hooovahh Posted June 30 Report Posted June 30 Lets say I have a basic hardware abstraction layer for environmental chambers. Here I have the parent Chamber class, a Simulate Class which overrides the required members, a CSZ, and an Envirotronics which are two makers of chamber hardware. For this example lets say I want to distribute this as 3 different VIPM packages. I have my Hooovahh Chamber.vip, which contains the Parent, and Simulate classes, and I have two others the Hooovahh Chamber >> CSZ.vip, and Hooovahh Chamber >> Envirotronics.vip. On the palette I have the main functions all look similar to this. My main question is about how people handle the Finding and Opening functions? I want these drivers on the palette to be easy to use for my developers. At the moment when you install the main Chamber package it installs the Parent VIs you see, and the Simulate class constant on the Class Constants subpalette. Each child specific package then installs a new class constant in the subpalette. Then when a developer wants to use the Find Chambers, they must wire to it an array of classes to use. Here is an example: Here we have a Find VI that is static dispatch on the parent, with overrides insides for each of the Chamber types. It returns an array of found Chambers which is a cluster. In the cluster is the class for the chamber found, which is used in the Overrides for Open and Close. This works and is fine. But I like the idea of hiding away the class constants, and having more self contained Find VIs for each hardware type. In most cases we know the hardware we want to talk to and it isn't an array of classes on an array of COM ports, but instead the one hardware class we intend to use on the system. What I think I would prefer is some thing more like this: Here the developer gets a dedicated Find VI for each class which is a static dispatch for each child class. They all return the same array of cluster (which would be a data type from the parent) and then that array of found chambers is used in the Parent Open which has overrides for each class inside. In this design I would have the Find for each class installed on the palette under some kind of Find Hardware subpalette. In this case I imagine there would need to be some kind method of keeping each Find from only using one COM port at a time. Either through VIG or Semaphore of some kind. Admittedly this is simplified in the previous example since the Parent would be doing the finding, and would know to only pass a unique COM port to one child at a time. In all of these cases I imagine we have full control over the Parent, and all Children. If anyone develops a new child class, we would roll it into the reuse library as another package which would go through the verification process. Do developers prefer one design over the other? What pros and cons haven't I thought about? Thanks. Quote
ShaunR Posted June 30 Report Posted June 30 (edited) I use a polymorphic VI. It basically just wraps the class constant for this purpose.The user can then have a single VI that they can choose the implementation method from a menu and that ripples down through the class functions. It means you only need 1 VI in the palette for the Open/New/Whatever and, once placed, the the user can change implementations without creating or deleting anything. When there is a single type wired it looks much better because LabVIEW will show the class instance (see below) rather than the generic instance see (above). The drawback is quick-drop (apparently) because you cannot choose a specific instance, only the polymorphic, but I ignore people that complain about that Edited June 30 by ShaunR Quote
hooovahh Posted June 30 Author Report Posted June 30 35 minutes ago, ShaunR said: I use a polymorphic VI. It basically just wraps the class constant for this purpose.The user can then have a single VI that they can choose the implementation method from a menu and that ripples down through the class functions. It means you only need 1 VI in the palette for the Open/New/Whatever and, once placed, the the user can change implementations without creating or deleting anything. The problem I have with that is you need a polymorphic VI that has all of the instances inside it. That creates a dependency that all children are available and installed. In my situation you may only install the Chamber package, and CSZ package. Then the developer only has the parent, and that one child (well 2 there is the simulate). So now where would that polymorphic VI live? In the parent package? Then that creates a circular dependency. I did explore creating an XNode that would look at your current system and drop a VI that had whatever children were available for that target, but that got a bit messy. The reason for having separate packages, is because some child classes, only work on some targets. I may have one chamber that uses a Windows DLL to talk to it over USB. This DLL wouldn't run on Linux RT, and I need to not bring along that child class as dependencies, because that will break the deploy or build, even when that child isn't being directly called. Quote
crossrulz Posted June 30 Report Posted June 30 If you have a specific structure for your chambers (ie everybody is under the "Hooovahh Chamber" directory), you could do a simple lookup and use the Get LV Class Default Value to dynamically load the classes. I do something similar with my HAL already, except I dictate what class to load based on a JSON file. 1 Quote
ShaunR Posted June 30 Report Posted June 30 (edited) 11 minutes ago, crossrulz said: If you have a specific structure for your chambers (ie everybody is under the "Hooovahh Chamber" directory), you could do a simple lookup and use the Get LV Class Default Value to dynamically load the classes. I do something similar with my HAL already, except I dictate what class to load based on a JSON file. That's not the real problem (but the same solution as I was about to suggest). The main issue is the LabVIEW static linking. Traditionally we have gotten around it with conditional disable structures or calling CLFN's with a path. hooovahh has created a class that isn't platform independent, only device independent and is attempting to solve platform dependencies with deployment. I'll have to sleep on it. Edited June 30 by ShaunR Quote
