Popular Post hooovahh Posted January 8 Popular Post Report Posted January 8 So a couple of years ago I was reading about the ZLIB documentation on compression and how it works. It was an interesting blog post going into how it works, and what compression algorithms like zip really do. This is using the LZ77 and Huffman Tables. It was very education and I thought it might be fun to try to write some of it in G. The deflate function in ZLIB is very well understood from an external code call and so the only real ever so slight place that it made sense in my head was to use it on LabVIEW RT. The wonderful OpenG Zip package has support for Linux RT in version 4.2.0b1 as posted here. For now this is the version I will be sticking with because of the RT support. Still I went on my little journey trying to make my own in pure LabVIEW to see what I could do. My first attempt failed immensely and I did not have the knowledge, to understand what was wrong, or how to debug it. As a test of AI progression I decided to dig up this old code and start asking AI about what I could do to improve my code, and to finally have it working properly. Well over the holiday break Google Gemini delivered. It was very helpful for the first 90% or so. It was great having a dialog with back and forth asking about edge cases, and how things are handled. It gave examples and knew what the next steps were. Admittedly it is a somewhat academic problem, and so maybe that's why the AI did so well. And I did still reference some of the other content online. The last 10% were a bit of a pain. The AI hallucinated several times giving wrong information, or analyzed my byte streams incorrectly. But this did help me understand it even more since I had to debug it. So attached is my first go at it in 2022 Q3. It requires some packages from VIPM.IO. Image Manipulation, for making some debug tree drawings which is actually disabled at the moment. And the new version of my Array package 3.1.3.23. So how is performance? Well I only have the deflate function, and it only is on the dynamic table, which only gets called if there is some amount of data around 1K and larger. I tested it with random stuff with lots of repetition and my 700k string took about 100ms to process while the OpenG method took about 2ms. Compression was similar but OpenG was about 5% smaller too. It was a lot of fun, I learned a lot, and will probably apply things I learned, but realistically I will stick with the OpenG for real work. If there are improvements to make, the largest time sink is in detecting the patterns. It is a 32k sliding window and I'm unsure of what techniques can be used to make it faster. ZLIB G Compression.zip 4 1 Quote
Rolf Kalbermatter Posted Monday at 01:10 PM Report Posted Monday at 01:10 PM (edited) On 1/8/2026 at 10:37 PM, hooovahh said: So a couple of years ago I was reading about the ZLIB documentation on compression and how it works. It was an interesting blog post going into how it works, and what compression algorithms like zip really do. This is using the LZ77 and Huffman Tables. It was very education and I thought it might be fun to try to write some of it in G. The deflate function in ZLIB is very well understood from an external code call and so the only real ever so slight place that it made sense in my head was to use it on LabVIEW RT. The wonderful OpenG Zip package has support for Linux RT in version 4.2.0b1 as posted here. For now this is the version I will be sticking with because of the RT support. Still I went on my little journey trying to make my own in pure LabVIEW to see what I could do. My first attempt failed immensely and I did not have the knowledge, to understand what was wrong, or how to debug it. As a test of AI progression I decided to dig up this old code and start asking AI about what I could do to improve my code, and to finally have it working properly. Well over the holiday break Google Gemini delivered. It was very helpful for the first 90% or so. It was great having a dialog with back and forth asking about edge cases, and how things are handled. It gave examples and knew what the next steps were. Admittedly it is a somewhat academic problem, and so maybe that's why the AI did so well. And I did still reference some of the other content online. The last 10% were a bit of a pain. The AI hallucinated several times giving wrong information, or analyzed my byte streams incorrectly. But this did help me understand it even more since I had to debug it. So attached is my first go at it in 2022 Q3. It requires some packages from VIPM.IO. Image Manipulation, for making some debug tree drawings which is actually disabled at the moment. And the new version of my Array package 3.1.3.23. So how