posted July 27, 2007 QUOTE(LV Punk @ Jul 26 2007, 10:25 AM) If I understand your question, it's your browser that is handling this; they are referred to as http://en.wikipedia.org/wiki/Mime_type' target="_blank">Mime types Okay, thanks. I understand mime types, and how they are used in HTTP headers, but I'm a little confused on how they are used in the datasocket implementation. Am I wrong in assuming that the Datasocket Read VI only supports a limited subset of these mime types? Which ones does it support, if this is true? I know [text] and work, but are there others?One thing I noticed is that even though "html" is accepted, it isn't a real mime type since it's actually "text/html". In fact "text" isn't a valid mime type either, its "text/plain". I'm assuming that the Datasocket VI's are coded to only allow certain "keywords" of supported types rather than mime types as valid in the URL. I'm not even sure it really handles "[text]" and "[html]" differently...does it? Quote
Yair Posted July 27, 2007 Report Posted July 27, 2007 QUOTE(orko @ Jul 26 2007, 10:18 PM) One thing I noticed is that even though "html" is accepted, it isn't a real mime type since it's actually "text/html". I'm assuming that the Datasocket VI's are coded to only allow certain "keywords" rather than mime types as valid in the URL. The way I understand it, the [text] part has nothing to do with MIME types and simply tells the primitive to retrieve whatever is at that URL as binary data represented as a string. Quote
orko Posted July 27, 2007 Report Posted July 27, 2007 QUOTE(yen @ Jul 26 2007, 12:23 PM) binary data represented as a string ...as opposed to what? Are there other "[tag]" operations that can be done with the Datasocket primatives to obtain data in another form? I'm confused because the "type" input of the primative is what I thought defined the data type. Quote
Yair Posted July 27, 2007 Report Posted July 27, 2007 The type input defines the LabVIEW data type (e.g. you might be sent a 1D array of DBL), but the data you download from the web is not a LabVIEW string. You just want it as a LabVIEW string because that's how your file primitives let you save binary data so you have to tell it "don't do any type checking and conversion. Just get me the data". Quote
orko Posted July 28, 2007 Report Posted July 28, 2007 Hmm... that's the way I understood the type input. The "[text]" or " " endings on the URL's are still are a mystery to me, since they don't seem to behave any differently from one another.This test returned true (they were equal) no matter what type of file (jpg,pdf,html,txt) I was trying to download from the internet:http://forums.lavag.org/index.php?act=attach&type=post&id=6466Since I can't seem to find any documentation on the differences between these two, I'll just assume they react exactly the same. I was just wondering if there were other capabilities (other "[tags]") inside the Datasocket Read primative that behaved differently.Thanks for your time, and sorry for hijacking this thread a bit Quote
LAVA 1.0 Content Posted July 28, 2007 Report Posted July 28, 2007 QUOTE(crelf @ Jul 26 2007, 02:33 PM) This I gotta see! Are you coming to NI-Week? Unfortunately, no. I'll try and dig up an old picture at home and scan it in. Maybe I'll update my avatar Quote
LAVA 1.0 Content Posted July 28, 2007 Report Posted July 28, 2007 QUOTE(orko @ Jul 26 2007, 03:18 PM) One thing I noticed is that even though "html" is accepted, it isn't a real mime type since it's actually "text/html". In fact "text" isn't a valid mime type either, its "text/plain". I'm assuming that the Datasocket VI's are coded to only allow certain "keywords" of supported types rather than mime types as valid in the URL. I'm not even sure it really handles "[text]" and " " differently...does it?If you try to retrieve a PDF file (or other binarary file) without the [text] suffix, the Datasocket Read function throws an undefined error (-2146797887).It's a wild guess on my part, but maybe the text/html tags have something to do identifying extended character sets for non-english versions of LabVIEW. It would be nice if the Datasocket read returned the content-type as a string; then you could use a case to determine how to process (present) the data. If the content-type was "image/jpeg" you could convert it to a pixmap like crelf did here[/post], you could write the content (string) to a file and then pass it to my IE Dialog box located here, or use [color=#006400]system exec[/color] to open the file. Quote
Yair Posted July 28, 2007 Report Posted July 28, 2007 QUOTE(LV Punk @ Jul 27 2007, 04:13 PM) It would be nice if the Datasocket read returned the content-type as a string; I don't think that can be done. MIME types are relevant if you're handling binary data as an attachment or embedded content. In this case, you're simply asking the server for a file, so there should not be any MIME data. Quote
orko Posted July 28, 2007 Report Posted July 28, 2007 QUOTE(yen @ Jul 27 2007, 06:30 AM) I don't think that can be done. MIME types are relevant if you're handling binary data as an attachment or embedded content. In this case, you're simply asking the server for a file, so there should not be any MIME data. MIME types (media types) are also relevant in all HTTP response headers and are given in the "content-type" header on all HTTP 1.0 and 1.1 requests for files. That's one of the reasons I asked if the default browser was handling the requests for files (vs. NI using native TCP and parsing out the headers themselves). If they are just passing the request to IE or Netscape, then they might not have access to all of these server response headers in the Datasocket VIs themselves. One other caveat is that each protocol that is supported (ftp,http,psp,dstp,opc,etc) would require special handling to support grabbing the content-type, if that information is available at all. The DataSocket Read VI is still my choice in retrieving files from the internet, but when I need to know more information out of the HTTP headers (like content-type) I think the easiest method is to use TCP to get them (via a HEAD request). http://forums.lavag.org/index.php?act=attach&type=post&id=6480''>http://forums.lavag.org/index.php?act=attach&type=post&id=6480'>http://forums.lavag.org/index.php?act=attach&type=post&id=6480 Quote
Yair Posted July 29, 2007 Report Posted July 29, 2007 QUOTE(orko @ Jul 27 2007, 06:56 PM) That's one of the reasons I asked if the default browser was handling the requests for files (vs. NI using native TCP and parsing out the headers themselves). If they are just passing the request to IE or Netscape, then they might not have access to all of these server response headers in the Datasocket VIs themselves. I would highly doubt that any external browser is used, but I don't know much about this. It just would not seem to make much sense. Quote
netmirrorapp78 Posted 1 hour ago Report Posted 1 hour ago NetMirror can make it easier to save or access PDF files from websites when the browser does not provide a straightforward option. Open the webpage through NetMirror and locate the PDF file you want to save. Once the PDF loads, use the available download or save option to store it on your device. If the website opens the PDF in a separate viewer then use that viewer’s download button. Make sure you only save files that you have permission to access. Quote
netmirrorsapp17 Posted 1 hour ago Report Posted 1 hour ago You can save a PDF file from a website using NetMirror by opening the page and selecting the PDF file. If the file opens in the browser you can use the download option to save it to your device. NetMirror can be useful when you want to access web content on a larger screen. However make sure you only download files that you are allowed to access and save. Quote
vedapp1 Posted 56 minutes ago Report Posted 56 minutes ago You can save a PDF file from a website by opening the page in your browser and selecting the Print option. Then choose Save as PDF and select your preferred folder. With the Vedu App you can also keep your entertainment content organized and easy to access. Quote