hooovahh Posted June 30 Author Report Posted June 30 5 hours ago, crossrulz said: If you have a specific structure for your chambers (ie everybody is under the "Hooovahh Chamber" directory), you could do a simple lookup and use the Get LV Class Default Value to dynamically load the classes. I do something similar with my HAL already, except I dictate what class to load based on a JSON file. How do you deal with built applications? Your solution sounds fine on Windows, and in a development environment. But if I make an RT or Windows application, it won't know to bring along the child classes into the build if they are called dynamically. Unless I add them as an always include I guess. I think there isn't any way around having to have either a class constant of the children somewhere (like into the Find Parent VI) or to have each child class have it's own Find which is part of it's own class and brought into the builds. I suggested the XNode option just because it could read those files on your Windows disk, then plop down the constants into the generated code. That has complications like only bringing along the classes on your disk, at that time, unless on load the XNode reloads and regenerates code which is a different kind of mess I wouldn't want to deal with. But then again it could be a cool right click feature for reload, or check boxes on what libraries are installed, and which ones to load. And while that is all cool sounding, the very large majority of the time a developer just wants to plop down a single VI, that finds the hardware for that specific hardware type. And then not have to do anything extra to make builds work. Quote
ShaunR Posted July 2 Report Posted July 2 (edited) I'm not sure you can get away without dynamically loading. It seems you are basically wanting a plugin architecture. The problem with platform specific code is, I think, a separate issue. Note that a plugin architecture also solves your "find" since you can only find those that have been installed. The issue then becomes that you were reliant on static binding (class constants) to solve your deployment to target. This is the same as VI refnums. What do you envisage the process to be when you have a chamber that has different implementations depending on platform? Let's say that the CSZ chamber must use TCP for Linux but USB for Windows? Now you don't have a static binding problem for deployment but you still have a platform problem. Edited July 2 by ShaunR Quote
hooovahh Posted July 2 Author Report Posted July 2 6 hours ago, ShaunR said: I'm not sure you can get away without dynamically loading. It seems you are basically wanting a plugin architecture. The problem with platform specific code is, I think, a separate issue. Note that a plugin architecture also solves your "find" since you can only find those that have been installed. The issue then becomes that you were reliant on static binding (class constants) to solve your deployment to target. This is the same as VI refnums. I don't think plugin architecture describes what I'm looking for correctly. Ideally the developer installs packages for the hardware they have. The package can have some idea of the system they have, so like 32bit DLLs can only be installed in 32 bit LabVIEW. I do think that I'm envisioning a static class constant (or VI call) to ensure dependencies are brought along for the build. Which does bring me back to the first question. Do people prefer or use one design over the other? And by that I mean the static dispatch parent with finding classes passed in, or explicit find for each child type? 8 hours ago, ShaunR said: What do you envisage the process to be when you have a chamber that has different implementations depending on platform? Let's say that the CSZ chamber must use TCP for Linux but USB for Windows? Now you don't have a static binding problem for deployment but you still have a platform problem. For that there would either be a separate CSZ TCP, and CSZ USB children, or there would be a CSZ Parent, CSZ TCP, and CSZ USB depending on implementation details and overlap between the two types. But I do get your point. As a developer I know I have a CSZ so I install that package, then start developing. Only once I go to deploy to an RT target will the USB one tell me it isn't compatible by saying it can't bring along some DLL requirement. I guess this is something that the LVAddons might help with. I haven't dived into it yet but as I understand it, files can be made available or not in the IDE based on the target. So then you might install the CSZ USB package, but it won't be on the palette if your target is Linux RT. I actually did run into this issue recently where I was using the JKI REST API. I tested it on Windows and assumed it would work fine on RT since it the normal HTTP functions are on Linux RT. But unfortunately later versions of JKI's package uses the Advanced HTTP functions which are not available. Quote
bjustice Posted July 3 Report Posted July 3 9 hours ago, hooovahh said: I actually did run into this issue recently where I was using the JKI REST API. I tested it on Windows and assumed it would work fine on RT since it the normal HTTP functions are on Linux RT. But unfortunately later versions of JKI's package uses the Advanced HTTP functions which are not available. I ran into this exact issue as well. There is even a good issue ticket on this with some discussion: https://github.com/vipm-io/http-rest-client/issues/29 Jim and I spun off a plugin based package architecture to solve this. Just as others have commented, the plugin architecture means that the parent package is abstract, and then users only need to download the plugin implementation that matches their needs. Pointedly, the windows-only advanced-http-client library is a separate plug package... so you don't need to pull it into memory unless you install and use it. Here is a good discussion on this: https://github.com/vipm-io/http-client-plugin-base/issues/4 Tangentially related: Jim wrote a LabVIEW wrapper around the RUST reqwest crate. and then we wrapped this in a http client plugin. The native LabVIEW http client library is blocking/single-threaded on linux. But, this reqwest implementation is nonblocking. It's been amazing for my needs Quote