is performance? Well I only have the deflate function, and it only is on the dynamic table, which only gets called if there is some amount of data around 1K and larger. I tested it with random stuff with lots of repetition and my 700k string took about 100ms to process while the OpenG method took about 2ms. Compression was similar but OpenG was about 5% smaller too. It was a lot of fun, I learned a lot, and will probably apply things I learned, but realistically I will stick with the OpenG for real work. If there are improvements to make, the largest time sink is in detecting the patterns. It is a 32k sliding window and I'm unsure of what techniques can be used to make it faster. ZLIB G Compression.zip 348.33 kB · 4 downloads Great effort. I always wondered about that, but looking at the zlib library it was clear that the full functionality was very complex and would take a lot of time to get working. And the biggest problem I saw was the testing. Bit level stuff in LabVIEW is very possible but it is also extremely easy to make errors (that's independent of LabVIEW btw) so getting that right is extremely difficult and just as difficult to proof consistently. Performance is of course another issue. LabVIEW allows a lot of optimizations but when you work on bit level, the individual overhead of each LabVIEW function starts to add up, even if it is in itself just tiny fractions of microseconds. LabVIEW functions do more consistency checking to make sure nothing will crash ever because of out of bounds access and more. That's a nice thing and makes debugging LabVIEW code a lot easier, but it also eats performance, especially if these operations are done in inner loops million of times. Cryptography is another area that has similar challenges, except that security requirements are even higher. Assumed security is worse than no security. I have done in the past a collection of libraries to read and write image formats for TIFF, GIF and BMP. And even implemented the somewhat easier LZW algorithm used in some TIFF and GIF files. On the basic it consists of a collection of stream libraries to access files and binary data buffers as a stream of bytes or bits. It was never intended to be optimized for performance but for interoperability and complete platform independence. One partial regret I have is that I did not implement the compression and decompression layer as a stream based interface. This kind of breaks the easy interchangeability of various formats by just changing the according stream interface or layering an additional stream interface in the stack. But development of a consistent stream architecture is one of the more tricky things in object oriented programming. And implementing a decompressor or compressor as a stream interface is basically turning the whole processing inside out. Not impossible to do, but even more complex than a "simple" block oriented (de)compressor. And also a lot harder to debug. Last but not least it is very incomplete. TIFF support is only for a limited amount of sub-formats, the decoding interface is somewhat more complete while the encoding part only supports basic formats. GIF is similar and BMP is just a very rudimentary skeleton. Another inconsistency is that some interfaces support the input and output to and from IMAQ while others support the 2D LabVIEW Pixmap, and the TIFF output supports both for some of the formats. So it's very sketchy. I did use that library recently in a project where we were reading black/white images from IMAQ which only supports 8 bit greyscale images but the output needed to be 1-bit TIFF data to transfer to a inkjet print head. The previous approach was to save a TIFF file in IMAQ, which was stored as 8-bit grey scale with only really two different values and then invoke an external command to convert the file to 1 bit bi-level TIFF and transfer that to the printer. But that took quite a bit of time and did not allow to process the required 6 to 10 images per second. With this library I could do the full IMAQ to 1-bit TIFF conversion consistently in less than 50 ms per image including writing the file to disk. And I always wondered about what would be needed to extend the compressor/decompressor with a ZLIB inflate/deflate version which is another compression format used in TIFF (and PNG but I haven't considered that yet). The main issue is that adding native JPEG support would be a real hassle as many PNG files use internally a form of JPEG compression for real life images. Edited Monday at 01:27 PM by Rolf Kalbermatter Quote
