athalia Posted November 24, 2009 Report Share Posted November 24, 2009 Hi there, Need help...can i convert a labview9version file to a labview7.1? Im currently using 7.1version...but im trying to read a 9version file...Is there a way to read it? Thanks and Cheers!! Hi there, Need help...can i convert a labview9version file to a labview7.1? Im currently using 7.1version...but im trying to read a 9version file...Is there a way to read it? Thanks and Cheers!! heres the file... Password Input.vi Password Input.vi Quote Link to comment
jgcode Posted November 24, 2009 Report Share Posted November 24, 2009 Hi Athalia As long as all functions and structures etc... used are available in 7.x then you should be able to. I know you can't save for 7.x using 8.2.1, I don't know which is the first lower version that will work but 8.0 should be fine (maybe someone can confirm which it is?). You will have to open the VI in LabVIEW 2009 first. Then select File>>Save for Previous Version... Then save it down to e.g. LabVIEW 8.0. Then you will have to open the new VI in e.g. LabVIEW 8.0 Then select File>>Save for Previous Version... again to 7.x 1 Quote Link to comment
Clio75 Posted November 24, 2009 Report Share Posted November 24, 2009 This is annoying. The two highest on my "bug" list is : - you can't save to older version without having them all installed - You can't open a VI that is to old with out having the correct verions installed. For me I need sometimes to open old VI(I have some from 5.0 and 7.0) or exampels that is writen by others. And this is not possible if you install the newest. All this head-banging gives me headache (clam down. Count from 10 to 1 slowly) Quote Link to comment
athalia Posted November 24, 2009 Author Report Share Posted November 24, 2009 Hi Athalia As long as all functions and structures etc... used are available in 7.x then you should be able to. I know you can't save for 7.x using 8.2.1, I don't know which is the first lower version that will work but 8.0 should be fine (maybe someone can confirm which it is?). You will have to open the VI in LabVIEW 2009 first. Then select File>>Save for Previous Version... Then save it down to e.g. LabVIEW 8.0. Then you will have to open the new VI in e.g. LabVIEW 8.0 Then select File>>Save for Previous Version... again to 7.x LabVIEW 2009? Is it the latest version? or its just the installer add-on?or are you talking about the version 9? Because im quite new to VI Thanks for the reply though.Appreciate it This is annoying. The two highest on my "bug" list is : - you can't save to older version without having them all installed - You can't open a VI that is to old with out having the correct verions installed. For me I need sometimes to open old VI(I have some from 5.0 and 7.0) or exampels that is writen by others. And this is not possible if you install the newest. All this head-banging gives me headache (clam down. Count from 10 to 1 slowly) Ya you are rite..why cant they just make it compatible with the rest of the version...haha Quote Link to comment
Francois Normandin Posted November 24, 2009 Report Share Posted November 24, 2009 LabVIEW 2009? Is it the latest version? or its just the installer add-on?or are you talking about the version 9? Yes, version 9.0 is LabVIEW 2009, the newest. Quote Link to comment
hooovahh Posted November 24, 2009 Report Share Posted November 24, 2009 For me I need sometimes to open old VI(I have some from 5.0 and 7.0) or exampels that is writen by others. And this is not possible if you install the newest. All this head-banging gives me headache (clam down. Count from 10 to 1 slowly) Actually you can have many versions of LabVIEW installed at once. I at one time had 5.0, 6.0, 6.1, 7.1, 8.0, 8.2, 8.5, 8.6, and 2009. All in Windows XP SP3. It's kind of a pain to setup, and it is better to use virtual machines for this if possible. A discussion was created some time ago but I can't seem to find it. Quote Link to comment
athalia Posted November 24, 2009 Author Report Share Posted November 24, 2009 Yes, version 9.0 is LabVIEW 2009, the newest. hmmm so you are saying that I can actually keep my version7.1 and install version9 without uninstall my version7.1? Thanks! Quote Link to comment