ShaunR Posted July 3 Report Posted July 3 (edited) 18 hours ago, hooovahh said: And by that I mean the static dispatch parent with finding classes passed in, or explicit find for each child type? Parking deployment for the moment (as I said, I think it's a separate issue) ... I dislike both. My workflow would be "Find" a chamber (i.e. detect one or more), "open" comms then start setting setpoints, dwells, ramps etc. I don't care who the manufacturer is - that was all sorted during the install, right? Ideally the "find" would return a list of available chambers (an array of class objects) so I'm not sure why I would need to use class specific "find" functions, or even use the actual class constants from a palette. If you no longer require class constants to be passed in to "find", then you can build a "found" array dynamically that users can use. In this flavour of "find, internally you can coerce to a more specific from the general type to actually probe and that coercion can be dependent on what's installed. Edited July 3 by ShaunR Quote
hooovahh Posted July 3 Author Report Posted July 3 42 minutes ago, ShaunR said: My workflow would be "Find" a chamber (i.e. detect one or more), "open" comms then start setting setpoints, dwells, ramps etc. I don't care who the manufacturer is - that was all sorted during the install, right? Ideally the "find" would return a list of available chambers (an array of class objects) so I'm not sure why I would need to use class specific "find" functions, or even use the actual class constants from a palette. If you no longer require class constants to be passed in to "find", then you can build a "found" array dynamically that users can use. In this flavour of "find, internally you can coerce to a more specific from the general type to actually probe and that coercion can be dependent on what's installed. But the "Find" is child specific, you can't use the same find VI for each class type. Some will use RS-232 COM ports. But others could be 485, or Modbus, some TCP IP Addresses, UDP Address, HTTP Addresses, etc. And they will all talk with different protocols. So there needs to be new Find, for each package and class type installed. And using one classes find function should not force a dependency on all the other classes. This is because of the platform specific needs mentioned earlier. If I went the way I think you are describing, you would call a Find function, and it would "return an array of class objects" Okay but to do that don't I need to have all those children classes in memory? Wouldn't that mean using that Find causes a forced dependency on all classes? Then that breaks things like RT deployment when a target doesn't support that type. This is a great elegant solution that I like. But imagine the situation where I would like to pick the RSA polymorphic, and have no other classes in memory. Well no classes at the same level as RSA, obviously the parents of RSA need to be in memory. That's why this solution doesn't work, and that's why a Find which returns an array of classes doesn't work. Quote
hooovahh Posted July 3 Author Report Posted July 3 9 hours ago, bjustice said: Pointedly, the windows-only advanced-http-client library is a separate plug package... so you don't need to pull it into memory unless you install and use it. Here is a good discussion on this: https://github.com/vipm-io/http-client-plugin-base/issues/4 Looks like Jim went with the design where class constants are passed in as an array of classes to operate on like my first example. Quote
Rolf Kalbermatter Posted yesterday at 02:17 PM Report Posted yesterday at 02:17 PM (edited) I solved that in the past a little bit different. When using classes you can fairly easily instantiate child classes dynamically with the Get LV Class Default Value. The idea is that instead of just passing the VISA Resource name, I use a string that identifies both the desired class name and the VISA Resource name (or TCP IP address and port or whatever is needed). Something like "VCP Chamber::COM1" for instance. How you formalize the syntax to map the name identifier to the actual class implementation is another detail that needs some deliberation, but it can be as complex or as simple as you prefer. My Initialize VI from the Base class then parses the string identifier into its parts, builds the path to the VI class file (either just statically or it can even do enumeration of the according class files on disk and try to map them correctly) and then calls Get LV Class Default Value with that path to instantiate the actual class implementation, typecasting it into the base class to call the internal (protected) and dynamic dispatch Initialize Class method which gets the actual VISA Resource name (also as string to stay flexible for other potential interfaces that may not be based on VISA) to open the resource and do whatever the specific device requires. It's very flexible and does not require a static constant that needs to be installed somewhere and explicitly added to the caller in order to instantiate new device types. But it's not exactly a panacea solution. You need to think about the directory structure and how the various class files will be installed in respect to the base class so the Initialize function can find and use them dynamically. It's basically one way to implement the class factory pattern without the base class having to know all possible future child classes beforehand, nor the user having to wire the explicit class constant somewhere. And yes it has the problem about build applications. The LabVIEW application builder doesn't know that the dynamic class is used since there is no direct linker reference to it anywhere. But the whole idea is to make it dynamic to avoid hard-wired dependencies. I usually solved it by adding the according classes explicitly as always included. It felt like the smaller evil of either having a static hierarchy that makes later installations of new child classes a serious problem and the explicit addition of the class file to the build specification. It's basically a documentation issue but we all know of course that users don't read the documentation. 😁 Edited yesterday at 02:41 PM by Rolf Kalbermatter Quote