hooovahh Posted Tuesday at 01:11 PM Author Report Posted Tuesday at 01:11 PM Yes I'm trying to think about where I want to end this endeavor. I could support the storage, and fixed tables modes, which I think are both way WAY easier to handle then the dynamic table it already has. And one area where I think I could actually make something useful, is in compression of CAN frame data and storage. zLib compression works on detecting repeating patterns. And raw CAN data for a single frame ID is very often going to repeat values from that same ID. But the standard BLF log file doesn't order frames by IDs, it orders them by time stamps. So you might get a single repeated frame, but you likely won't have huge repeating sections of a file if they are ordered this way. zLib has a concept of blocks, and over the weekend I thought about how each block could be a CAN ID, compressing all frames from just that ID. That would have huge amounts of repetition, and would save lots of space. And this could be very multi-threaded operation since each ID could be compressed at once. I like thinking about all this, but the actual work seems like it might not be as valuable to others. I mean who need yet another file format, for an already obscure log data? Even if it is faster, or smaller? I might run some tests and see what I come up with, and see if it is worth the effort. As for debugging bit level issues. The AI was pretty decent at this too. I would paste in a set of bytes and ask it to figure out what the values were for various things. It would then go about the zlib analysis and tell me what it thought the issue was. It hallucinated a couple of times, but it did fairly well. Yeah performance isn't wonderful, but it also isn't terrible. I think some direct memory manipulation with LabVIEW calls could help, but I'm unsure how good I can make it, and how often rusty nails in the attic will poke me. I think reading and writing PNG files with compression would be a good addition to the LabVIEW RT tool box. At the moment I don't have a working solution for this, but suspect that if I put some time into I could have something working. I was making web servers on RT that would publish a page for controlling and viewing a running VI. The easiest way to send image data over was as a PNG, but the only option I found was to send it as uncompressed PNG images which are quite a bit larger than even the base level compression. I do wonder why NI doesn't have a native Deflate/Inflate built into LabVIEW. I get that if they use the zlib binaries they need a different one for each target, but I feel that that is a somewhat manageable list. They already have to support creating Zip files on the various targets. If they support Deflate/Inflate, they can do the rest in native G to support zip compression. Quote
Rolf Kalbermatter Posted Tuesday at 02:11 PM Report Posted Tuesday at 02:11 PM (edited) 1 hour ago, hooovahh said: I do wonder why NI doesn't have a native Deflate/Inflate built into LabVIEW. I get that if they use the zlib binaries they need a different one for each target, but I feel that that is a somewhat manageable list. They already have to support creating Zip files on the various targets. If they support Deflate/Inflate, they can do the rest in native G to support zip compression. They absolutely do! The current ZIP file support they have is basically simply the zlib library AND the additional ZIP/UNZIP example provided with it in the contribution order of the ZLIB library. It used to be quite an old version and I'm not sure if and when they ever really upgraded it to later ZLIB versions. I stumbled over that fact when I tried to create shared libraries for realtime targets. When creating on for the VxWorks OS I never managed to load it at all on a target. Debugging that directly would have required an installation of the Diabolo compiler toolchain from VxWorks which was part of the VxWorks development SDK and WAAAAYYY to expensive to even spend a single thought about trying to use it. After some back and forth with an NI engineer he suggested I look at the export table of the NI-RT VxWorks runtime binary, since VxWorks had the rather huge limitation to only have one single global symbol export table where all the dynamic modules got their symbols registered, so you could not have two modules exporting even one single function with the same name without causing the second module to fail to load. And lo and behold there were pretty much all of the zlib zip/unzip functions in that list and also the zlib functions itself. After I changed the export symbol names of all the functions I wanted to be able to call from my OpenG ZIP library with an extra prefix I could suddenly load my module and call the functions. Why not use the function in the LabVIEW kernel directly then? 1) Many of those symbols are not publicly exported. Under VxWorks you do not seem to have a difference between local functions and exported functions, they all are loaded into the symbol table. Under Linux ELF, symbols are per module in a function table but marked if they are visible outside the module or not. Under Windows, only explicitly exported functions are in the export function table. So under Windows you simply can't call those other functions at all, since they are not in the LabVIEW kernel export table unless NI adds them explicitly to the export table, which they did only for a few that are used by the ZIP library functions. 