jzoller Posted November 24, 2009 Report Share Posted November 24, 2009 hmmm so you are saying that I can actually keep my version7.1 and install version9 without uninstall my version7.1? Thanks! Warning! Installing newer versions after installing 7.1 will remove your 7.1 DAQ drivers. Such a charming behavior. Joe Z. Quote Link to comment
hooovahh Posted November 24, 2009 Report Share Posted November 24, 2009 Warning! Installing newer versions after installing 7.1 will remove your 7.1 DAQ drivers. Such a charming behavior. Joe Z. Thanks for mentioning that. While many versions of LabVIEW can co-exist happily, the addons, and extras that come with LabVIEW is a more difficult. When I said "it is a pain to setup" I should have mentioned the extra difficulties involved in making everyone happy. While I had all these versions installed they were mostly used for down converting code. I never actually deployed code saved in 5.0 to a DAQ system. Quote Link to comment
Yair Posted November 24, 2009 Report Share Posted November 24, 2009 The two highest on my "bug" list is : - you can't save to older version without having them all installed This is no longer true. At least so far, every version since 8.2 can save all the way back to 8.0. - You can't open a VI that is to old with out having the correct verions installed. Yes, but the numbers are reasonably large. You may not be able to open your 5.0 VIs in the newest versions, but you can definitely open the 7.0 VIs. Why are these "highest" on your list? Do you move code between versions often? Quote Link to comment
athalia Posted November 26, 2009 Author Report Share Posted November 26, 2009 Could anyone help me to convert this file to 7.1 version..please!! thanks!! zxcz.vi solenoid.vi Quote Link to comment
athalia Posted November 30, 2009 Author Report Share Posted November 30, 2009 Hi Athalia As long as all functions and structures etc... used are available in 7.x then you should be able to. I know you can't save for 7.x using 8.2.1, I don't know which is the first lower version that will work but 8.0 should be fine (maybe someone can confirm which it is?). You will have to open the VI in LabVIEW 2009 first. Then select File>>Save for Previous Version... Then save it down to e.g. LabVIEW 8.0. Then you will have to open the new VI in e.g. LabVIEW 8.0 Then select File>>Save for Previous Version... again to 7.x Hey jgcode thanks for the steps given from you...Ive manage to convert the file...just like you instruct. Thanks again!! Quote Link to comment
jgcode Posted November 30, 2009 Report Share Posted November 30, 2009 Hey jgcode thanks for the steps given from you...Ive manage to convert the file...just like you instruct. Thanks again!! No worries, glad you got it to work! Quote Link to comment
Vinc1 Posted February 21, 2020 Report Share Posted February 21, 2020 Hi everyone, There's someone that can help me by converting the attached file (LV2015) into LV2014 file? The attached file contains a DLL to manage a pressur controller.. It's impossible for me convert the file, searching in the forum i read that there's no way to open file newer than your version to convert them. Can someone help me please? Thanks ge_pace_series.zip Quote Link to comment
crossrulz Posted February 21, 2020 Report Share Posted February 21, 2020 Your best bet is to put your request here: NI Forums - Version Conversion 1 Quote Link to comment
Mefistotelis Posted February 21, 2020 Report Share Posted February 21, 2020 pylabview could do it, but it looks like there are differences in "Virtual Instrument Tag Strings" section, and the parser can't read that section ATM: So - only NI can help you, unless you are willing to help in development of pylabview. 1 Quote Link to comment
Vinc1 Posted March 3, 2020 Report Share Posted March 3, 2020 Thank you all for the reply! So, what can i do? The file that i've attached in the first message is a Labview Library to hanlde the pressure controller GEPace series 5000... The library is provided by NI at this page http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=8D9CF3659FFC6452E04400144F1EF859 Do you think thath the only way is to contact NI? Thanks Quote Link to comment
Vinc1 Posted March 3, 2020 Report Share Posted March 3, 2020 On 2/21/2020 at 1:48 PM, crossrulz said: Your best bet is to put your request here: NI Forums - Version Conversion Thanks, I'll try this Quote Link to comment
