ASTDan Posted December 29, 2007 Report Posted December 29, 2007 Hello, This hopefully will be a simple question. I am working on some code and to my supprise it has a degree symbol (little circle above numbers). I didn't know LabVIEW had this capibility. I have been trying to figure this out for years. How do you insert a degree symbol into a string? Thanks Happy Holidays! Dan Quote
Dan Bookwalter Posted December 29, 2007 Report Posted December 29, 2007 QUOTE(ASTDan @ Dec 28 2007, 03:01 PM) Hello,This hopefully will be a simple question. I am working on some code and to my supprise it has a degree symbol (little circle above numbers). I didn't know LabVIEW had this capibility. I have been trying to figure this out for years. How do you insert a degree symbol into a string? Thanks Happy Holidays! Dan well on windows you can hold down the ALT key then using the keypad enter the ascii code for the character you want , if remember correctly the degree is ALT-167 .... Dan Quote
Gary Rubin Posted December 29, 2007 Report Posted December 29, 2007 QUOTE(Dan Bookwalter @ Dec 28 2007, 03:12 PM) well on windows you can hold down the ALT key then using the keypad enter the ascii code for the character you want , if remember correctly the degree is ALT-167 .... You can also used the Windows character map to find the symbol (it's in the Symbols font), copy it to the clipboard, then paste it into LabVIEW. Quote
TobyD Posted December 29, 2007 Report Posted December 29, 2007 QUOTE(Dan Bookwalter @ Dec 28 2007, 12:12 PM) well on windows you can hold down the ALT key then using the keypad enter the ascii code for the character you want , if remember correctly the degree is ALT-167 ....Dan ALT+0176 will give you a smaller version. Hold either ALT key and type 0176 on the keypad (you must use the keypad - the numbers above the keyboard will not work). ALT+167 = º ALT+0176 = ° Quote
AdamRofer Posted December 29, 2007 Report Posted December 29, 2007 QUOTE(TobyD @ Dec 28 2007, 01:05 PM) ALT+0176 will give you a smaller version. Hold either ALT key and type 0176 on the keypad (you must use the keypad - the numbers above the keyboard will not work).ALT+167 = º ALT+0176 = ° http://en.wikipedia.org/wiki/Degree_symbol QUOTE On Apple Computer's Mac OS, the degree sign can be typed by Option-Shift-8 on most keyboard layouts, including Australian, British, Canadian and U.S. Extended layouts. (Option-K, on the other hand, is "ring above") On Microsoft Windows, the degree sign can be typed by ALT + 0176 on the numeric keypad. On Linux and other Unix-like systems, many keyboard layouts allow typing the degree sign with AltGr+Shift+0. Due to a similar appearance in some fonts in print and on computer screens, some other characters may be mistakenly substituted for it: the "masculine ordinal indicator" (U+00BA, º ), the "ring above" (U+02DA, ˚ ), "superscript zero" (U+2070, ⁰ ), superscript zero proper ( 0 ) or superscript letter "o" ( o ), and the "ring operator" (U+2218, ∘ ). So, like everyone said, but ALT+0176 is the only "proper" degree symbol (U+00B0, °) (I just learned this today). --- Adam Rofer Quote
PJM_labview Posted December 29, 2007 Report Posted December 29, 2007 Alternatively, if all else failed, you can generate it programatically ( ).Download File:post-121-1198880077.vi PJM Quote
jdunham Posted December 29, 2007 Report Posted December 29, 2007 QUOTE(AdamRofer @ Dec 28 2007, 02:05 PM) So, like everyone said, but ALT+0176 is the only "proper" degree symbol (U+00B0, °) (I just learned this today). In a legacy from MS-DOS days, you can also generate this character with ALT-248. My other favorite is ALT-241, which gets you plus-or-minus (±). You can use this method to generate any of the 'standard' 8-bit ASCII characters 0-255. Jason Quote
ASTDan Posted December 30, 2007 Author Report Posted December 30, 2007 Wow super cool. Now to fully open a can of worms. Where can I find a list of all common symbols i.e. degree, plus minus, etc. Where is the ASCII codes for all this stuff. I wasn't aware of the Alt+176 Thanks. Also on a comment note wouldn't it be cool if there was a Open G library that contained common symbols like the one posted by PJM_LabVIEW. Quote
Dan Bookwalter Posted December 30, 2007 Report Posted December 30, 2007 QUOTE(ASTDan @ Dec 29 2007, 09:38 AM) Wow super cool. Now to fully open a can of worms. Where can I find a list of all common symbols i.e. degree, plus minus, etc. Where is the ASCII codes for all this stuff. I wasn't aware of the Alt+176Thanks. Also on a comment note wouldn't it be cool if there was a Open G library that contained common symbols like the one posted by PJM_LabVIEW. here is one source , remember keep repeating to yourself GOOGLE IS MY FRIEND ;-) http://www.asciitable.com/ Have Fun Dan Quote
Ton Plomp Posted December 30, 2007 Report Posted December 30, 2007 QUOTE(ASTDan @ Dec 29 2007, 03:38 PM) Where can I find a list of all common symbols i.e. degree, plus minus, etc. Where is the ASCII codes for all this stuff. I wasn't aware of the Alt+176 QUOTE(Dan Bookwalter @ Dec 29 2007, 05:19 PM) Well LabVIEW has an ASCII table included: <ctrl-?>, search, ASCII Codes, and at #29 is a table. But unfortunately it's incomplete, only the first 127 charactars are shown. Ton Quote
Rolf Kalbermatter Posted December 31, 2007 Report Posted December 31, 2007 QUOTE(tcplomp @ Dec 29 2007, 01:09 PM) Well LabVIEW has an ASCII table included: <ctrl-?>, search, ASCII Codes, and at #29 is a table.But unfortunately it's incomplete, only the first 127 charactars are shown. Ton It's complete. ASCII doesn't define more than that. The rest are extended characters that depend on the currently set local, the font used etc, etc. Rolf Kalbermatter Quote