2) I have no idea which version NI is using and no control when they change anything and if they modify any of those APIs or not. Relying on such an unstable interface is simply suicide. Last but not least: LabVIEW uses the deflate and inflate functions to compress and decompress various binary streams in its binary file formats. So those functions are there, but not exported to be accessed from a LabVIEW program. I know that they did explicit benchmarks about this and the results back then showed clearly that reducing the binary size of data that had to be read and written to disk by compressing them, resulted in a performance gain despite the extra CPU processing for the compression/decompression. I'm not sure if this would still hold with modern SSD drives connected through NVE but why change it now. And it gave them an extra marketing bullet point in the LabVIEW release notes about reduced file sizes. 😁 Edited Tuesday at 02:18 PM by Rolf Kalbermatter Quote
hooovahh Posted Tuesday at 05:02 PM Author Report Posted Tuesday at 05:02 PM 3 hours ago, Rolf Kalbermatter said: They absolutely do! The current ZIP file support they have is basically simply the zlib library AND the additional ZIP/UNZIP example provided with it in the contribution order of the ZLIB library.... Last but not least: LabVIEW uses the deflate and inflate functions to compress and decompress various binary streams in its binary file formats. So those functions are there, but not exported to be accessed from a LabVIEW program. So then is this what an Idea Exchange should be? Ask NI to expose the Inflate/Deflate zlib functions they already have? I don't mind making it I just want to know what I'm asking for. Also I continued down my CAN logging experiment with some promising results. I took log I had with 500k frames in it with a mix of HS and FD frames. This raw data was roughly 37MB. I created a Vector compatible BLF file, which compresses the stream of frames written in the order they come in and it was 5.3MB. Then I made a new file, that has one block for header information containing, start and end frames, formats, and frame IDs, then two more blocks for each frame ID. One for timestamp data, and another for the payload data. This orders the data so we should have more repeated patterns not broken up by other timestamp, or frame data. This file would be roughly 1.7MB containing the same information. That's a pretty significant savings. Processing time was hard to calculate. Going to the BLF using OpenG Deflate was about 2 seconds. The BLF conversion with my zlib takes...considerably longer. Like 36 minutes. LabVIEW's multithreaded-ness can only save me from so much before limitations can't be overcome. I'm unsure what improvements can be made but I'm not that optimistic. There are some inefficiencies for sure, but I really just can't come close to the OpenG Deflate. Timing my CAN optimized blocks is hard too since I have to spend time organizing it, which is a thing I could do in real time as frame came in if this were in a real application. This does get me thinking though. The OpenG implementation doesn't have a lot of control for how it work at the block level. I wouldn't mind if there is more control over the ability to define what data goes into what block. At the moment I suspect the OpenG Deflate just has one block and everything is in it. Which to be fair I could still work with. Just each unique frame ID would get its own Deflate, with a single block in it, instead of the Deflate containing multiple blocks, for multiple frames. Is that level of control something zlib will expose? I also noticed limitations like it deciding to use the fixed or dynamic table on it's own. For testing I was hoping I could pick what to do. Quote