ShaunR Posted 12 hours ago Report Posted 12 hours ago (edited) 21 hours ago, Rolf Kalbermatter said: it's very flexible and does not require a static constant that needs to be installed somewhere and explicitly added to the caller in order to instantiate new device types. Hooovahh is using the static binding for deployment though. Rather than abstract the transport he wants to abstract the device as a proxy for the transport because then platform specific deployment is automatic. You use VISA for the hardware abstraction and configure the transport with a string. Hooovahh is attempting to configure the transport by not installing a device so that when it's deployed only the platform classes are deployed. I think he will run in to trouble if he has a device that has multiple transports but that doesn't seem an issue right now. Edited 12 hours ago by ShaunR Quote
Rolf Kalbermatter Posted 7 hours ago Report Posted 7 hours ago 4 hours ago, ShaunR said: Hooovahh is using the static binding for deployment though. Rather than abstract the transport he wants to abstract the device as a proxy for the transport because then platform specific deployment is automatic. You use VISA for the hardware abstraction and configure the transport with a string. Hooovahh is attempting to configure the transport by not installing a device so that when it's deployed only the platform classes are deployed. I think he will run in to trouble if he has a device that has multiple transports but that doesn't seem an issue right now. Actually VISA is only one of the possible transports. Each device can implement its own as the addressing and device selection is both a string. I also have done at some point a dual abstraction basically a stream transport layer and higher protocol layer. The protocol layer uses the stream layer through composition. It works but gets rather involved very quickly. Quote
hooovahh Posted 6 hours ago Author Report Posted 6 hours ago On 7/9/2026 at 10:17 AM, Rolf Kalbermatter said: The idea is that instead of just passing the VISA Resource name, I use a string that identifies both the desired class name and the VISA Resource name (or TCP IP address and port or whatever is needed). Something like "VCP Chamber::COM1" for instance. How you formalize the syntax to map the name identifier to the actual class implementation is another detail that needs some deliberation, but it can be as complex or as simple as you prefer. My Initialize VI from the Base class then parses the string identifier into its parts, builds the path to the VI class file (either just statically or it can even do enumeration of the according class files on disk and try to map them correctly) and then calls Get LV Class Default Value with that path to instantiate the actual class implementation I've used a variation of this design in the past and as you said if you load it dynamically from disk, LabVIEW needs to be told to always include it in builds. If I provide VIPM package to someone, I don't think it is an obvious step that they should need to find my class and add it to an always include for builds. I don't need to do that for other APIs, like DAQmx for example. If you can rely on the documentation to have the always include, and you control on disk where things are, your dynamic load solution with naming of the class will work. If I want to avoid always include, and if I want the code to have to be brought as a dependency, I think there are only one of two options for forcing the library to be in memory, so the dependencies are brought along. Either have a class constant somewhere, or a class specific VI. It must be one of those two options right? That was my original question of which design do people prefer and use to force some code to be dependent on that class? Quote
Rolf Kalbermatter Posted 1 hour ago Report Posted 1 hour ago (edited) 5 hours ago, hooovahh said: If I want to avoid always include, and if I want the code to have to be brought as a dependency, I think there are only one of two options for forcing the library to be in memory, so the dependencies are brought along. Either have a class constant somewhere, or a class specific VI. It must be one of those two options right? That was my original question of which design do people prefer and use to force some code to be dependent on that class? Yes, you can't eat the cake and have it too. That is the same in fact for DLLs and other dynamic libraries in any other environment. Full dynamic call means the compiler/linker and any package builder doesn't and can't know about these dependencies automatically. You have to tell it somehow. But I find it debatable if it is really easier for a user to obligate him to use some explicit class constant somewhere in his program or have him make sure to add a class file to the always included section of a build specification. Both need to be documented and explained and the class constant needs to be added in every place again every time. The Build Specification is usually created once for an application and not touched much ever after that. There is of course the point that your API simply won't run (correctly) without class constant so the user is forced to look for the reason. You can even make the according input "always needed" although I tend to implement a minimal simulation in the base class itself. So the user is at some point forced to find out that it is needed. With the Build Specification its a little more involved. You can build the app just fine and only notice that it doesn't work correctly after you run the build executable. But with some good error handling in the Initialize VI you can detect that the implementation is missing and create an according error message. Edited 43 minutes ago by Rolf Kalbermatter Quote
