VI in Subpanel
jgcode
Is there a way for a VI to tell if it is currently loaded in a subpanel?
Maybe a property?
Anyone know?
Cheers
JG
Edited by jgcode
Maybe a property?
Anyone know?
Cheers
JG
Not sure if there is a better way. But if you try to load it into a sub-panel and it is already in one, you will get
Error 1145
Possible Reason(s)
Labview: Cannot open VI because it is already in a subpanel control.
If its not in memory, it will succeed, and if its already running but not in a sub panel you get
Error 1144
LAbview: Cannot insert VI in subpanel because VI is already open.
Error 1145
Possible Reason(s)
Error 1144
Excellent "cat skinning" there Shaun! You absolutely shreaded the "box" I was thinking in.
Ben
Uh, oh. Ben, were you not reading the CLAD thread yesterday, or did you just feel like rattling some cages?
I had no idea what was posted yesterday since I can't convince the LAVA site to show me unread threads. Its is like I have to stand here and watch it to see message come up. I feel like I am viewing the landscape out of a train window. I can't look back or forward but can only catch a glimpse of what is passing at the moment and that is on my work machine. On my home machine it is like the drapes are closed.
Ben
Ben
This isn't really the right tread for this but why don't you use the RSS feature? Not that the RSS is 100% right now, but it doesn't miss content, it just some times adds old content.
I use outlook for my RSS reader, but a better solution for you might be Google reader. It's an in browser RSS reader that is linked to your gmail account. So if you read some RSS at work then go home it will show that you read those articles. reader.google.com
Error 1145
Possible Reason(s)
Error 1144
Cheers, but its not that I want to load it, I just want to know when the VI tests itself - is it the "active VI" in the subpanel out of a possible number of VIs at a given time. So if it isn't I don't want any actions to be performed, so unfortunately this will not work for my task. Thanks tho.
<edit>
Ok had a thought and it worked
The Front Panel:Open property is True when the VI is loaded in the subpanel
False otherwise
Easy!
Problem sorted
Cheers
</edit>
Edited by jgcode
Ben
I have my moments. As few and far between as they may be though :)
<edit>
False otherwise
Easy!
Problem sorted
Cheers
</edit>
Ah. Thought you wanted to definitively know. Just for reference. It will also show as maximized.
I am using LV2009 and FP:State property toggles between Standard (in subpanel) and Closed (not in subpanel)- but not maximized ??
That is ok tho, cause now I have a way for the VI to test itself.
Cheers
Edited by jgcode
  • 2 weeks later...
Cheers
Can I have multiple subpanels (on the same 'main' vi) show the same opened vi? Each representing its own instance (and access to its own data)?
Say forinstance that I have a VI that shows a word from a list. I have three lists - one each for subject, verb and object. I know how to set the value of a front panel item, so I can set a VI's data in that respect. I just cannot seem to InsertVI into multiple subpanels.
Any suggestions?
Any suggestions?
I haven't tried this specifically but I suspect that if you make your subVIs re-entrant it would work.
False otherwise
Easy!
Problem sorted
Cheers
FP:Open only tells you if the front panel is open anywhere.
This may be enough, if you only want to distinguish the two states "closed" and "open in subpanel".
But what if you'd like to distinguish (1) "closed", (2) "open as separate window" and (3) "open in subpanel"?
I just found a very interesting private VI property: Front Panel Window:OS window.
This property returns 0 if there is no OS window for this VI (which is the cases for (1) and (3)).
If the VI has it's own window, this property returns a number >0 (case (2)).
In combination with FP:Open, this enables you to tell exactly what the state of the panel really is.