ShaunR Posted Tuesday at 06:00 PM Report Posted Tuesday at 06:00 PM 29 minutes ago, hooovahh said: Just each unique frame ID would get its own Deflate, with a single block in it, instead of the Deflate containing multiple blocks, for multiple frames. Is that level of control something zlib will expose? I also noticed limitations like it deciding to use the fixed or dynamic table on it's own. For testing I was hoping I could pick what to do. With ZLib you just deflateInit, then call deflate over and over feeding in chunks and then call deflateEnd when you are finished. The size of the chunks you feed in is pretty much up to you. There is also a compress function (and the decompress) that does it all in one-shot that you could feed each frame to. If by fixed/dynamic you are referring to the Huffman table then there are certain "strategies" you can use (DEFAULT_STRATEGY, FILTERED, HUFFMAN_ONLY, RLE, FIXED). The FIXED uses a uses a predefined Huffman code table. 1 Quote
hooovahh Posted Tuesday at 07:09 PM Author Report Posted Tuesday at 07:09 PM 1 hour ago, ShaunR said: With ZLib you just deflateInit, then call deflate over and over feeding in chunks and then call deflateEnd when you are finished. The size of the chunks you feed in is pretty much up to you. There is also a compress function (and the decompress) that does it all in one-shot that you could feed each frame to. If by fixed/dynamic you are referring to the Huffman table then there are certain "strategies" you can use (DEFAULT_STRATEGY, FILTERED, HUFFMAN_ONLY, RLE, FIXED). The FIXED uses a uses a predefined Huffman code table. Thanks but for the OpenG lvzlib I only see lvzlib_compress used for the Deflate function. Rolf I might be interested in these functions being exposed if that isn't too much to ask. Edit: I need to test more. My space improvements with lower level control might have been a bug. Need to unit test. Quote
Rolf Kalbermatter Posted Tuesday at 07:59 PM Report Posted Tuesday at 07:59 PM (edited) 56 minutes ago, hooovahh said: Thanks but for the OpenG lvzlib I only see lvzlib_compress used for the Deflate function. Rolf I might be interested in these functions being exposed if that isn't too much to ask. Actually there is ZLIB Inflate and ZLIB Deflate and Extended variants of both that take in a string buffer and output another one. Extended allows to specify which header format to use in front of the actual compressed stream. But yes I did not expose the lower level functions with Init, Add, and End. Not that it would be very difficult other than having to consider a reasonable control type to represent the "session". Refnum would work best I guess. Edited Tuesday at 08:51 PM by Rolf Kalbermatter Quote
hooovahh Posted Tuesday at 09:06 PM Author Report Posted Tuesday at 09:06 PM 1 hour ago, Rolf Kalbermatter said: Actually there is ZLIB Inflate and ZLIB Deflate and Extended variants of both that take in a string buffer and output another one. Extende allows to specify which header format to use in front of the actual compressed stream. But yes I did not expose the lower level functions with Init, Add, and End. Not that it would be very difficult other than having to consider a reasonable control type to represent the "session". Refnum would work best I guess. I don't see any function name in the DLL mention Deflate/Inflate, just lvzlib_compress and lvzlib_compress2 for the newer releases. Still I don't know if you need to expose these extra functions just for me. I did some more testing and using the OpenG Deflate, and having two single blocks for each ID (Timestamp and payload) still results in a measurable level of improvement on it's own for my CAN log testing. 37MB uncompressed, 5.3MB with Vector compression, and 4.7MB for this test. I don't think that going to multiple blocks within Deflate will have that much of a savings, since the trees, and pairs need to be recreated anyway. What did have a measurable improvement is calling the OpenG Deflate function in parallel. Is that compress call thread safe? Can the VI just be set to reentrant? If so I do highly suggest making that change to the VI. I saw you are supporting back to LabVIEW 8.6 and I'm unsure what options it had. I suspect it does not have Separate Compile code back then. Edit: Oh if I reduce the timestamp constant down to a floating double, the size goes down to 2.5MB. I may need to look into the difference in precision and what is lost with that reduction. Quote
Rolf Kalbermatter Posted Tuesday at 09:21 PM Report Posted Tuesday at 09:21 PM (edited) Well I referred to the VI names really, the ZLIB Inflate calls the compress function, which then calls internally the inflate_init, inflate and inflate_end functions, and the ZLIB Deflate calls the decompress function wich calls accordingly deflate_init, deflate and deflate_end. The init, add, end functions are only useful if you want to process a single stream in junks. It's still only one stream but instead of entering the whole compressed or uncompressed stream as a whole, you initialize a compression or decompression reference, then add the input stream in smaller junks and get every time the according output stream. This is useful to process large streams in smaller chunks to save memory at the cost of some processing speed. A stream is simply a bunch of bytes. There is not inherent structure in it, you would have to add that yourself by partitioning the junks accordingly yourself. Edited Tuesday at 09:58 PM by Rolf Kalbermatter 1 Quote
Rolf Kalbermatter Posted Tuesday at 11:28 PM Report Posted Tuesday at 11:28 PM (edited) 2 hours ago, hooovahh said: Edit: Oh if I reduce the timestamp constant down to a floating double, the size goes down to 2.5MB. I may need to look into the difference in precision and what is lost with that reduction. A Timestamp is a 128 bit fixed point number. It consists of a 64-bit signed integer representing the seconds since January 1, 1904 GMT and a 64-bit unsigned integer representing the fractional seconds. As such it has a range of something like +- 3*10^11 years relative to 1904. That's about +-300 billion years, about 20 times the lifetime of our universe and long after our universe will have either died or collapsed. And the resolution is about 1/2*10^19 seconds, that's a fraction of an attosecond. However LabVIEW only uses the most significant 32-bit of the fractional part so it is "only" able to have a theoretical resolution of some 1/2*10^10 seconds or 200 picoseconds. Practically the Windows clock has a theoretical resolution of 100ns. That doesn't mean that you can get incremental values that increase with 100ns however. It's how the timebase is calculated but there can be bigger increments than 100ns between two subsequent readings (and no increment). A double floating point number has an exponent of 11 bits and 52 fractional bits. This means it can represent about 2^53 seconds or some 285 million years before its resolution gets higher than one second. Scale down accordingly to 285 000 years for 1 ms resolution and still 285 years for 1us resolution. Edited Tuesday at 11:30 PM by Rolf Kalbermatter 1 Quote
Rolf Kalbermatter Posted Tuesday at 11:53 PM Report Posted Tuesday at 11:53 PM 2 hours ago, hooovahh said: What did have a measurable improvement is calling the OpenG Deflate function in parallel. Is that compress call thread safe? Can the VI just be set to reentrant? If so I do highly suggest making that change to the VI. I saw you are supporting back to LabVIEW 8.6 and I'm unsure what options it had. I suspect it does not have Separate Compile code back then. Reentrant execution may be a safe option. Have to check the function. The zlib library is generally written in a way that should be multithreading safe. Of course that does NOT apply to accessing for instance the same ZIP or UNZIP stream with two different function calls at the same time. The underlaying streams (mapping to the according refnums in the VI library) are not protected with mutexes or anything. That's an extra overhead that costs time to do even when it would be not necessary. But for the Inflate and Deflate functions it would be almost certainly safe to do. I'm not a fan of making libraries all over reentrant since in older versions they were not debuggable at all and there are still limitations even now. Also reentrant execution is NOT a panacea that solves everything. It can speed up certain operations if used properly but it comes with significant overhead for memory and extra management work so in many cases it improves nothing but can have even negative effects. Because of that I never enable reentrant execution in VIs by default, only after I'm positively convinced that it improves things. For the other ZLIB functions operating on refnums I will for sure not enable it. It should work fine if you make sure that a refnum is never accessed from two different places at the same time but that is active user restraint that they must do. Simply leaving the functions non-reentrant is the only safe option without having to write a 50 page document explaining what you should never do, and which 99% of the users never will read anyways. 😁 And yes LabVIEW 8.6 has no Separated Compiled code. And 2009 neither. 1 Quote
hooovahh Posted yesterday at 12:46 PM Author Report Posted yesterday at 12:46 PM All very good information thanks for the discussion. I was mostly just interested in reentrant for the ZLIB Deflate VI specifically. For my test I took 65k random CAN frames I had, organized them by IDs, then made something like roughly 60 calls to the deflate, getting compressed blocks for each ID and time. Just to highlight the improvement I turned the compression level up to 9, and it took about 400ms. In the real world the default compression level is just fine. I then set the loop to enable parallelism with 16 instances, which was the default for my CPU. That time to process the same frames at the same compression level took 90ms. In the real world I will likely be trying to handle something like a million frames, in chunks, maybe using pipelining. So the improvement of 4.5 times faster for the same result is a nice benefit if all I need to do is enable reentrant on a single VI. Just something for you to consider, and seems like a fairly low risk on this VI, since we aren't talking to outside resources, just a stream. I'd feel similarly for the Inflate VI. I certainly would not try to access the same stream on two different functions at the same time. Thanks for the info on time. I feel fairly certain that in my application, a double for time is the first easy step to improve log file size and compression. Quote
ShaunR Posted 9 hours ago Report Posted 9 hours ago On 1/13/2026 at 7:09 PM, hooovahh said: Thanks but for the OpenG lvzlib I only see lvzlib_compress used for the Deflate function. Rolf I might be interested in these functions being exposed if that isn't too much to ask. Edit: I need to test more. My space improvements with lower level control might have been a bug. Need to unit test. Yes. Rolf like to wrap DLL's in his own DLL (a philosophy we disagree on). I use the vanilla zlib and minizip in Zlib Library for LabVIEW which has all the functions exposed. Quote
hooovahh Posted 5 hours ago Author Report Posted 5 hours ago 3 hours ago, ShaunR said: Yes. Rolf like to wrap DLL's in his own DLL (a philosophy we disagree on). I use the vanilla zlib and minizip in Zlib Library for LabVIEW which has all the functions exposed. Do you guys also disagree philosophically about sharing your work online? That link doesn't appear to be to a download but a login page, it isn't clear to me if the code is free (as in beer). I assume it isn't free (as in speech). In this situation I think Rolf's implementation meets my needs. I initially thought I needed more low level control, but I really don't. Quote
ShaunR Posted 4 hours ago Report Posted 4 hours ago (edited) 23 minutes ago, hooovahh said: Do you guys also disagree philosophically about sharing your work online? That link doesn't appear to be to a download but a login page, it isn't clear to me if the code is free (as in beer). I assume it isn't free (as in speech). In this situation I think Rolf's implementation meets my needs. I initially thought I needed more low level control, but I really don't. I've never understood the "free (as in beer) or free (as in speech) internet vocabulary. Beer costs and speech has a cost. It's BSD3 and cost my time and effort so it definitely wasn't "free" Rolf's works on other platforms so you should definitely use that, but if you wanted to play around with functions that aren't exported in Rolf's, there is a zlib distribution with a vanilla zlib binary to play with while you wait for a new openg release. Edited 4 hours ago by ShaunR Quote
hooovahh Posted 3 hours ago Author Report Posted 3 hours ago I'm unsure of your tone and intent with text, but I'll do my best to explain the vocabulary. The Free (as in beer) is like when I go to a friends house and they offer me a free beer. I can have this beer, and I am entitled to enjoying it without monetary cost. Of course someone else paid for it, but I get to enjoy it, they shared it with me. I do no have the rights or the freedom to reproduce this beer, market it, and sell it. My free-ness is limited to the license you provide. I guess an equivalent analogy here could be if my friend gives me a beer, but expects me to help him move. It is an agreement we both have. If I am "free to do what I want" that is a different kind of freedom. A freedom that is more like free speech, a right that we have. It isn't as limited as someone giving me a beer, it is closer to someone giving me a beer recipe. Typically this is associated with free open source software. Open source software is free (like beer) someone is giving it to me without having to pay. But the freedom I get goes farther than that. This probably is a problem with the english language, and how words can have many meanings and without context "free" can mean different things. The Beer/Speech is just there to help clear up what kind of free we are talking about. Quote
ShaunR Posted 2 hours ago Report Posted 2 hours ago 1 hour ago, hooovahh said: I'm unsure of your tone and intent with text, The intent was to tell you the software was free (as in BSD licence) and, if had downloaded it, it contains a zlib binary that isn't wrapped. Quote
hooovahh Posted 31 minutes ago Author Report Posted 31 minutes ago Yes thank you I see that now. The link to a login page, private hosting, and the listing for Commercial Pricing at the top of the page made me think it was more restrictive. Quote
